Old June 2nd, 2011, 07:29 AM   #1
AdreeN
Motorcycle(s): 250r
HIDs too bright, what now?
So my HIDs pretty much light up the entire road/sidewalks, and worst of all, blind vehicles infront of me.
I have oncoming cars flashing their highbeams at me to let me know.
What can I do now?
Are there "stickers" for headlights where it will cut off the top portion of the headlights so it isn't shooting above cars and houses as I pass by.
Or should I black out the headlights?
Any advice?
AdreeN is offline   Reply With Quote
Old June 2nd, 2011, 07:39 AM   #2
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
You can adjust the headlight; there are screws on the back allowing you to adjust them. HID's are meant to be used in projectors specifically for this reason, it's hard to control the light without them.
Live2ride is offline   Reply With Quote
Old June 2nd, 2011, 08:24 AM   #3
Jinx250
Smoker
Motorcycle(s): Guess....
Put it back to stock and use SilverStar bulbs.
Jinx250 is offline   Reply With Quote
Old June 2nd, 2011, 08:36 AM   #4
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
aim them lower. I've been running HID's for a couple months now, and the only time I've been flashed was when I had a passenger. I aimed mine a little lower than stock and they are fine. I'm never going back to halogens. Still wanna retrofit some projectors tho.
kamikaze is offline   Reply With Quote
Old June 2nd, 2011, 08:37 AM   #5
Cuongism
Cuongism's Avatar
You can re-aim them to point down and away from oncoming traffic. Do you know what color bulb you currently have? You can get less intense bulbs like 4500 or 3k if your current bulbs are high. There's a local place by me that sells them for $10-15 so you may have luck up there as well.
Old June 2nd, 2011, 08:38 AM   #6
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
http://www.ehow.com/how_5211767_alig...eadlights.html
If the adjustment still doesn't work, either retrofit some projectors or go back to regular bulbs.
The www.ModMy250.com guy
Old June 2nd, 2011, 08:42 AM   #7
CThunder-blue
ModMy250.com
4500k or 3000k will be brighter than the 5000k+ bulbs. The numbers just mean what color range they are, not how many lumen they output. 3000k is usually what OEM systems use and are as close to daylight (yellow tinge) as you will get. 4500k are aftermarket bulbs and are closer to white. Once you go beyond 4500k, the lumen go down as the light moves thru the color spectrum. 13000k, for instance, is purple and outputs as much light as a regular bulb.
Old June 2nd, 2011, 08:46 AM   #8
Cuongism
Cuongism's Avatar
Thanks for the clarification. The other effect on lumens I would imagine is wattage? Check to see if you have 35 or 55 watt.
Old June 2nd, 2011, 09:00 AM   #9
kamikaze
kamikaze's Avatar
yea. I've got the 55w 5000k bulbs and they are amazing. the other thing when you go to the higher wattage it tends to wash a little of the colour out, so you can usually go one bulb temp higher.
Old June 2nd, 2011, 09:24 AM   #10
lux
I think you turn the knurled knob to the left to lower.
lux is offline   Reply With Quote
Old June 2nd, 2011, 11:28 AM   #11
AdreeN
Motorcycle(s): 250r
thanks for all the replies!
i'm definitely not going back to stock anytime soon, as i already spent the money on the hids.
i can't exactly "aim" them, because the HIDs to begin with don't quite fit right into the housing (right bulb size, but didn't fit in housing), i had to bend the metal bracket that holds it and add some material to get it to sit tight.
the last thing i want to do is re-do that process and hope it aims lower.
can i put some sort of decorative vinyl/tape over the top edge of the headlights so that it doesn't beam over people's cars and into their eyes?
FYI i'm running 60k HIDs :S
I wanted the colour to stand out from the rest of the lights on the road so I would make me more visible, now I'm just blinding.
Old June 2nd, 2011, 11:35 AM   #12
CThunder-blue
ModMy250.com
As long as it's in the housing, you should be able to aim it. The knob will adjust the plate that the bulb sits in.
Old June 2nd, 2011, 11:38 AM   #13
first, make sure the bulbs are seated flat in the headlight socket receptacle. if they are just a bit off, that will make for horrendous light scatter.
second, aim your headlights (very critical). they are most likely not pointed correctly. my bike was waaay out as delivered from the factory.
third, the last thing you want is to draw attention to HID kits as all aftermarket/retrofitted HID kits are illegal (not DOT approved). besides, you get the most illumination with 4300K color temp bulbs.
Old June 2nd, 2011, 11:40 AM   #14
AdreeN
Motorcycle(s): 250r
awesome thanks for the tips.
i'm a nub when it comes to mechanical parts.
i'll def try to aim them downwards more when i have time.
Old June 2nd, 2011, 11:52 AM   #15
http://www.ninjette.org/forums/showp...18&postcount=9
Old June 2nd, 2011, 04:19 PM   #16
c717905
c717905's Avatar
Motorcycle(s): 2009 Black Ninja 250, 2009 Black ZX-6r
I had this problem and seriously considered removing the low beam HID. I finally was able to aim it simply by sticking my hand through the bike, up underneath the front fairing and physically wiggling the wires to the bulb, and thus moving the bulb, until the pattern was low enough to suit me. I know it sounds ghetto, but I tried turning the adjustment knob to no avail and this jerry-rigged way worked.
Black '09 250R: Bridgestone BT-021s-Yoshi CF Slip-On-Fender Eliminator-Corbin Seat-Seat Cowl-Proton Flushmounts-BikeLiteZ Taillight-LED Glow-HIDs-Reflective Rimtape-Yoshi Rearsets-MRA DB Windscreen
c717905 is offline   Reply With Quote
Old June 2nd, 2011, 08:54 PM   #17
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
Blinding a cars bad imagine the 2 ton thing coming strait at you because it cant see ahead :S
rusninja is offline   Reply With Quote
A few questions about HIDs blades8306 General Motorcycling Discussion 15 November 28th, 2012 10:34 PM
Anyone know if these hids will work? Liquidtoon 2008 - 2012 Ninja 250R Farkles 6 August 2nd, 2010 10:11 AM
Flickering HIDs The_beanz 2008 - 2012 Ninja 250R Tech Talk 2 February 1st, 2010 03:17 PM
HIDs ?!?! overload 2008 - 2012 Ninja 250R Tech Talk 2 November 4th, 2009 01:58 PM
HIDs KVR 2008 - 2012 Ninja 250R Tech Talk 0 April 15th, 2009 07:58 PM
