Old July 12th, 2012, 10:02 AM   #1
surlistyc
Motorcycle(s): 2003 kawasaki ex250
Lost all power out of nowhere
I was riding last night back from a friends house. I backed it up under my car port and as soon as I put the kickstand down, everything just shut off, dash/engine/lights. I figured it was a fuse. I checked them all, I think even including the master (20 amp?) I put the fairing back on and went to start it. it worked fine? This morning I tried to take it out, it started fine, but the tach was reading it was revving up to 12k but the engine definitely didn't sound like it and the neutral light was flickering, so I turned off the bike. now it won't come back on again? I am so completely lost as to what this could be.
I measured the battery, 12.5+ volts when not on. I also tested the (thing, not too sure what it is) with the 20 amp fuse in it. I got the same reading.
surlistyc is offline   Reply With Quote
Old July 12th, 2012, 10:20 AM   #2
DaBlue1
DaBlue1's Avatar
Check your neutral safety switch, stand switch and your battery connections.
Old July 12th, 2012, 10:27 AM   #3
Load the battery and try again.
Old July 12th, 2012, 10:28 AM   #4
surlistyc
Where would the neutral safety switch and stand switch be?
Old July 12th, 2012, 11:05 AM   #5
DaBlue1
DaBlue1's Avatar
The neutral safety switch is located behind the drive sprocket cover on the left side of the motorcycle. When the transmission is in neutral, the safety switch closes and completes a circuit to chassis ground (neutral lamp on dash is illuminated). When the transmission is out of neutral (in gear) the safety switch opens and the circuit is not completed.
The sidestand safety switch located at the sidestand pivot bracket on the left side of the motorcycle. When the sidestand is in the up (riding) position, the safety switch closes and completes a circuit to chassis ground. When the sidestand is down (parked) the safety switch opens and the circuit is not completed.
Old July 12th, 2012, 11:08 AM   #6
surlistyc
Thanks. Do 03's have the stand switch? I've heard about them, but I thought it was something that you mod, or on newer bikes.
Old July 12th, 2012, 11:55 AM   #7
All generations have a shutoff switch at the sidestand and clutch lever as a safety function. It stops you from using the bike in a way that could be unexpectedly out of control. (starting in gear and clutch released, or moving with the sidestand down)
The reason you hear of people modifying the sideatand switch is because racers tend to take off the sidestand and grind off the mount for not cornering clearance. They usually put a jumper across the switch to complete the circuit and fool the bike into thinking the stand is up and ok to ride even though it's no longer even there.
Posted via Mobile Device
Old July 12th, 2012, 01:08 PM   #8
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
My 2000 runs with the stand down. You can even take off with it down. I've never checked if it's there, but in the 2845 miles that others have owned it, the last owner being a girl that rode 140 miles over 3 years, I highly doubt anyone has modified it.
I'd suspect a loose ground.
dirty nasty is offline   Reply With Quote
Old July 12th, 2012, 01:28 PM   #9
surlistyc
Problem resolved. I really don't think mine has a stand switch either as I have newbishly taken off with the stand down. I caught it before I took any corners, but still a newb move.
Back story -
I bought this bike used with 25.5k miles. The guy who owned it before me had very obviously done a lot of DIY work, and has dropped it at least twice from what I can see. Well 2 days after I got the bike, it stopped working, mostly, it wanted to turn over but just couldn't. Found out the plugs were flooded. in the process of working on it, I knocked this blue wire loose. it didn't seem to connect to anything at all. eventually I found out, that blue wire was what kept the fan running. (When I turn on the ignition the fan automatically turns on) not too much of a problem, but I'm sure it's only supposed to turn on at a certain temp. There was another blue wire coming off of the cathode on the battery into a (power box?) where a few other wires plug into, and that is plugged into something else which feeds electricity to the components.
solution - I had the key turned so the ign is on, no power. I jiggled that damned blue wire and sure enough the fans and elec all come on.
Now to still figure out why my bike is still running so hot after removing the old CRUSTY, GUNKY coolant and replacing it.
Will drilling holes result in lost power? salcuta88 2008 - 2012 Ninja 250R Tech Talk 15 July 22nd, 2014 03:56 PM
Lost power while riding on twisty hills today. jackliu239 1986 - 2007 Ninja 250R Tech Talk 13 May 28th, 2014 04:08 AM
Lost power while, will start but will not idle spareparts329 1986 - 2007 Ninja 250R Tech Talk 28 August 28th, 2013 06:16 AM
'07 just lost power slnarcissist 1986 - 2007 Ninja 250R Tech Talk 6 May 31st, 2012 04:37 PM
lost power? possible causes. looking for advice. walty87 2008 - 2012 Ninja 250R Tech Talk 16 March 8th, 2012 11:17 AM
