Old June 29th, 2013, 08:21 PM   #1
akcalhoun
Motorcycle(s): 2013 honda shadow phantom
starter idle gear
i replaced my alternator cover to day and when i was re-installing it i noticed the starter idle gear could move in and out. is this supposed to be pushed in so that the teeth of it connect with the teeth of starter motor clutch gear? ive put the cover back on but havent put n the fluids and try to crank it. thx
akcalhoun is offline   Reply With Quote
Old June 29th, 2013, 08:32 PM   #2
tubarney
The engine cover will stop the sprocket from falling out of where it is supposed to be.
I'm not sure if it is possible to put the cover back on without the starter gear lining up with the grooves in the big sprocket(on crank) and the starter motor spindle gear thing.
Old June 29th, 2013, 08:33 PM   #3
tubarney
Last time I installed mine, the gear almost fell out when I was puttting the cover on. I did have it all lined up though so everything was good.
Old June 30th, 2013, 04:57 AM   #4
akcalhoun
here's a picture to explain better. when i took of the cover Blue was sticking out like it is in the pic. b4 i put cover back on i pushed back Blue so that its gears where in contact with Red's.
Old June 30th, 2013, 04:58 AM   #5
akcalhoun
if any could clarify that this is the correct orientation i'd much appreciate it. im hours away from putting in fluids and re-cranking and am gettin very paranoid.
Old June 30th, 2013, 06:59 AM   #6
tubarney
Yeah thats the correct way.
I'm pretty sure the engine cover keeps it from falling out of the grooves.
Old June 30th, 2013, 07:42 AM   #7
akcalhoun
ok i thought so. when i pulled alt cover off it moved forward to where it wasnt contacting the big gear behind the fly wheel. i pushed it back cuz it kinda seemed like it was suppossed to be in contact with it. was pretty sure thats how it went and made sense to me, but wanted a 2nd opinion.
Starter Relay/Starter Problem Time Mage 1986 - 2007 Ninja 250R Tech Talk 13 July 13th, 2012 05:02 AM
Hello starter oneway gear question jibberish71 1986 - 2007 Ninja 250R Tech Talk 8 May 7th, 2011 02:32 PM
