Go Back   ninjette.org > Marketplace > Motorcycle-related
Old June 9th, 2011, 08:58 AM   #161
dubojr1
dubojr1's Avatar
Originally Posted by Live2ride View Post
I've had no issues with clearence of the chain guard; or anything for that matter. My chain guard is at least 2-2.5 inches away from the rearset adjusters / rearsets. You may want to check your chain guard for warping.
This may be true while parked but how close does it come during suspension travel?
Old June 9th, 2011, 09:21 AM   #162
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
I just went out to my shed and jumped up and down with the full force of my 250lb. Butt on my bike. It was still at least 2 inches away from the rearset adjuster, even further from the rearset itself. I could make a video if you don't believe me .
Live2ride is offline   Reply With Quote
Old June 9th, 2011, 09:24 AM   #163
dubojr1
dubojr1's Avatar
Sweet I'm glad it clears.
Maybe some pics of his chain guard damage would be good now.
Old June 9th, 2011, 10:22 AM   #164
Originally Posted by infinitethrill View Post
Dropped the rearset from the top back slot to the bottom back slot. Just lowering them a tad bit. In the rear position, the edge of the left rearset is hitting the chain guard plastic right near the bolt that holds the chain guard there. There is a gouge in the plastic where it is hitting. I can feel the swingarm move (speedbump or similar) and smack my foot pretty hard through the peg. May have to dremel it down a bit, but the metal bracket is just below that... Otherwise seems to be working good.
Preload setting?
Old June 14th, 2011, 03:50 AM   #165
infinitethrill
forever a n00b
infinitethrill's Avatar
Motorcycle(s): 08 ex250J, 78 GL1000, 01 ex250f, 99 VFR800FI
Whoops, didn't see this post till now. Anyway its picture time -
After a while I stopped feeling the smack when they hit, seems the gouge is big enough that clearance issues are no longer there. As long as they don't bump together it works for me. I would be concerned about loosing further suspension travel when needed at full lean. Maybe need to dremel it out a bit.
Edit: I run my preload setting at the lowest possible. I am 120 pounds so that is what is recommended for my weight. Have not tried two up since I got the adjusters but it may be a problem...
infinitethrill is offline   Reply With Quote
Old June 14th, 2011, 04:41 AM   #166
dubojr1
dubojr1's Avatar
Your avatar looks like it is lowered also. Is this true?
Old June 14th, 2011, 05:33 PM   #167
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Mine don't come near of anything?? What is that in th picture. Chain gaurd?
scotty is offline   Reply With Quote
Old June 14th, 2011, 11:47 PM   #168
infinitethrill
forever a n00b
Nope, bike has not been lowered. I would never do that. Eww. Anyway, is my bike broken? I thought it was normal
Old June 15th, 2011, 01:11 AM   #169
You sure the previous owner didn't lower it?
Old June 15th, 2011, 04:44 AM   #170
dubojr1
dubojr1's Avatar
+1
It sure looks lower than stock in your avatar...
Old June 15th, 2011, 07:50 AM   #171
Live2ride
Live2ride's Avatar
I just wanted to add that the ground clearence with these adjusters is noticeably higher and I feel much more confident when taking sharp turns. Now I just need to take off those useless peg feelers that keep catching my pant legs .
Old June 15th, 2011, 05:32 PM   #172
infinitethrill
forever a n00b
Verdict says:
Do I need a different angle or can someone tell from this?
Old June 16th, 2011, 06:37 AM   #173
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
Looks like the stock dog bone. Take a pic of your installed rear sets, I'd like to see if we can't figure out what's going on here. Mine isn't even close to rubbing
warlord is offline   Reply With Quote
Old June 16th, 2011, 06:43 AM   #174
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
82. Just waiting on Paypal invoice.
Vampyre is offline   Reply With Quote
Old June 16th, 2011, 03:39 PM   #175
scotty
scotty's Avatar
Billy did you install them correctly? Only thing I can see that mght hit with these adjusters are the passanger foot pegs.
Old June 16th, 2011, 07:24 PM   #176
Dr Honda
Dr Honda's Avatar
Motorcycle(s): Buell XB12Ss, Victory Vegas, DRZ400, XR50
Hi Guys,
Thanks again for all the orders.
I noticed today that I still had 2 "Blem" rearset adjusters that haven't been paid for. So... I'm releasing them for sale. One person has already expressed interest in one (sale pending) so... there is one set left.
I am removing the blem code from my web site... so if you would like it... Please PM me.
I apologize if you were on the original list for a blem set... but it's been 2 weeks since they were made available.
Dr Honda is offline   Reply With Quote
Old June 16th, 2011, 07:40 PM   #177
Live2ride
Live2ride's Avatar
I considered this a dumb question but....did you install the rearsets on the inside (bike side) of the adjusters instead of the outside? That could be the reason why its rubbing.
Old June 19th, 2011, 01:10 AM   #178
infinitethrill
forever a n00b
I posted a photo install guide earlier in the thread. Here it is installed showing the gouge in the plastic where it was hitting.
Old June 19th, 2011, 03:50 AM   #179
dubojr1
dubojr1's Avatar
Billy: has your bike been dropped on the left side? I believe the mount points for the rear-sets have been known to bend. If they are bent inwards towards the swingarm, this may be why yours are hitting the chainguard. I guess the rear-set could possibly be bent too. Need to check both.
Last futzed with by dubojr1; June 19th, 2011 at 03:53 AM. Reason: Additional info added
Old June 19th, 2011, 07:18 PM   #180
Dr Honda
Dr Honda's Avatar
Originally Posted by Dr Honda View Post
Hi Guys,
Blem's are all gone.
