June 19th, 2012, 07:26 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150 Posts: 146
WTB - Pre Gen Valve Adjustment Tool
I'm looking for a valve adjustment tool for a pre-gen Ninja 250. The new gen tool is proably the same thing, but I don't know for sure. The part number is 57001-1220.
Thanks, Jim Moore Jax, Fl
Jim Moore Jax, FL |
June 19th, 2012, 02:32 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
New-gen is not the same. Pre-gen used valve tappets. New-gen uses valve shims. I haven't worked on valves on a pre-gen, but I have on my Honda that uses tappets and a valve tool isn't required to do the adjustment.
June 20th, 2012, 07:03 AM | #3 |
The pregen tool is basically a 9mm socket & handle with a small flat-blade screwdriver down the middle of it. The screwdriver turns/holds the adjuster screw while the socket tightens the locknut. You can use a regular socket/ratchet and screwdriver, but they have to be used separately and often times the action of tightening the nut turns the screw and changes the adjustment. Without the tool it's a lot of trial and error to get the adjustment perfect, so the main benefit to the tool is saving time. If you were really handy you could make your own tool by welding a handle to a deep 9mm socket and using a small screwdriver down through the socket.
As was said, the newgens use bucket and shim valve adjustment, for those you measure the existing gaps, remove the camshafts and take out the buckets, measure the shims, calculate what new shims are needed, install the new shims in the buckets, and reassemble the motor. |
June 20th, 2012, 07:22 AM | #4 |
Thanks guys, I appreciate the info. Sounds like I'm looking for a pre-gen tool. As a note, I checked the valves this week. The thought of trying to do an adjustment in those tiny spaces was so traumatizing it sent me on a tool hunt.
Jim Moore Jax, FL |
valve adjustment tool is it necessary? | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 8 | July 20th, 2014 08:26 PM |
For Sale: Valve Adjustment Tool | cbdallas | Motorcycle-related | 2 | January 9th, 2014 04:03 PM |
digital caliper? right tool for valve adjustment. | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 15th, 2013 01:50 PM |
need help fast!!!! valve adjustment tool | 4x4kayak2112 | 2008 - 2012 Ninja 250R Tech Talk | 0 | May 6th, 2011 07:37 AM |
valve adjustment tool | EvnEvn724 | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 5th, 2011 09:49 AM |
