Old October 10th, 2014, 07:48 PM   #1
mrudich
mrudich's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
Small puncture in tire
I noticed my psi was low the other day, so I aired it up. But then at the end of the day I checked it and the psi was back down again. I found this little sucker embedded in my (back) tire.
My tire is relatively new. Still seems to have a decent amount of tread life on it so it would be very preferable to not have to replace it... Also I'm very low on money and a new tire will have me eating rice and beans for a month. But then again a crash would be significantly more hurtful on my already strained budget (and also my body..)
I've heard a lot of debate on the effectiveness and safety of patches/plugs. There seems to be no clear answer..
I can't decide what to do.
mrudich is offline   Reply With Quote
Old October 10th, 2014, 08:31 PM   #2
You'll get differing opinions, and very few tire shops will tell you anything other than replace it. That looks like a small puncture, looks like it is near the center of the tire, and down into the tread. As far as ones that I'd consider plugging/patching myself, it's near the top of the list.
Old October 10th, 2014, 09:04 PM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I don't care for the this or that argument... I can plug a tire; I can't take it off to internally patch it, I go with what I know... As of yet it hasn't let me down
Old October 10th, 2014, 11:54 PM   #4
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
A plug is a good repair to get you out of trouble, but a patch would be a more secure repair, I wouldn't waste the tyre for that small a puncture. Get it patched from inside, wear the tyre out and replace it.
Originally Posted by jgcable;
I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it.
baxtc1 is offline   Reply With Quote
Old October 11th, 2014, 01:40 AM   #5
mrudich
mrudich's Avatar
Seems like repair it is.
I'm gonna call up all of my local motorcycle shops (there're only like 2.5) tomorrow and see what an internal patch might cost. Hopefully not too much!
Old October 11th, 2014, 07:52 AM   #6
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
Buy some Ride On tire sealant, install it, ride a few miles, pull the nail and you're golden. Plus the next time you get something in that tire, just pull it and you won't lose any air pressure. And it will fine tune the balance of the tire too. Much cheaper than having a shop install a one time patch.
http://www.youtube.com/watch?v=YqkBfEHYzxw
flitecontrol is offline   Reply With Quote
Old October 11th, 2014, 02:11 PM   #7
mrudich
mrudich's Avatar
Crud. None of my local motorcycle shops repair tires..
I'm not quite sure if I trust an external plug done by myself with no previous experience. But I have no means of doing an internal patch.
Old October 11th, 2014, 02:12 PM   #8
mrudich
mrudich's Avatar
Does anyone else have experience with this stuff? If it works then this seems like maayybe the stuff to go with.
Old October 11th, 2014, 02:15 PM   #9
I've always had good luck with these:
http://www.stopngo.com/pocket-tire-p...ubeless-tires/
Old October 11th, 2014, 02:32 PM   #10
mrudich
mrudich's Avatar
I'm assuming the mushroom style plugs work better than the standard plugs like these:
http://www.stopngo.com/atv-tire-repair-kit/
Old October 11th, 2014, 04:46 PM   #11
flitecontrol
Did you watch the video? Pretty good demonstration of how well it works there. I have it in all my tubeless bike tires.
Old October 11th, 2014, 05:03 PM   #12
mrudich
mrudich's Avatar
Have you ever personally gotten something in your tire that would have caused a flat but was prevented by the ride-on stuff? Just curious.
Old October 11th, 2014, 05:10 PM   #13
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
I have used a ton of plugs. On motorcycles or cars. they have never failed me.
ok maybe one or two leaked after I was done and had to be redone. Patches are even better and easy to install. take an afternoon pull the tire . patch it. reinstall and balance it.
They work great . I had nine plugs on one truck tire after I ran over a pile of roofing working one day. The tires lasted another year before they ran out of tread and I replaced them.
LIFE IS NOT FOR REGRETS OR EXCUSES.
Breath deep, seek peace.
Embrace the Madness. Life is good, let it be
Old October 11th, 2014, 05:22 PM   #14
mrudich
mrudich's Avatar
Did you use the mushroom style or the other kind? (String?)
And sadly I don't have the necessary stuff to take a wheel off.
Old October 11th, 2014, 05:33 PM   #15
flitecontrol
Yes, I have. Picked up a sheet metal screw in the back tire of the VN750. Pulled it out, the hole sealed right up, and no loss of air pressure. Good stuff.
There may have been other objects that got in the tires, but I didn't notice them.
Old October 12th, 2014, 06:22 AM   #16
.........And sadly I don't have the necessary stuff to take a wheel off.
Sooner or later you will have to do it, Mateo.
If you plan on keeping riding, knowing how will become very good.
Needed tools are not more than $20.
Using the services of a shop will be much more expensive.
Plugs work; when they don't any longer, you can use a good tire for many more miles by installing an inner tube.
Old October 12th, 2014, 09:52 AM   #17
Klondike1020
Intrepid Adventurer
I use the generic string types found at walmart and other places.
I bought a special kit to keep in my bike, made for motorcycles. I use the cheapo ones on other peoples bikes lol
The tools needed to take the wheel off are cheap. and a balance from harbor freight would work well.
