Old April 21st, 2018, 09:40 AM   #41
Originally Posted by Tylorwashere View Post
Yeah sorry about the uploading thing, I tried using the button but I don't think it likes me doing it from my phone or something. Those are 92027 and 92027a, I was showing them to show that they were there. I haven't gotten the hub apart, but from the exploded view and what I can see from looking into it, it's all there. ( the bearings have no play, dust covers are there, etc.
Your 92027 spacer has a pocket opening on one side. When installing, does this opening side face the wheel or the swingarm?
Old April 21st, 2018, 04:35 PM   #42
Tylorwashere
Motorcycle(s): 2005 Ninja 250
So for anyone interested, I'm not sure if this actually fixed it or I just happened to put it together right this time, but I loosened up the bracket that holds the brake caliper in place, because I noticed it seemed to make the axle bind up when i put it through without the tire on. So after it was all put back together i tightened it up where it was with the axle through and the tire straight, and it's fine now.
Tylorwashere is offline   Reply With Quote
Old April 21st, 2018, 07:49 PM   #43
I'm still not following exactly how this could happen.
If the outside wheel bearings are in-place the axle should be running through the center of the wheel. And if the swingarm isn't bent...
Waiting for someone to solve the mystery.
Old April 21st, 2018, 10:15 PM   #44
Also not sure how rear brake can affect positioning of rear axle and wheel.
Old April 22nd, 2018, 04:12 AM   #45
Tylorwashere
The axle runs through part of the bracket that holds it
Old April 22nd, 2018, 09:06 AM   #46
Notice that there's only one way the brake bracket can fit on axle, no adjustment possible.
The only thing that makes sense is you got spacer 92027A reversed. Then it would cause:
1. Wheel to stop spinning, because spacer flange would squeeze seal instead of pressing on brake caliper bracket
2. Only way for wheel to spin would be for axle-nut to be really loose, thus wheel would wobble
3. Wheel would sit further to left
4. In order for brake disc to fit, wheel would lean to right
5. Under braking, wheel wobble would cause bike to wiggle in different directions like snake
You need to replace seal 92049, it's most likely damaged. This will allow dirt in and damage wheel bearing quickly and need replacing in less than a couple months.
Old April 22nd, 2018, 09:35 AM   #47
Tylorwashere
Notice that there's only one way the brake bracket can fit. What part did you loosen and adjust?
1. Wheel to stop spinning, because space flange would squeeze seal instead of pressing on brake caliper bracket
2. Wheel would sit further to left
3. In order for brake disc to fit, wheel would lean to right
4. Under load, wheel would wobble due to loose torque needed to allow wheel to spin
Bracket 43034 bolts into an arm at the top, i loosened that bolt
Old April 22nd, 2018, 09:57 AM   #48
That rear torque arm follows whatever lateral position brake caliper bracket is in. Remove bolt completely and you'll see it can't exert any lateral force since it's very loose sideways. It's only function is to locate the caliper fore & aft. I hope you tightened that bolt back down, it shouldn't be loose.
Take a photo of your rear axle like this. Seal to left of screwdriver tip is most likely damaged and needs replacement.
Last futzed with by DannoXYZ; April 22nd, 2018 at 01:29 PM.
Wider tire in the back? salcuta88 2008 - 2012 Ninja 250R Tech Talk 34 October 4th, 2014 02:11 PM
Kissed someones back bumper with my front tire this morning YORCHI !%@*#$%!)@#&!%@ I crashed! 11 November 23rd, 2012 05:50 PM
Quick stop and felt the bike tire start to fishtail back and forth Hitman General Motorcycling Discussion 23 June 20th, 2011 06:22 AM
Different front and back tire. good idea or not? sudapuff 1986 - 2007 Ninja 250R Tech Talk 0 October 26th, 2010 12:35 AM
[roadracingworld.com] - Bridgestone Looks Back On First Season As MotoGP Control Tire Ninjette Newsbot Motorcycling News 0 November 25th, 2009 09:22 AM
