Old February 19th, 2010, 01:55 PM   #1
Keenan84
Keenan84's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition
Yoshi baffle
im just having trouble putting in the baffle on my yoshi. The black baffle end cap doesnt fit in the end of the muffler??? help!
Keenan84 is offline   Reply With Quote
Old February 19th, 2010, 02:50 PM   #2
Keenan84
Keenan84's Avatar
heres a couple pics. maybe i am doing something wrong?
Old February 19th, 2010, 03:07 PM   #3
randomwalk101
self wrencher
randomwalk101's Avatar
the little nut/screw needs to be removed then use a rubber hammer and gently tap it in, put the screw in to lock..
Old February 19th, 2010, 03:09 PM   #4
Keenan84
Keenan84's Avatar
the problem is that the opening seems JUST too small. and maybe not perfectly round. i think even with a hammer its going to be tough, but ill give it a try.
Old February 19th, 2010, 04:14 PM   #5
Keenan84
Keenan84's Avatar
soooo i tapped it in, but its just sliiiightly off center (the hole) and now its stuck. wd40 has not helped....its half sticking out still, so i can pull on it. but its not budging at all.
Danmoto GP can -- baffle drop in DanielObrien42 2008 - 2012 Ninja 250R Tech Talk 4 March 1st, 2015 02:05 PM
Exhaust collars/baffle plates/baffle caps? massacremasses General Motorcycling Discussion 3 June 7th, 2013 05:52 AM
How to Install Danmoto Baffle Liist 2008 - 2012 Ninja 250R Tech Talk 1 April 12th, 2013 01:31 PM
Danmoto to baffle or not to baffle... DailyRidden250R 2008 - 2012 Ninja 250R Tech Talk 29 November 20th, 2012 01:19 AM
baffle removal b_eastep 1986 - 2007 Ninja 250R Tech Talk 27 July 11th, 2009 09:43 PM
