Old October 31st, 2017, 11:33 PM   #1
babyninja1968
Motorcycle(s): lotts
new to me 89 and no key...where ?
just picked up a sweet 89 and came with no key, no title, no miles, (well hardly any mikes) where do I get a key ?
babyninja1968 is offline   Reply With Quote
Old October 31st, 2017, 11:40 PM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Any decent locksmith can cut a key directly from the ignition.
My Ninja 300
Old November 1st, 2017, 12:03 AM   #3
babyninja1968
keysel
Thanx ! I guess gonna bring ig. switch with me into town, ....whats commonly needing attention other than the usual sitting bike issues ?...anything particular to the ex250 should be aware of ? thanx
Old November 1st, 2017, 06:57 AM   #4
What are your plans for it?
Without a Title it's a parts or race bike. You might be able to get a Title issued, but I wouldn't put too much time/money/effort into it until you know for sure.
Just a thought.
Old November 1st, 2017, 07:45 AM   #5
A quick search makes it look like CA is similar to NC as far as titling an untitled vehicle. You can get a bonded title, but need to have a bill of sale to show you own the motorcycle. I trust you got that, or can get that.
Here I titled an untitled motorcycle that was given to me, with a little paperwork, an inspection (inspector came to my house) and a title bond, which cost me $100. It took me three days from starting the process to walking out of the local DMV with a registration and license plate. Three years have passed, so the bond is expired and I now have a clear title.
Old November 1st, 2017, 08:02 AM   #6
babyninja1968
Originally Posted by jkv45 View Post
What are your plans for it ?
Just a thought.
Going to get a title for it and get it on the road...its so clean, I cant wait to ride it, it will be a labor of love for sure, will post pics of the progress
Old November 4th, 2017, 12:22 PM   #7
babyninja1968
gonna be fun removing the ignition switch....maybe I should just remove the gas tank lock and take that to the locksmith, the helmet lock is in lock position so I cant get a screwdriver on it to remove it and take it to the locksmith
Old November 4th, 2017, 12:51 PM   #8
I wonder how many different keys there were for 250s. Even though there are thousands of possibilities, sometimes there are only a dozen or two actually used. If someone stocked them, you could just try keys until one worked.
Old November 4th, 2017, 01:37 PM   #9
Look underneath and around helmet lock cylinder. There should be a codr there that locksmith can use to make key
Old November 4th, 2017, 01:40 PM   #10
babyninja1968
they use one key for everything on these bikes right ? so if I removed the fuel cap/inlet and brought that to the locksmith, might be the easiest way ? or is the ignition switch easier to remove ? read somewhere that the screws on ig. switch need to be drilled ?
Old November 4th, 2017, 02:04 PM   #11
tfkrocks
tfkrocks's Avatar
No that won't work, the gas tank only uses the tip of the key, not the whole key. And yes the ignition typically has security screws on there so they have to be drilled.
My Ninja 300
Old November 4th, 2017, 02:20 PM   #12
Only remove the ignition as a last resort. That code should be easily visible, and many kawi dealers and/or locksmiths can get a key from the code directly.
Old November 4th, 2017, 02:38 PM   #13
babyninja1968
Cool, thank you, I will try that on the helmet lock, hopefully I can see something underneath it hopefully it's not behind it because I can't get it off because the pins in the way of the screw
Old November 4th, 2017, 02:49 PM   #14
Some people have said you can use a mirror-on-a-stick to look at the helmet-lock cylinder for code.
Old November 4th, 2017, 02:52 PM   #15
babyninja1968
Right on, thank you so much
Old November 4th, 2017, 02:55 PM   #16
babyninja1968
Not yet I just gave it a bath today and we'll get some pictures as soon as I can it's not as clean as I was hoping it to be but it's still pretty darn nice for 1988 which it turns out to be
Old November 4th, 2017, 07:13 PM   #17
Here's more info than you'll ever want to know about keys. And also how to release seat without key.
https://www.ninjette.org/forums/showthread.php?t=170793
https://www.ninjette.org/forums/showthread.php?t=63003
https://forums.ninja250.org/viewtopic.php?t=79963
I'm going through same thing with a 2002 and 2003 I bought with no keys. Will only need keys for one as 2nd will be race-only bike. Luckily I have locksmith friend who can help me out.
Old November 5th, 2017, 02:27 PM   #18
babyninja1968
Here it is , after quick bath....
Old November 5th, 2017, 02:28 PM   #19
babyninja1968
uploaded with my phone, pics are ok I guess if you are a bat haa....sorry bout the upside down pics
Old November 22nd, 2017, 11:21 AM   #20
spent_too_much
spent_too_much's Avatar
You need to remove the helmet lock, in order to see the key code on back. I have used bolt cutters to remove the "pin" and then access the phillips head bolt. I have never used the helmet lock anyway.
Your locksmith can then cut a key by code. In my experience, this is the easiest way out.
Old November 22nd, 2017, 11:23 AM   #21
spent_too_much
Wow! it looks fresh off of the showroom floor!
Old November 22nd, 2017, 01:39 PM   #22
babyninja1968
Thanx !!
Old November 22nd, 2017, 02:28 PM   #23
babyninja1968
Thanx Jean, just got the lock off and I can see the code, Z then 4 digits just like you said......I kinda mutilated the poor lock though...I called the locksmith and and told them it was an 88 Kawi and they said the bike was to old and they didnt have the codes...whimps...have to try another locksmith.....so that 4 digit code is for the ignition ? AND....all the other locks ?
Old November 22nd, 2017, 04:23 PM   #24
yes, the Z---- code makes one key that works for all locks. The gas-tank lock uses one fewer position; works with same key though.
I sent out RFQ via Yelp to 10 different outfits in S.F. Bay Area and two of them got back to me that they were able to make key from the code. Got two keys made from key-code for $51 and had two other copies made at same time.
Old November 22nd, 2017, 05:09 PM   #25
babyninja1968
where in SF bay area did you get replies from ? I am in South Bay....South San San Jose
Old March 9th, 2020, 08:36 PM   #26
Sorry I never replied to this. I used http://popalockbayarea.com/. Specifically made appointment at their Oakland location. Came in with my helmet lock and showed them key-code on back.
They punched it onto their computer and put the cut codes into machine. Even had JMA blank that fits! Out popped master-keys that’s brand-new and works better than any copies. Even if you have a key, don’t copy it because you’ll copy the wear and tear as well. Make a new master from key-code if you can.
Last futzed with by DannoXYZ; March 9th, 2020 at 10:11 PM.
Key comes out when ON n4mwd 1986 - 2007 Ninja 250R Tech Talk 22 May 27th, 2014 03:39 PM
I lost my only key the_game General Motorcycling Discussion 132 August 6th, 2013 01:59 PM
Broken key... 2003ninja General Motorcycling Discussion 19 July 4th, 2012 09:12 AM
Key tag Arinze General Motorcycling Discussion 10 April 7th, 2012 07:34 PM
key alternatives? alex.s General Motorcycling Discussion 6 September 28th, 2011 06:29 PM
