March 5th, 2020, 10:05 PM | #1 |
idle @ 7k when choke is on - Fixed
So i did a full tear down, clean and inspection of the carbs. I still have the same problem. When my choke is wide open the bike revs to 7k. If i reduce the choke the engines stalls.
Once warm it idles at 1500 Any ideas why the rpm is so high?
Last futzed with by woodchipliz; March 6th, 2020 at 02:19 PM. |
March 6th, 2020, 07:38 AM | #2 |
Can you just back it down enough to get the RPMs about 2500?
It's an enrichener, so raising the RPMs is common. Once it starts I always set it so it will keep running at a moderate RPM, usually in the 2500 range, until I get my gear on and take off. At that point it will usually idle (barely) with the choke off. |
March 6th, 2020, 02:18 PM | #3 |
Fixed it. Choke rpm is now 4 - 5 K
March 6th, 2020, 04:18 PM | #4 |
March 7th, 2020, 11:24 AM | #5 |
in my case i noticed that the right butterfly was opened more than the left one, so i bench sync the carbs and that fixed it
Bike not idling below half choke, idle screw not affecting idle speed | Zaraki_Kenpachi | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 6th, 2020 11:13 AM |
Dying at idle with choke off | jonnybravo9 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 2nd, 2014 09:17 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Choke has no effect on idle... Help. | Jono | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 14th, 2011 09:45 PM |
Choke Idle Speed has Changed | patw | 2008 - 2012 Ninja 250R Tech Talk | 21 | August 1st, 2010 10:27 PM |
