Old January 26th, 2015, 10:12 PM   #1
MrAtom
MOTM - July '15
How to replace the throttle cable?
Haven't been posting much lately. Got another job, semester began, and my computer broke.
But, I did finally find some time to fix my broken throttle cable. I just can't seem to get it back on. I can't find any resources on this, either. The issue I'm having is that no matter how many times I try, the right control thing with all the cables and parts wont close up. Anyone else have this issue?
Also, I noticed my right handlebar wiggles a little. Any advice on that?
Thank you.
Old February 1st, 2015, 10:49 AM   #2
Free bump for some more help...
Old February 7th, 2015, 08:20 AM   #3
Country Joe
Grouchy Old Squid
Motorcycle(s): 2006 Ninja 250, 1993 Yamaha FJ 1200 ABS, 1990 Yamaha FJ 1200, 2014 Can Am Spyder RT-S
I found the same problem you are having when I disassembled the throttle housing. It helps greatly to enlist another pair of hands, give your assistant a small screwdriver or a piece of stiff wire to hold the cable in the groove inside the housing while you attempt to put it back together. Just try to be patient, it really is a pain in the rear to reassemble, it just takes a little time.
Country Joe is offline   Reply With Quote
Old February 7th, 2015, 08:43 AM   #4
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
I tie a string where the cable attaches to the carb to the end of the old cable. When you pull the old cable out, you can use the string to pull the new cable into place and it is routed properly with no binding. I believe there is an Allen head bolt that tightens the handlebar to the bracket. Snug this up if the bar is loose. Using some blue threadlocker will help ensure it doesn't come loose again.
Profanity is the weapon of the witless.
flitecontrol is offline   Reply With Quote
Old February 7th, 2015, 07:52 PM   #5
Originally Posted by MrAtom View Post
........... I can't find any resources on this, either. ............
Check this out:
http://faq.ninja250.org/wiki/Throttl...is/re-assembly
Like the base of the handlebar is loose respect to the triple?
Old February 8th, 2015, 04:24 PM   #6
MrAtom
MOTM - July '15
I got it figured out and forgot to update. Sorry haha. And, yeah, @Motofool, just like that.
Old February 9th, 2015, 08:15 PM   #7
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Throttle Cable Housing indr 2008 - 2012 Ninja 250R Tech Talk 2 December 20th, 2012 07:44 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
Changing Throttle Cable Francis 2008 - 2012 Ninja 250R Tech Talk 7 April 11th, 2011 12:25 AM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
