Old September 29th, 2012, 12:51 PM   #1
BearZ
BearZ's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250R
Cool eBay Levers install instructions and review
I installed Ebay Clutch and Brake levers today, they were just under $50 with expedited shipping, which is still cheaper than ASV, Speed Metal or any other store brand ones. The quality is indiscernible from other, more expensive levers. I took a bunch of photos after installing, unfortunately it's raining here today so I haven't taken it for a spin yet, but I'll post installation instructions and initial thoughts, then do a full length review once I have been on the street with them.
Tips and pointers before installing:
The clutch is a little bit harder, brake is super easy. I did the clutch first, then the brake, that is what I recommend, you decide which way you want to do it.
You'll need:
Aftermarket/replacement levers
10mm socket wrench
a flat head screwdriver (I'll explain why)
Half hour of your time
2 hands
elbow grease
Removing the stock Clutch lever.
Take your 10mm socket wrench and start loosening the Bolt. Remember: Lefty-loosey. There is a lock nut at the bottom, make sure it doesn't fall off when loosening the bolt. Once you get it started, you should be able to just use your hands to take it off.
Loosen the adjuster for the clutch cable, you should be able to use your hands to do it, if not, use an adjustable wrench/spanner to get it started.
Gently nudge the clutch out, this might take a little bit of wiggling around depending on how well it's sitting in there. This is what i looks like once you're taken the clutch lever out.
Take the clutch wire out of the stock clutch lever, just twist and slide out.
Get your aftermarket/replacement lever ready
Put the clutch wire into the new lever, slide in and twist.
Gently slide the new Lever back into position, put the adjuster back into position and screw it in about half way. Line up the holes of the lever. Insert the Bolt back in and begin to tighten until it starts showing up on the bottom end, twist on the lock nut and tighten it down. Note: There isn't enough room where the lock nut goes to put an adjustable wrench, so I wedged a flat head screw driver there to prevent the lock nut from turning while I tightened the bolt.
Test the clutch. If it's too loose, LOOSEN the clutch wire adjuster until the clutch feels taught, then tighten the adjuster ring.
Voila!
Removing Brake lever
Using the same 10mm socket wrench, loosen the bolt, taking care that the lock nut does not fall off.
Gently pull on the lever and it will come right off, there are no wires or cables to worry about here.
Get the Aftermarket/replacement lever ready, line up with the holes and put the nut and bolt back in- tighten.
And, Done!
BearZ is offline   Reply With Quote
Old September 29th, 2012, 05:51 PM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Good instructional but the perch has to be replaced w/ another models' on the 1986-2007 models. What year is yours?
Old September 29th, 2012, 07:55 PM   #3
Thanks, but pics are way too big!
Old September 29th, 2012, 07:57 PM   #4
/moved to 2008-2012 farkles area
Old September 29th, 2012, 08:11 PM   #5
BearZ
BearZ's Avatar
Thanks for moving! My bad. I wish the site had auto resize
Old September 29th, 2012, 09:26 PM   #6
rawbert625
rawbert625's Avatar
Motorcycle(s): the cool ones
we can just hit Ctrl+scroll down. Apart from that, great DIY!
rawbert625 is offline   Reply With Quote
Old October 22nd, 2012, 05:24 PM   #7
Rawrcasm
Rawrcasm's Avatar
I've been searching around, but haven't come across the answer. What is the adjustable number dial on each lever for? You mentioned in order to adjust the clutch, to loosen/tighten the clutch wire adjuster.. so what are the dials for?
Rawrcasm is offline   Reply With Quote
Old October 22nd, 2012, 05:39 PM   #8
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
No, they adjust the position of the levers for a shorter/longer reach. They do not affect the cable adjustment, they just move the lever closer to the handgrip.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old October 22nd, 2012, 06:38 PM   #9
Rawrcasm
Rawrcasm's Avatar
Awesome, thank you!
Old October 22nd, 2012, 09:27 PM   #10
Holy huge pictures batman! Open them in paint and zoom out, then save and upload again.
Old October 22nd, 2012, 11:22 PM   #11
BearZ
BearZ's Avatar
Haha, paint, that's cute. I'm a graphic designer, I know very well how to resize images, I was just hoping ninjette would have auto-resize... No such luck though.
Old October 23rd, 2012, 06:26 AM   #12
I suggested paint because for resizing, it's so stupid-proof that anyone can use it; gotta remember that I don't know you past a username for the most part.
