Old January 13th, 2018, 07:45 PM   #1
jazzwillrise
Motorcycle(s): Kawasaki Ninja 250
Ninja 250 Engine Seizure Symptoms?
jazzwillrise is offline   Reply With Quote
Old January 13th, 2018, 08:54 PM   #2
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
are you asking what its like when it seizes or like shortly before?
If its seized it doesn't turn over.
If its about to be seized its cause it is lacking oil, and might be too late to add and hope for the best.
rubber side down is offline   Reply With Quote
Old January 13th, 2018, 09:06 PM   #3
It's hard to know what the post is about, but we'll try to help if more information follows.
Old January 13th, 2018, 10:20 PM   #4
Is there oil in engine?
Old January 14th, 2018, 02:35 AM   #5
Ram Jet
Ram Jet's Avatar
Originally Posted by jazzwillrise View Post
Did you seize while posting this?
Bill
Old January 14th, 2018, 02:28 PM   #6
If you hit the starter and hear a buzz/clicking noise but the engine does not turn over, try charging the battery before freaking out.
A dead battery will often make the starter relay sit there and buzz without any useful turning:
https://faq.ninja250.org/wiki/When_I...attering_noise
If you want a sanity check on seizure, remove the end cap on the center of the left side engine cover. This will expose a 14mm (IIRC) bolt head that you can use a ratchet and small extension to turn by hand. Normally this is handy for valve adjustments but should answer the question (sorta) presented here. If you're able to turn the engine by hand with a ratchet for a few turns, the engine is not seized.
Old January 14th, 2018, 02:34 PM   #7
Snake
Snake's Avatar
Old January 14th, 2018, 03:28 PM   #8
I think Jasper figured it out on his own just after he started the thread, and replaced his post with three dots.
Old January 14th, 2018, 03:49 PM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Authorities come to your house and take your engine. Usually comes with an arrest of some kind.
Old January 14th, 2018, 06:07 PM   #10
Snake
Snake's Avatar
That’s why you file off the serial numbers.
Old January 16th, 2018, 10:21 AM   #11
spent_too_much
spent_too_much's Avatar
Bill
LOL
Old January 16th, 2018, 10:31 AM   #12
Snake
Snake's Avatar
@jazzwillrise is your internet froze in Texas? We need more info to answer your question.
[visordown.com] - Victory recall over risk of engine seizure Ninjette Newsbot Motorcycling News 0 May 6th, 2014 03:32 AM
[motorcycle.com] - 2014-2015 Victory Models Recalled for Risk of Engine Seizure Ninjette Newsbot Motorcycling News 0 May 2nd, 2014 01:40 PM
Pregnancy Symptoms Kscreations08 Off-Topic 17 March 23rd, 2014 02:15 PM
[visordown.com] - Honda UK recalls 392 VFR1200Fs over engine seizure concerns Ninjette Newsbot Motorcycling News 0 June 4th, 2010 08:30 AM
