July 2nd, 2016, 11:41 AM | #1 |
New To This
Join Date: Jun 2016 Motorcycle(s): 2012 Ninja 250R Posts: 5
I Done Messed Up
I removed the front fairing mount via hacksaw this morning and think I may have messed up bad. As I finished sawing through the metal, my hacksaw slipped and cut my ignition wiring slightly, there were some sparks but it didn't actually seem that bad. That is, until I tried to turn the bike on. When I turned the key to the 'On' position, nothing happened - there doesn't seem to be any power running through my bike. Here are some pictures:
I'm not really sure where to go from here. Did I completely fry the electrical system on my bike? Did I destroy my ignition? Do I just need to replace my ignition wiring? Did I blow a fuse? Is blowing a fuse a thing? I would be grateful for any help! -Scott |
July 2nd, 2016, 12:00 PM | #2 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Doesn't look like you cut the wires, only the shithing. Based on the attached images, my browser currently has other images blocked.
Spoiler for topic:
July 2nd, 2016, 12:01 PM | #3 |
Check the main fuse. 30am if I remember right.
July 2nd, 2016, 12:20 PM | #4 |
New To This
July 2nd, 2016, 12:21 PM | #5 |
Agreed check the main fuse 30A it should be located on the starter solenoid IIRC not up on the NewGen.
July 2nd, 2016, 12:30 PM | #6 |
Be sure to wrap electrical tape around the wires you nicked.
July 2nd, 2016, 12:31 PM | #7 |
Good call
July 2nd, 2016, 12:33 PM | #8 |
Thanks. ^^^^^^
July 2nd, 2016, 04:58 PM | #9 |
New To This
Okay, it WAS a blown fuse! Now it's fixed! I can't thank you enough!
This place is so awesome. |
July 2nd, 2016, 06:02 PM | #10 |
I strongly suggest carrying a few spare fuses, 30A & 10A. I personally use the Bussmann easyID Illuminating Blade Fuses, when the fuse is blown, it lights up, making it easy to find the bad one, especially at night on the side of a dark road. My post about them, https://www.ninjette.org/forums/show...postcount=7145 Bussmann VP/ATC-10ID easyID Illuminating Blade Fuse, (Pack of 10) https://www.amazon.com/dp/B004AH6O9A..._GngExbR4DR8JS Bussmann VP/ATC-30ID easyID Illuminating Blade Fuse, (Pack of 10) https://www.amazon.com/dp/B004AH8NF8..._6ogExbPQK5EY4
July 2nd, 2016, 08:18 PM | #11 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Tak tsk! Nobody mentioned to the OP to carefully tape up the exposed wire(s)?
For two reasons: - To prevent them shorting on the frame or whatever. - To inhibit corrosion of the exposed wiring! Now having wagged my finger; I'll go back and check the suggestion was not already made! Edit: Darn you @Snake! Lol! I should say good on you, Snake!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
I got messed up | modded | !%@*#$%!)@#&!%@ I crashed! | 32 | August 16th, 2013 09:49 PM |
I messed up...how would you have taken this turn? | watsyurface | Riding Skills | 46 | March 20th, 2013 03:45 PM |
This is messed up | Apex | Off-Topic | 6 | January 20th, 2013 12:49 AM |
Messed up diaphragm | THE BIG SITT | Motorcycle-related | 0 | May 30th, 2012 05:25 PM |
I think i really messed up.... | illrational | 2008 - 2012 Ninja 250R Tech Talk | 20 | September 2nd, 2010 05:56 PM |
