View Poll Results: Pick one... | |||
I've ridden a linked brake bike before... and I liked it ^_^ | 5 | 15.15% | |
I've ridden a linked brake bike before... and it wasn't right... wasn't right at all -_- | 1 | 3.03% | |
I'm not interested in riding a linked brake bike. | 14 | 42.42% | |
I'd love to ride a linked brake bike. | 6 | 18.18% | |
I am a linked brake bike. | 7 | 21.21% | |
Voters: 33. You may not vote on this poll |
Thread Tools |
April 23rd, 2012, 02:59 PM | #1 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Linked Brakes
I'm curious about this linked brakes thing that I've heard some bikes have. I think our benevolent overlord mentioned his new bike has linked brakes.
It sounds kinda sketchy to me. I like to have full control over my brakes so that I can intelligently pick the right ratio of front and rear braking for each specific scenario I encounter. Linked brakes would take away some of that control. Any of you have good or bad experience with bikes with linked brakes? I'm not planning on getting a linked brake bike, I'd just like to hear people's thoughts on them. @Alex: is it possible to disable the linked brakes on your bike using that mini, nasa, control-center built into your dash? |
April 23rd, 2012, 03:03 PM | #2 |
Join Date: Sep 2011 Motorcycle(s): 2011 Kawasaki Ninja 250r Posts: 169
Hopefully someone with a CBR 250 with the ABS will help you out Akima, they have the brakes like that. When I was looking for my bike and went to the stealership to check out the CBR the sales guy was really trying to push me to go with the ABS version because it had the brakes that did that. Not sure much about it though.
April 23rd, 2012, 03:06 PM | #3 |
a lot of scooters are linked. ive driven some older small bikes with linked brakes. if you are just cruising theres nothing wrong with them, and they help with brake life. but if you are doing anything remotely aggressive, they are kinda counter-productive IMO
April 23rd, 2012, 03:15 PM | #4 | |
Nooblet
MOTM - Oct '13
There's no real need for me to lane split over an area of ground where the surface is clearly dirty and covered in small stones, but sometimes I like too... and when I do, I want complete control over my brakes so that i can slow down using just the rear brake and still get a small amount of turning in. If the front brake was also applied when I pressed in the rear brake lever, that could easily cause the front wheel to loose traction and for me and my bike to land splat on the ground. |
April 23rd, 2012, 03:23 PM | #5 |
MOTM - Sep '18, Feb '16
I had a 2006 Honda VFR with link ABS brakes. I loved them on that bike. Bit on a race bike or even a street 250 I can live without them. When I tested my brakes on mud covered painted cement. I was shocked how quick the bike just stopped moving . That was from just snatching the front to feel the ABS kick in.
As for the linked part. It was nice to go into a turn and just push lightly on the rear brake and feel the whole (big fat pig of a bike ) slow down. I also rode an old BMW. Those felt clunky and I did not like them . The new Honda was seem less . On the Honda the rear and just part of the front brakes work from the rear pedal and the front is separate. Six front break pistons four outer work with the hand lever and the two center ones work off the rear. |
April 23rd, 2012, 03:41 PM | #6 | |
BMW has the linked system down pretty well at this point, and I'm a fan. I use the front lever exclusively, and it adds a smidge of rear without me worrying about it. The front is linked to the rear. But the rear is not linked to the front. In other words, if you use the brake pedal, that controls only the rear caliper, and has nothing to do with the front. In the early 2000's, there were a number of BMW models that were linked in both directions. There were a large number of zero-mph drops when someone drags the rear brake pedal for sharp slow turns, which then activated the front brake while the bars were turned, and thump, there it was. Once the 1200 series was released ('04 for GS, '05 for RT), the linking morphed into today's strategy.
April 23rd, 2012, 03:48 PM | #7 |
that sounds pretty nice. if you slam on the lever are you able to lock the rear at all?
April 23rd, 2012, 04:19 PM | #8 | |
If the same thing happens on a non-abs or simpler abs bike, with the rear in the air you can't turn into the corner anyway, and you'll likely let off the front brake completely once you realize what's happening, and re-enable the front brake quite a bit later than the computer is able to do automatically. But it's also smart enough to realize when the rear is bouncing off the ground for a sharp bump, and in that case it doesn't cut the front brake pressure for that microsecond. The first ABS systems on the F800 series had that behavior, so if you were coming to a quick stop on a bumpy road, it seemed to take longer than it should as it couldn't differentiate between those bumps and the rear lifting due to strong deceleration forces. The top end systems are very confidence inspiring. What it means is that no matter how slippery the road, no matter what the surface, I should never refrain from using as much brake as I feel I need to slow the bike down, knowing that I will not lose stability as long as I'm somewhere close to straight up and down. It's not magic, and if leaned over fully and you nail the brakes, bad things are going to happen at some point, it can't conjure up unlimited traction.
