Old August 17th, 2010, 09:22 PM   #1
sofo
sofo's Avatar
Got handlebar vibrations?
Try the vibranator!
The bar-end weight plus vibranator version looks particularly interesting for Woodcraft clip-on users.
sofo is offline   Reply With Quote
Old August 18th, 2010, 01:12 AM   #2
can someone please explain to me why bar ends are so frickin' expensive??? doesn't look like much to make a set of those.
Old August 18th, 2010, 02:16 AM   #3
edbro
Motorcycle(s): 2009 250r
$110
edbro is offline   Reply With Quote
Old August 18th, 2010, 07:12 AM   #4
Talonne
Talonne's Avatar
Motorcycle(s): '09 Metallic Diablo Black
Insane.
Talonne is offline   Reply With Quote
Old August 18th, 2010, 07:34 AM   #5
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
percision
Old August 18th, 2010, 09:32 AM   #6
sofo
sofo's Avatar
Ok guys, take a couple of deep breaths and keep in mind there is a lot more going on inside these things than just a couple of bits of machined bits of metal. These are primarily a device to counteract vibration, not just dead weight bolted inside of or on the ends of your handlebars.
Kelly, can you lathe up a few sets of these cheaper and as well-made? If so I'll pre-order some from you instead of these guys.
Last futzed with by sofo; August 18th, 2010 at 09:33 AM. Reason: typos
Old August 18th, 2010, 10:18 AM   #7
bdavison
Wartown, USA
bdavison's Avatar
As someone who owns a metal lathe, and a milling machine....
There is no reason they are expensive other than greed. Those things are so easy to make its not even funny. Its a round piece of bar stock, a screw, washers, and a rubber cork. The lathe time is a matter of minutes on a manual lathe.
Old August 18th, 2010, 10:50 AM   #8
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
Technically speaking, it is dead weight. That's how they counter-act vibration...with their dead-weighted-ness.
That said some of the are very very pretty, but ludicriously expensive. Sure there may be some finer details in how they fasten themselves to the clip-ons, etc....but greed or low production numbers is usually what I attribute to some of the costs being so high.
Old August 18th, 2010, 10:59 AM   #9
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Why do folks pay large amounts of money to buy what is essentially $2 worth of paint applied to a $4 canvas stretched over $1 worth of wood?
Old August 18th, 2010, 11:03 AM   #10
um... to stick on the end of their handlebars?
Old August 18th, 2010, 11:30 AM   #11
sofo
sofo's Avatar
Did any of you actually read the details of what this does before jumping on the bash the expensive bar-end bandwagon?
Old August 18th, 2010, 11:41 AM   #12
well, I did, but I don't suffer an unmanageable amount of vibration with the set of stock bar weights I fitted to the WC clipons I have.
My original comment was not only directed at your posted weights, but to all weights that I found when I was researching bar weights before I figured out how to fit the stock weights back onto the bike.... for virtually free.
if these float your boat, buy them and let us know how they work.
Old August 18th, 2010, 11:44 AM   #13
sofo
sofo's Avatar
Fair enough but I think to lump these in with expensive bling weights like Rizoma and Yoshimura is a little inaccurate.
Lesson learned about sharing with the community on my part though.
Old August 18th, 2010, 12:04 PM   #14
Flashmonkey
To be perfectly fair, I didn't click on the link initially.
Although, looking at it, and using my wonderful e-detective skills and whatever engineering related knowledge I've retained from university, I can probably say that these will work on the exact same principles as the blinged out Rizoma stuff, in that it is just an extra piece of weight attached to the bar to change it's resonant frequency. Will it be more effective? Well that's hard to determine because the vibration on any particular motorcycle will tend to be somewhat unique to that motorcycle....of course depending on the source of the vibration (whether ingrained in the actual design of the bike as a by-product of something, or as a result of the wear of a component, or the street/context of the environment the bike is being ridden in). Vibration is weird like that, and is very difficult to counter-engineer, even when you have the full might of an OEM R&D department behind you.
With that said, the reason I'd buy these over a set of Rizoma's is because they've actually put some thought behind the design, and not just fancied up a piece of scrap metal with anodization and fancy print. The though alone is worth the extra money...but in the end...as long as it works who the hell cares really.
And don't let some negative comments deter you from making posts like this. This is yet another option available to this community that we are now aware of thanks to your efforts.
Old August 18th, 2010, 12:09 PM   #15
They got a decent writeup and recommendation in Motorcycle Consumer News this month, (the vibranator), based on feedback from someone who tried them on a VFR if I remember correctly.
Old August 18th, 2010, 09:14 PM   #16
Ninja North
Motorcycle(s): 2008 Ninja 250R (FI)
I haven't tried this myself, but I heard that bar-ends for er-6n/er-6f are heavier than ours, and they do fit. I'd imagine they are cheaper.
Ninja North is offline   Reply With Quote
[motorcycle.com] - MV Agusta Brutale California with um Wood Vibrations Ninjette Newsbot Motorcycling News 0 October 4th, 2013 01:40 PM
Strange Vibrations on 5G at 7K RPM abhisaxe 2008 - 2012 Ninja 250R Tech Talk 3 March 30th, 2013 09:13 AM
HELP: Heavy vibrations! sixstring 2008 - 2012 Ninja 250R Tech Talk 16 April 16th, 2010 03:10 PM
Vibrations in screen and left footpeg karlosdajackal 2008 - 2012 Ninja 250R Tech Talk 1 February 1st, 2010 06:20 AM
Vibrations in handlebar - Ninja 250's 250fan General Motorcycling Discussion 24 October 15th, 2009 06:42 PM
