Notices
Old July 23rd, 2018, 07:33 AM   #1
Micah
Motorcycle(s): 01 Ninja 250r
Where can I find pistons?
I was riding my 2001 ninja 250r and the left cylinder stopped working, so I took the engine apart and saw a hole in the center of one of my pistons, no compression. I checked all the websites I can think of. Does anyone know where I can get standard size replacement pistons?
Posted via Mobile Device
Micah is offline   Reply With Quote
Old July 23rd, 2018, 07:36 AM   #2
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Well you could try Kawasaki
I think you should have a look at your mixture it seams the it could be too weak.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old July 23rd, 2018, 08:30 AM   #3
taz
taz's Avatar
MOTM - May '17
Wiseco 40062M06200 look these up you will for sure get farther
Old July 23rd, 2018, 08:58 AM   #4
Hi and Welcome!
Need to also completely disassemble carbs snd give them thorough cleaning and flossing. Hole in piston is most likely from lean AFR caused by clogged carbs. Without fixing actual cause, new pistons will soon have another hole in them.
Old July 23rd, 2018, 07:46 PM   #5
Micah
When we were taking the engine apart, we discovered the spark plug for that cylinder was loose, so we theorize that the plug was not grounded correctly, causing the spark to go to the piston. (The hole is in the dead center, shaped very similar to the end of the spark plug.) Trying to avoid having amother hole in a new piston, so an Ideas on what caused this are appreciated. We will go through the carb to see if things are as they should be.
Old July 24th, 2018, 09:20 AM   #6
Loose plug may rattle and damage threads, but won't hole a piston. It just doesn't have enough energy. Note that centre electrode to ground is still same distance, spark will jump exactly same way. Worst case scenario with loose plug, is it won't fire at all.
Only way to make hole in piston is extremely hot combustion many, many times with lean mixtures for minutes on end, tens of thousands of firings.
Old July 25th, 2018, 10:55 AM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
@Micah, I've got several old motors in various states of torn apart.
You want a used piston ( or whole motor?)
Old July 25th, 2018, 11:35 AM   #8
I'd probably get a used piston myself if I were just looking to get it running again.
As others have noted, whatever caused the damage need to be corrected before running it with the new piston installed.
What did the plug look like? All the valves look OK? Is the plug hole stripped?
Old July 25th, 2018, 03:12 PM   #9
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
If there is a plug shaped hole in the piston, I’d check you have the right plugs installed, sounds like th3 thread it too long & the piston hit the plug !
Old July 25th, 2018, 06:41 PM   #10
Pregen uses 12.7mm reach plugs and newgen has 19mm. If newgen plug was accidentally installed in pregen, it would hit and stop engine very first spin around. And/or punch hole right away. But I don't think starter has that much power. It would go >CLUNK< and stop.
Check cam-chain wear and tension along with cam timing.
Last futzed with by DannoXYZ; July 25th, 2018 at 09:33 PM.
250 Pistons fit in 300? sprinter 2013 - 2017 Ninja 300 Tech Talk 4 August 6th, 2013 08:40 AM
Movement of both pistons. Joule General Motorcycling Discussion 16 July 7th, 2012 12:49 PM
What pistons to use... ninja_thresh_hold 2008 - 2012 Ninja 250R Tech Talk 13 July 7th, 2012 02:18 AM
Help! Need opinions on pistons... Skippii 1986 - 2007 Ninja 250R Tech Talk 16 March 1st, 2012 02:17 PM
Brake caliper pistons JamesNZ 2008 - 2012 Ninja 250R Tech Talk 19 January 22nd, 2012 09:47 PM