April 23rd, 2012, 09:00 PM | #10 |
time for a BMW S1000RR (assuming the same system is in place there?)
April 23rd, 2012, 10:05 PM | #11 |
The S1000RR has a great system, but it's a little different. That bike's different riding modes have some neat features when it comes to the ABS, with Race mode allowing ABS on the front wheel, while letting the back lock and slide at will if needed for adjusting cornering lines. I'd bet that it doesn't drop the front brake pressure when lifting the rear in that mode either, but you'd have to check a S1000RR board for the details.
April 23rd, 2012, 11:09 PM | #12 |
Nooblet
MOTM - Oct '13
Thanks for your input @Alex. The linked brakes on your ABS bike sound quite good on account of all the extra intelligence that goes into how much the other brake should be applied.
April 23rd, 2012, 11:11 PM | #13 |
Jigglin' your Jiglets
MOTM - Apr '13
I'm trying to find an article or review on the Ninja 1000's ABS system but I can't seem to find anything. I'm sure it's not as advanced as the BMW systems but I'd like to know if it is linked and the other features it offers. Maybe I'll drive down to the dealer in 3 months and see what they know. DEPRESSING
April 23rd, 2012, 11:16 PM | #14 |
I don't believe they are linked.
April 23rd, 2012, 11:21 PM | #16 |
MOTM - Apr '13
Well there was no real answer for me, like uh, I have no fackin clue would have been a good option
April 23rd, 2012, 11:23 PM | #17 |
MOTM - Apr '13
But does it have some of those other cool ABS features? Every article I find on it says "Oh and the ninja 1000 has ABS which is a cool feature"
Wow, thanks article, really helps me out here
April 23rd, 2012, 11:25 PM | #19 |
Nooblet
MOTM - Oct '13
Having ABS on your bike doesn't require that the bike has linked brakes. They are two separate technologies that sometimes interact (like on Alex's bike).
April 23rd, 2012, 11:34 PM | #20 |
MOTM - Apr '13
April 23rd, 2012, 11:35 PM | #21 |
MOTM - Apr '13
I know, but I can't find any information on the Ninja 1000s ABS so I wonder what kind of features it actually has
April 24th, 2012, 09:25 AM | #22 | |
I guess it really shouldn't surprise me considering cars like the M3, the R8, and the 911 Turbo |
April 24th, 2012, 12:30 PM | #23 |
TylersEM2
Stanced 02 Civic, Check! 08+ 250r, ...Not yet... |
April 24th, 2012, 01:26 PM | #24 |
I have them on the CBR600. Don't really even notice them. Though sometimes if i am slowing to a stop I might fiddle with the zipper on my jacket or some other distraction and just use the pedal to slow the bike.
April 24th, 2012, 01:27 PM | #25 |
Just can't buy one until they take them off sales hold. Supposedly connecting rods are coming apart due to a lose bolt (so far just the majority of opinions, even my tech friends hadn't heard as of saturday).
April 24th, 2012, 01:35 PM | #26 |
Not sure if this applies to the CBR250 but from Motorcycle.com re the 600 and 1000:
When the system sees that you’re really crushing the brake lever in a feverish attempt to stop, it will then apply a degree of rear brake based on a predetermined pressure value from the front, regardless of ABS activation. You could do this on a conventional system, but most riders don’t have the skill necessary to match the speed and precision of the electronic system. Applying some level of rear brake will cause the rear suspension to compress, thereby helping stabilize the chassis, achieving one of the primary goals of employing C-ABS on a supersport. When using the rear brake only, the ECM doesn’t bring the front brake into action until the rear brake is near the point of lock-up. This, says Farewell, is different than current linked systems that include the front brake much sooner. This allows a rider to use the rear brake much like a non-combined system. This could come in handy, for example, during sporty stints when the rider might use the rear for trail-braking. |
April 24th, 2012, 01:47 PM | #27 |
That sounds awesome. I wish my bike had that.