There was a thread in the forum information forum about auto-resizing pictures. I don't remember why it didn't get used, but I think it was something about not being compatible with the newer version of vbulletin or something like that.
Old October 23rd, 2012, 08:28 PM   #13
This forum auto-resizes attached images; it doesn't resize images that are linked to other sites. We might at some point, but there are impacts to doing so (on mobile devices, for animated pics, on older browsers, etc.)
Old October 24th, 2012, 06:32 AM   #14
loz944
loz944's Avatar
Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really)
good diy just like to add it may be wise to remove the clutch switch to prevent from damage
Be safe ride smart .....a dumb rider is a dead rider
loz944 is offline   Reply With Quote
Old October 24th, 2012, 07:38 AM   #15
BearZ
BearZ's Avatar
Clutch switch?
Old October 24th, 2012, 04:09 PM   #16
loz944
loz944's Avatar
the switch that prevents the bike starting in gear unless the clutch lever is pulled .
as seen on many threads here it can break easily when removing the clutch leaver.
Old October 26th, 2012, 07:47 AM   #17
BearZ
BearZ's Avatar
I haven't had any issues with it myself.
Old October 26th, 2012, 08:12 AM   #18
If you don't watch the plastic pin when installing the levers it is VERY easy to break. The starter will keep working in neutral unless you completely disconnect the switch.
Old October 26th, 2012, 08:55 AM   #19
BearZ
BearZ's Avatar
Yea, I was careful with the switch when I installed it. I read about it actually before I started working on it.
Old November 5th, 2012, 01:46 AM   #20
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
@BearZ do you have a link? I found a few different ones on ebay.
Kstorm21 is offline   Reply With Quote
Old November 13th, 2012, 09:22 AM   #21
BearZ
BearZ's Avatar
Here
Old November 13th, 2012, 03:29 PM   #22
Kstorm21
Kstorm21's Avatar
Does anyone know if the green ones from ebay match the 2009 SE 250 or is it more of the new green?
Old November 13th, 2012, 10:06 PM   #23
Levers? They aren't painted so of course they won't match. Do they really need to?
Old November 13th, 2012, 10:10 PM   #24
Kstorm21
Kstorm21's Avatar
I'd say it'll look a hell of a lot better if they did. I don't like when colors are a shade or two off from each other.
Old November 13th, 2012, 10:21 PM   #25
lc86
lc86's Avatar
Motorcycle(s): 2010 Ninja 250r (RIP)
I've actually ordered 2 green sets from them for my 2010 SE and to answer your question...both sets were slightly different shades of green I bought a replacement set because when I went down on my bike it scratched one of them (It didn't break it, but I wanted it to look pristine again so I bought another set). The original set was a little darker, the newer set actually matched a little better.
here is a pic of the original set
...and here is a pic of the newer set on my bike
lc86 is offline   Reply With Quote
Old November 13th, 2012, 10:47 PM   #26
Kstorm21
Kstorm21's Avatar
Thanks for the pics...I was thinking about getting the full green ones that's why I was wondering. I think it would be more obvious with the full lever green if it wasn't really close.
Old November 14th, 2012, 07:43 AM   #27
We've heard time and time again that they fade and fade fast. Also, the only way for them to match is if they are or look like they are painted. Anodized metals don't look painted and I doubt many would agree that they would look good if they did. They'd look like plastic!
DIY - eBay Steering damper install. psych0hans 2008 - 2012 Ninja 250R Tech Talk 27 May 22nd, 2017 07:21 PM
Review: Clutch & Brake Levers from the2wheel Ebay Store DaBlue1 2008 - 2012 Ninja 250R Farkles 123 January 11th, 2015 11:32 PM
Ninja 300 Ebay Smoked Double Bubble Windscreen Review, Unboxing, Removal, Install SON1C 2013 - 2017 Ninja 300 Farkles 5 September 18th, 2014 07:02 PM
Ninja 300 Ebay Rear Seat Cowl Review and How To Install - Stardust Pearl White SON1C 2013 - 2017 Ninja 300 Farkles 4 September 11th, 2014 08:06 PM
How to install Rear Spools on your Kawasaki Ninja 300 Motorcycle & eBay parts review! SON1C 2013 - 2017 Ninja 300 Tech Talk 14 June 27th, 2014 08:15 PM
