January 23rd, 2017, 02:51 PM | #1 |
[motorcycle.com] - Why Do OEMs Use Ball Bearings In Steering Heads?
Dear MOby, I have a very short question for Ask MO Anything. Why do motorcycle factories insist on using ball bearings for OEM steering-head fitment, when every mechanic I know will replace them with aftermarket tapered roller bearings once they wear out? Why not just use tapered rollers to begin with? Regards, Kelvin Lau Dear Mr. L, I remember when the first R1 came out in 1998, Yamaha told us it chose to use roller bearings because they provided better steering feel and feedback. Intuitively it’s hard to argue with that since there is less contact area between a ball bearing’s inner and outer races, and that was backed up by the fact that the R1 was the sweetest-handling literbike ever at the time. But we may have just been had: Our friend Brian Gillen, MV Agusta’s head engineer, tells us using ball bearings in the steering head does offer advantages regarding packaging, since they take up less space and also weigh less. But in most cases, he says, the choice is primarily cost; tapered roller bearings can cost over twice as much as ball bearings. The big advantage to tapered rollers is that they last much longer, thanks simply to the fact that the load is spread over much greater surface area – among other things which require more knowledge than Ask MO can bring to bear. All I know is, 20,000 miles or so later, the ball-bearing ones in my 2000 R1 are shot. Compare this tapered roller bearing to the ball bearing in the lead image. SKF says: “Tapered roller bearings have tapered inner and outer ring raceways and tapered rollers. They are designed to accommodate combined loads, i.e. simultaneously acting radial and axial loads. The projection lines of the raceways meet at a common point on the bearing axis to provide true rolling and low friction. The axial load carrying capacity of tapered roller bearings increases with increasing contact angle ?.” And after that it gets complicated, okay? Keeping your bike’s steering head bearings properly lubed and adjusted will go a long way toward maximizing their lifespan, especially if it has ball bearings, but it’s a thing plenty of people ignore. If you can waggle the front wheel around when somebody raises it off the ground for you with the kickstand (or if you have a front-end stand even better), even if just a millimeter or two, you’ve really probably already waited too long. Chris Redpath of MotoGP Werks tells us if a bike with its original bearings has reached that stage, he’ll usually just replace the ball bearings with tapered rollers. If you try to replace them yourself, be sure and follow instructions and/or the manual when it’s time to tighten things up, because if your bike is anything like my old R1, the tightening procedure isn’t what you’d (I’d) expect: The two locking ring nuts, under the upper triple clamp that look like what you should really tighten, are supposed to be torqued to just 20 ft-lb and 6.5 lb-ft (lower and upper). It’s the steering stem nut, on top of the upper clamp (the one idiots scratch all up by carrying 15 keys on their keychain) that needs to be torqued to a bicep-rippling 85 lb-ft on my bike. Yo, where’s my 36mm socket? PS: No bike manufacturer makes its own bearings; they nearly all come from outside suppliers. If you have time to take your bike apart and get the old ones out, and if you’re lucky enough to have a bearing supply store in the neighborhood (they’re all over) with a nice person behind the counter armed with a micrometer, you can save substantial cash by going straight to the source. Direct your motorcycle-related questions to AskMoAnything@motorcycle.com, though some say we’re better at non-motorcycle-related ones… Why Do OEMs Use Ball Bearings In Steering Heads? appeared first on Motorcycle.com. Click here for full story...
Ball Bearings | Flying | Videos | 4 | December 4th, 2016 01:48 PM |
[motorcyclistonline] - MC Garage Video: How to Lube Motorcycle Steering Head Bearings | Ninjette Newsbot | Motorcycling News | 0 | July 18th, 2016 10:50 AM |
How ball bearings are made | Motofool | General Motorcycling Discussion | 5 | June 6th, 2016 06:49 AM |
Who Says Tapered Steering Head Bearings Are Best? | tgold | General Motorcycling Discussion | 27 | February 25th, 2016 02:33 PM |
Steering stem bearings- Grease or no? | MrSavvy | 2008 - 2012 Ninja 250R Tech Talk | 12 | June 10th, 2014 07:06 PM |
