June 28th, 2010, 03:04 PM | #1 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Clutch cable ever broken on a ride?
Hey all. Out of curiosity, has anyone here ever had your clutch cable break while riding? I know how to clutchless upshift (though I do tend to hit more false neutrals this way than upshifting w/ the clutch...I'm not snicking up hard enough I guess), but I don't know how to clutchless downshift. What do you do if the clutch DOES break while you're riding, in say, 5th gear? Thanks a ton! Ally
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
June 28th, 2010, 03:08 PM | #2 |
ridden dirt bikes without operable clutch cables. it is possible to shift up and down w/o the using the clutch. starting off is the bitch.
June 28th, 2010, 03:16 PM | #3 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Ive had a clutch cable snap during a ride....Just dont stop...if you do you are done. Upshifts are no problem, but downshifts are tricky. Gotta get it way down in the bottom of the gear before you tap it down. Take the backroads so you can california stop the stop signs....traffic lights will shut you down.
And when you get home...you gotta hit the kill switch to shut it off right as you pull into the driveway. Its not fun, but it can be done. Unfortunatly my clutch cable was defective, and the end pulled off, so before everyone harasses me for "proper maintenance"....dont. |
June 28th, 2010, 03:41 PM | #4 | |
(I don't think I've ever looked at my clutch cable, probably not a bad idea for me to take a peek at it at some point)
June 28th, 2010, 03:49 PM | #5 |
June 28th, 2010, 03:55 PM | #6 |
I had the strangest problem on a Suzuki Bandit a number of years ago. Something went haywire in the wiring loom, so anytime I pulled the clutch lever in, the starter motor went on. I had to ride it to the dealership, trying to use the clutch as little as possible, up or down, so I wouldn't burn out the starter motor, or hurt any of that starter mechanism either.
The main harness had somehow found itself in conflict with the steering head and got scrunched together, and two of the wires that controlled those functions (clutch interlock, starter motor), somehow got themselves in electrical contact. The shop thought that there was going to be all kinds of weird problems with the bike based on the symptoms, but once they found where the problem was, turned out to be an easy fix.
June 28th, 2010, 04:55 PM | #7 |
Actually took a good look at the clutch end of my clutch cable two days ago and it's showing some significant wear right where it enters the semi-rigid guide sleeve. Like the cable braid has been worn down such that it looks like a single segmented cylinder instead of the multiple steel braids. That said, I've gotten more than the usual amount of trash down there because my boot disintegrated a long time ago (doesn't seem to be sold individually) and, somewhat shamefully, I haven't cleaned it after every off-road trip but I have kept it lubed more than scheduled. Think I'm gonna go order a new one before it fails on me...
Sounds like one wacky wiring failure Alex. Mildly surprised you didn't blow a fuse or two.
June 28th, 2010, 06:20 PM | #8 | |
hope this helps --alex
June 28th, 2010, 10:45 PM | #9 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Has happened twice to me. 1st time I had no clue what to do, but ended up figuring out to start it, take off, and ride it without the clutch. All you have to do is start it up, let it stall, start it up again and at the same time give it some throttle and she'll be right. 2nd time, happened when I filtered in front a MASSSIVE truck at a red light, light turns green, SNAP -- the cable goes. Pushed it to the side, did the same thing, rode it to a mechanic. As for red lights, just stall it, when it turns green start it up with throttle and away you go. Rinse and repeat.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
June 28th, 2010, 10:48 PM | #10 |
June 28th, 2010, 11:28 PM | #11 |
I'm lovin' it.
Well the first time it snapped, I had no idea what could have happened, I guess it was a defective cable maybe? The second time was because the mechanic I went to said he could fix it without a replacement cable, he soldered the little nipple down the bottom back on. Or it might have even been me, I use to adjust the clutch so that I would barely have to move it at all, it was just within the recommended specs.
Clutch cable | Linkin | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 28th, 2015 03:29 AM |
Broken throttle cable | Ninja Rob | 1986 - 2007 Ninja 250R Tech Talk | 12 | January 23rd, 2015 10:07 AM |
clutch cable | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 27th, 2013 10:20 AM |
Clutch Cable | atomicrm | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 17th, 2011 12:22 PM |
Fine throttle cable adjustment assembly broken. | setasai | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 18th, 2011 09:10 PM |