Thanks guys.
Old June 20th, 2011, 12:12 AM   #181
infinitethrill
forever a n00b
I was able to yank real hard and bend it back. I dropped it earlier this year (the only damage that I knew of was a punched fairing. Had no idea it was bent. Everything else about them is fine then!
Old June 20th, 2011, 04:55 AM   #182
dubojr1
dubojr1's Avatar
Cool. I'm glad we were able to figure it out. Keep a look out for a used stock rear-set on here. They are available at reasonable prices pretty frequently.
Old June 20th, 2011, 06:42 AM   #183
MattRichling
I read this in bed last night and might have missed the answer to the question... Shipping to Ontario?
Thanks!
MattRichling is offline   Reply With Quote
Old June 20th, 2011, 07:09 AM   #184
Dr Honda
Dr Honda's Avatar
Thanks!
Shipping to Canada is $14, and takes 6 to 10 working days.
Old June 21st, 2011, 07:52 PM   #185
Jerkson
Motorcycle(s): Blue 2010 Kawasaki Ninja 250r
Remember: USPS shipments get transferred to Canada Post this side of the border. Canada Post is on strike...
Jerkson is offline   Reply With Quote
Old June 21st, 2011, 08:17 PM   #186
Vampyre
Vampyre's Avatar
Got mine and installed em. Absolutely perfect.
Old June 22nd, 2011, 06:52 AM   #187
Toly
Toly's Avatar
Motorcycle(s): KTM 390 Duke
Order #83 here
Toly is offline   Reply With Quote
Old June 22nd, 2011, 11:37 AM   #188
Jerkson
I thought I didnt have to re-use my stock shift rod. I Expected one of the threaded rods to be reverse-threaded for the front. Can someone take a head-on pic of how they assembled their rod?
Also, even with the rearsets in the "closest-to-stock" location there is a bit of a kink in the rear brake fluid line. How have you guys routed this line to avoid this?
Old June 22nd, 2011, 11:46 AM   #189
shiroganeshinobi
Motorcycle(s): 2010 250R SE
You do reuse, I made the same mistake. None of the screws would go into the front. Attach the extension nut to the shift rod and then pick the remaining screw according to length of where your peg will be and screw them in.
shiroganeshinobi is offline   Reply With Quote
Old June 22nd, 2011, 11:55 AM   #190
Live2ride
Live2ride's Avatar
I have mine in the furthest back position and have no kinking, all I did was push/pull the brake line through the little mount that holds the line on the undertail. The kinking went away after that.
Old June 22nd, 2011, 12:05 PM   #191
Jerkson
Yeah I figured that out already I was just under the impression that it was a full replacement.
I will go play with the brake feed line a bit then. Thanks for the tip
Old June 22nd, 2011, 10:55 PM   #192
vince_2149
vince_2149's Avatar
Motorcycle(s): 2012 Ninja 250
Received today and installed on my pregen tonight.
If anybody with an 07 or prior bike was interested in purchasing these, you can tell that they weren't made for the pregen due to a few issues on the rear brake side, but they still bolted up just fine after a few adjustments.
Thanks!
vince_2149 is offline   Reply With Quote
Old June 23rd, 2011, 06:27 AM   #193
Jerkson
After looking at my bike last evening, I think you're referring to the brake light signal wire that goes through a mount. I'm referring to the rear brake reservoir fluid line.
Old June 23rd, 2011, 06:02 PM   #194
Live2ride
Live2ride's Avatar
Your right.
Old June 24th, 2011, 02:57 PM   #195
MattRichling
Your order has been successfully processed!
Order number: 84
Old June 24th, 2011, 03:33 PM   #196
Bigballsofpaint
Order Number: 85
Now im just waiting for my paypal invoice
Old June 26th, 2011, 06:16 PM   #197
Dr Honda
Dr Honda's Avatar
Originally Posted by Bigballsofpaint View Post
Order Number: 85
I won't send paypal invoices, or charge credit cards until the parts are ready to ship. I'm hoping to have them back by Thursday.
Tony
Old June 27th, 2011, 12:40 PM   #198
yujayn
yujayn's Avatar
Motorcycle(s): 2011 ninja 250r
order 88 here....
waiting for my invoice too....so excited..!!!!yeeeppiiee..
yujayn is offline   Reply With Quote
Old June 27th, 2011, 01:59 PM   #199
Bigballsofpaint
Sounds good, i just wanted to make sure i didnt do anything wrong
Old July 2nd, 2011, 02:57 AM   #200
Dr Honda
Dr Honda's Avatar
Hi Guys,
The Parts got finished, and I got them back from the anodizer yesterday evening. SO... for all the people who just ordered parts... I will get them packed, and shipped out on Tuesday. (Monday is a holiday)
I will get the paypal invoices out later tonight or tomorrow.
Thanks for all the orders guys.
Tony
A&L Motorsports rearset adjusters Dr Honda Motorcycle-related 14 January 31st, 2015 04:55 PM
FS: A&L Rearset adjusters jp129 Motorcycle-related 3 June 29th, 2012 11:02 AM
FS: A&L Rearset Adjusters - Brand New Toly Motorcycle-related 6 May 21st, 2012 09:18 AM
installed A&L Motorsports rearset adjusters. The Good & Bad CThunder-blue 2008 - 2012 Ninja 250R Tech Talk 21 May 28th, 2011 03:17 AM
A&L motorsports rearset adjusters? CThunder-blue 2008 - 2012 Ninja 250R Farkles 12 March 16th, 2011 02:45 PM
