Old May 18th, 2009, 03:33 PM   #1
hzrnbgy
hzrnbgy's Avatar
Motorcycle(s): 2009 Black Ninja 250R, 2004 Yellow Ninja 250R
high elevation commute
okay, here is my situation
im going to Maui this coming summer for an internship position at Maui Institute of Astronomy Haleakala Observatory. Highest peak is around ~8500' above sea level. Although i'll be working at the observatory, i'll be staying at the Kahului harbor near the shoreline 31 miles away. Ive never been to Maui but i'll assume 90% of the ride will be stretches of hwy across farmlands, mountain and unlit backroads.
Looking at the terrain maps from google, half of the trip will be the final ascent though mountain roads. Im just wondering if the ninja can handle such trip two ways on a daily basis. Im sure its going to be fun but i dont want to be in a position that i might end up with a dead ninja in the middle of nowhere.
Any special consideration that i should take to make the ninja more capable of scaling the 60 mile ride? Any help would be appreciated
hzrnbgy is offline   Reply With Quote
Old May 18th, 2009, 03:52 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
I'm sure Kelly, ninjabrewer, or komohana can give you some inside information.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 18th, 2009, 03:55 PM   #3
hzrnbgy
hzrnbgy's Avatar
and yeah, ill be listening to Linkin Park music along the way
Old May 18th, 2009, 05:01 PM   #4
are you sure you can take your own vehicle to work? Don't they provide some sort of ground transportation? That road can get pretty hairy... fog, rain, snow, ice, super high winds... have you done any research on this?
You'll be going from sea level to 8500'? I know they advise rejetting for anything above 4-5000 ft, I think. what's your jetting now?
Old May 18th, 2009, 06:25 PM   #5
hzrnbgy
hzrnbgy's Avatar
the only research ive done so far was the google contour maps
haven't done any real research yet as i just found out today. gonna check with some relatives on the island about the commute.
im worried too as i heard you gotta use smaller jets in higher elavation as the atmosphere is thin. im still using stock jets
Old May 18th, 2009, 07:20 PM   #6
yeah, but if you start from sea level, if you jet for altitude, you'll be lean at sea level. I'd say don't worry about it for now and see how the bike runs as it's set up now. If you're running stock jetting and you've put that aftermarket can on it, you're most likely running lean already, so at altitude it might be just fine. Ride it there first, then make changes according to what problems you encounter.
First commute to work Reyno2ac Ride Reports 13 June 14th, 2012 05:43 PM
[sportrider - latest stories] - Riding Skills Series: Camber And Elevation Ninjette Newsbot Motorcycling News 0 October 28th, 2011 05:30 PM
Dyno Jet Stage 2 Help. #Jets, Elevation? Bushmaster11B 2008 - 2012 Ninja 250R Tech Talk 15 April 14th, 2011 11:20 AM
What is your commute? tjkamper Ride Reports 10 September 16th, 2009 06:52 PM
Do I need to rejet for higher elevation this summer? Gbug General Motorcycling Discussion 3 May 12th, 2009 05:29 PM