April 24th, 2012, 02:03 PM | #28 |
Nooblet
MOTM - Oct '13
I read Greg's last post and thought: that sounds scary! I don't think I could ride fast at all if I didn't feel like I was in complete control of my brakes. I was imagining all these scenarios where the brake system Greg described could cause me to crash or cause me to worry about using my brakes as much as I want to incase of invoking a linked brake and then crashing.
ABS sounds great to me. The idea of a computer automagically reducing my braking force if traction-loss is detected sounds purely positive to me. I can't imagine a scenario on the road where ABS would be undesirable (so long as it's a good ABS system). I'd love to have that on my bike. It's just the linked brake thing that seems sketchy to me. My government has attempted to impose throttle control systems on motorcyclists that would limit their acceleration and top speed. On a practical level: that concerns me for the same reasons the linked brakes concern me: there might be times when I expect my bike to perform one way, but the AI interferes and results in me crashing. Imagine suddenly realizing someone is about to pull out in front of you because they haven't seen you. They are very close to you before pulling out, so you don't feel like there is enough time to brake. You decide to accelerate as hard as possible to get in front of them. Imagine suddenly having a throttle-control system say: "I'm sorry THE PUTERS ARE TRYIN' TO KILL US!!!! I can imagine lots of scenarios where the linked brakes could cause similar types of accident. |
April 24th, 2012, 02:43 PM | #29 |
I thought the EU was trying to bring in the "safety features" that take control away from the rider, they're trying to get bikes off the roads at all costs, but know that if they ban them outright that brussels would be burnt to the ground in protest.
Between the age increases in their most recent driving licence directive, their attempts to push mandatory power limits, mandatory abs,electronic throttle override, diagnostics to see if non standard parts are in use, tried to ban any "racing parts" from road bikes, ever stricter emissions laws (commute in a car at rush hour takes an hour, on the bike it's 20 mins, to do the distance, but the bike has slightly higher emissions on a closed track with no traffic so a suit in brussels wants it banned) Continent was ripped apart by dictators, and now it sets up an unelected government that decides to do as it likes and force all countries to do as it says, it's just short of calling the boss furher Posted via Mobile Device |
April 24th, 2012, 03:02 PM | #30 | ||
Nooblet
MOTM - Oct '13
They claim they've been around for 40 years fighting government attempts to take away biker freedom. That pre-dates the EU's Quote:
May 9th, 2012, 12:29 AM | #31 |
Join Date: Aug 2010 Motorcycle(s): GPX250 + many others! Posts: 184
I owned a Guzzi with linked brakes, no ABS, no computer, just one front disc and the rear disc on the same (foot) brake circuit. A lot of the old Guzzi's had that. It was fine,no problem.
I wouldn't like to ride any bike that has computers or fancy electronic systems on the brakes. My mate Dave bought a brand new BMW four cylinder sportsbike last summer, (can't remember what model), on the way to work one morning, doing 90 in the outside lane of the motorway, the computer had a 'problem', and switched off the braking system. He managed to pull off safely and got the bike recovered back to the dealers who fixed it. I would have told them to shove it ! Perhaps next time I have a few minutes to spare at Brooklands, I'll take some pictures of the braking systems on the older bikes there. Many consist of bicycle type stirrup brakes - but are less effective |
May 9th, 2012, 01:03 AM | #32 |
Oh, and Akima, yes, MAG have been around for a long time, back in the days when pensioner Fred Hill used to regularly get sent to prison for not wearing a helmet, or paying the fines ! (Helmet law was '73 I think).
Linked brakes | theredsox | 2008 - 2012 Ninja 250R Tech Talk | 22 | May 29th, 2011 08:34 AM |
[motorcycle.com] - Hopkins linked to new MotoGP team | Ninjette Newsbot | Motorcycling News | 0 | January 15th, 2010 08:40 PM |
[visordown.com] - Doohan linked to second Vegas nightclub | Ninjette Newsbot | Motorcycling News | 0 | January 4th, 2010 02:50 PM |
[MotoGP News] - Rossi linked to Ferrari...again | Ninjette Newsbot | Motorcycling News | 0 | May 21st, 2009 09:00 AM |
[visordown.com] - Waldmann linked to MZ factory buyout | Ninjette Newsbot | Motorcycling News | 0 | March 18th, 2009 08:40 AM |