Some bike shops would patch it for cheap. Being that it is a tiny hole. I would suggest patching it from inside. In order to make a plug work you will have to ream the hole out and that will make it larger and take more meat out of the radial belting. I prefer not to incur more damage on the structure of the tire if I can avoid it, especially if the cost is only a little more effort. Pull the wheel, air it out, tire spoon the tire so one side is off the rim. Patch the hole from inside. Spoon the tire back on .
That coating that goes on the inside of the tires is amazing. I am certainly going to invest in that when I get an adventure touring bike. So far it has not been an issue with my sport bike.
Old October 12th, 2014, 01:34 PM   #18
flitecontrol
Kinda surprised Ride On tire sealant isn't better known on this forum. When you consider the hassle of dealing with a flat on the road, it's not just a matter of patching the tire, you have to air it up too! One flat will make you a True Believer/convert to Ride On! What's it worth to never have to patch a tire or get a flat? Priceless.
Old October 12th, 2014, 01:39 PM   #19
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
The main problem with the sealant goops is that it makes a mess on the inside of the wheel.
I, too, am a fan of the string (sticky pipe cleaner gummybear) plugs: easy to install with the $7 kits; pump the tire with a 12 volt portable Walmart-type pump. Good for fixing your car tires, as well. And doesn't require removing the tire (I save that for when I replace tires).
Old October 12th, 2014, 01:59 PM   #20
Klondike1020
Intrepid Adventurer
The coating that Flitecontrol is referring to is not gooey, or messy. You put a coating inside the tire and it stays adhered to the tire for life of tire. It never moves or gets on the wheel. Thats the best part.
Old October 12th, 2014, 05:21 PM   #21
flitecontrol
Exactly right. Some of those gooey tire sealants can get on the rim and corrode the metal, in addition to the mess mentioned earlier. Ride on stays on the tire and never contacts the rim. I used to have a pic of a tire cut in half with Ride On installed, but can't find it. Here's a good diagram showing where the Ride On goes (and stays).
https://www.google.com/search?q=pict...ts%3B250%3B266
Old October 12th, 2014, 05:44 PM   #22
Auto-balancing tires is a bonus.
... Also I'm very low on money and a new tire will have me eating rice and beans for a month......
Riders rolling on a budget should consider the cost of tire sealants.
Flat-proofing (for small punctures on vertical rolling surfaces) our tires using Ride-On takes (2) 8-oz. bottles of Ride-On TPS tire sealant for motorcycles, which costs $30+SH.
Old October 13th, 2014, 02:25 AM   #23
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Exclamation
A few years ago, I bought a Stop-n-go kit. Seemed like the perfect idea.
The plugs are coated with slippery stuff, maybe silicone? to help them squeeze thru the insertion needle.
I tried it twice. Both times the plug came loose and popped back inside the tire. After the second time, (and nearly crashing) I repurposed the kit as a rifle target. It work beautifully. They may work fine on a tire that has a thick carcass (like a car tire), but failed miserably on my motorcycle.
Now I carry a "string" plugger. Last time I used it, the tire worked fine until it wore out.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old October 13th, 2014, 02:20 PM   #24
dcj13
Participant
dcj13's Avatar
True about the auto-balancing qualities of liquids in tires. But two 8 oz bottles of sealant? That's adding a significant amount to the rolling mass-moment of inertia of each tire! And adds to un-sprung weight.
A few years ago on one of the BMW forum/lists, there was a discussion about the virtues/pitfalls of Dyna-beads in lieu of static or dynamic balancing. And one only uses a couple of ounces of the Dyna-beads...
Last futzed with by dcj13; October 13th, 2014 at 04:40 PM.
Old October 13th, 2014, 03:10 PM   #25
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I've used the cheap string plugs kits many times in the last 73K miles. Even had to plug two holes at once in a front tire due to a staple. Every tire I've plugged I've run down to the bare minimum tread, never had an issue. I'm currently running a plug in my rear tire from a nail I picked up at less than 5K miles, that tire should go to 25K miles like the previous ones did.
Old October 13th, 2014, 08:59 PM   #26
flitecontrol
Ebay ha it for a little less than $14/bottle with free shipping. I believe it takes one bottle per tire or therabout.
Eight ounces per tire is significant? Wouldn't tire wear tend to compensate for the weight of the Ride On?
Old October 13th, 2014, 09:26 PM   #27
Klondike1020
Intrepid Adventurer
lol people are crazy. If ya dont get flats. Dont get the sealant. IF you are going to be ridding where it may be an issue. Write off the cons and do it.
lol redic
[visordown.com] - Police puncture unlocked motorcycles tyres Ninjette Newsbot Motorcycling News 0 February 27th, 2014 09:50 AM
[motorcyclenews.com - news] - Small bikes for a small budget Ninjette Newsbot Motorcycling News 0 August 30th, 2013 09:40 AM
[motorcyclenews.com - news] - Small bikes for a small budget Ninjette Newsbot Motorcycling News 0 August 30th, 2013 02:40 AM
[roadracingworld.com] - Sport Tire Services Announces New Dunlop Race Tire Distributo Ninjette Newsbot Motorcycling News 0 February 6th, 2009 02:40 PM
[nytimes.com] - For Motorbike Dealer, There Are No Small Parts, Only Small Plans Ninjette Newsbot Motorcycling News 0 November 12th, 2008 11:58 PM
