April 2nd, 2020, 01:06 PM | #1 |
Join Date: Jun 2019 Motorcycle(s): Suzuki bandit 1200 Ninja 250 Posts: 60
Pre-gen front turn signal hack
If your fronts are bashed or crashed or you just want to minimize... I've used this hack many times... less than $10 easy
Need: *Pair of "eBay" universal signals *old flat auto license plate (not stamped raised numbers---smooth style) *4 small bolts/washers/nuts *rattle can satin black spray paint *tin snips/scissors *Drill and couple correct size bits Make a paper or cardboard template-- it will same for both sides but inverse... Mark holes for plate bolts and signal hole/backing bolt from inside with sharpie Cut, drill, paint....install! Pics pretty obvious... ***very sturdy and cheap-- done it a dozen times. |
April 2nd, 2020, 01:08 PM | #2 |
Get as careful as fancy as you'd like...
I've also used thick plastic or pieces of old fairing to do same project and color matched it to bike... |
April 2nd, 2020, 01:38 PM | #3 |
Also to put a new and nearly free "male" end on your ebay signals that are just single or stranded wire...(if you dont have any of the fancy cool squeeze on kind laying aroud...) you can use an appropriately sized cotter pin...
nip it short Spread it slightly to pinch wires in there SOLDER IT!!! heat shrink wrap then squeeze it with needle nose to get it right size to go fit snug in "female" end of your bike's OEM turn signal harness and plug it in...! |
April 2nd, 2020, 08:34 PM | #4 |
Very innovative! Thanks for tip!
May 8th, 2020, 01:06 PM | #5 |
Join Date: Apr 2014 Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles Posts: 98
Very innovative. I used a 3d printer to make the mounting plates you show here. All do the same job, although long term I like your way.
Left side Pre-gen turn signal... | ninja2007 | Items Wanted | 4 | September 30th, 2014 03:31 PM |
Fitting a new gen front wheel on a pre gen? | thumper64 | 1986 - 2007 Ninja 250R Tech Talk | 13 | November 6th, 2013 02:44 PM |
FS: Cheap Pre-Gen Front Turn Signals | GlassAnkles | Motorcycle-related | 2 | March 19th, 2013 10:20 AM |
WTB Pre-Gen Front Turn Signals | Pure Lunacy | Items Wanted | 5 | January 23rd, 2012 05:23 AM |
Pre-gen front turn signals | CmichRider | Items Wanted | 1 | May 30th, 2011 07:36 PM |
