Old August 14th, 2011, 11:09 PM   #1
A7xschecter6661
A7xschecter6661's Avatar
Motorcycle(s): 2003 Yamaha R6
Custom Gauges: Tutorial-ish
Hey there. I have my pretty black and green bike and don't like the black & white/red face on the gauges. So I browsed around looking for replacements, then looked for guides on how to do it yourself. Then started emailing a vinyl place asking if I scanned the faces could they make me the faces with the lines cut out. Then I decided to do it myself and have some fun.
Keep in mind if you follow this and mess anything up its not my problem, I am using spare parts and swapping them to my bike when and IF it works correctly. Also these are not going to be perfect. But it gives you a chance to throw a little customization into them.
Here is what you start with: They just unscrew out of the cluster (luckily I had a spare from a parts bike laying around)
Then I drilled out the back of the needle resting pin and pulled it through. Later this can be popped back in and super glued in the back.
Scan this to your computer and print a few copies. This will help you cut over the vinyl. Cut them out, I may have gotten lucky but it scanned to my computer and printed the correct size.
I then scraped off whatever I want to shine through with the dulled corner (flat) of a razor blade.
Then I slapped the carbon fiber on them trimmed off the extra (don't make it perfect because I did this the first time, messed it up and had to start over anyway so just get it close with scissors)
Then poked out the holes with a needle/screw driver/pen and tape the paper for that gauge over the faceplate. The holes help you line it up correctly.
I decide to do my RPM gauge as triangles instead of just rectangles.
The temperature face I messed up and combined the red area with the last line, but I actually like it better. But I may redo it to size it to match the height of the horizontal line.
And finally, the speedo. I took off all the 10 increments as well as 45, 55 and 65 as those are the most common speeds I travel.
Next will be some green paint on the back so it shines through green!
Then I will probably paint the bulbs for extra green and get everything together to take pics.
Let me know what you think!
A7xschecter6661 is offline   Reply With Quote
Old August 14th, 2011, 11:21 PM   #2
Neat!
Old August 14th, 2011, 11:41 PM   #3
Snake
Snake's Avatar
Great idea. Can't wait to see pics of the finished product.
Old August 15th, 2011, 12:27 AM   #4
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
This.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old August 15th, 2011, 01:17 AM   #5
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Very interested in seeing the finished product
Trailerboy531 is offline   Reply With Quote
Old August 21st, 2011, 04:41 PM   #6
A7xschecter6661
Here is where I am at now.
I actually ended up ripping the carbon fiber off, using fluorescent green paint underneath, re-cutting the lines and then filling in the areas with more paint with a toothpick. Cleaned the extra paint off with goo gone and of course it fades the carbon fiber! Oh well hoping its not too noticeable behind the lens anyway.
Its not perfect but I still think it looks cool!
Next I just have to find where I can get tiny number stickers to replace the speeds and rpms!
Though my girlfriends handwriting with a silver sharpie might look great
Old August 21st, 2011, 05:40 PM   #7
ducducgooseit
Motorcycle(s): ...
Kudos on the coloring.
Is it hard to get the carbon fiber weave to line up?
ducducgooseit is offline   Reply With Quote
Old August 21st, 2011, 07:06 PM   #8
A7xschecter6661
Actually I didn't even think about making the pattern go the same way on the guages.
I just cut a square, peel it, lay it flat, slap the gauge on it and start cutting away
Its not technically a carbon fiber vinyl, its more of just a cross stitched black fabric
Should hopefully have them on the bike tomorrow, only problem being I won't have numbers that light up at night to know my speed, but its easy enough to know where I should be at, some light comes in around the front which is why I also painted the bulbs green so we will see how it looks!
Old August 22nd, 2011, 05:54 PM   #9
A7xschecter6661
Final results are in
It looks pretty good, I had my girlfriend write the numbers on with a extra fine silver paint sharpie. The only thing that could make these things turn out better if you decide to do them is to use a transparent adhesive film underneath to do the coloring instead of paint. I would say colored tint/lens tape something like that.
Nice thing is since the gauge faces aren't right against the glass it lets a little light in front of them to slightly light up the numbers so you can still see them
Old August 22nd, 2011, 08:29 PM   #10
Mekkakat
Eternal Noob
Motorcycle(s): "Blanka" 07' Ninja 250
hmm, wild.
Mekkakat is offline   Reply With Quote
Old August 22nd, 2011, 08:36 PM   #11
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Not gunna lie, its a tad ghetto
But its a great idea! I like it
----> My Youtube! <----
Taking the fairings apart tutorial cadd 2013 - 2017 Ninja 300 Tech Talk 3 September 1st, 2014 10:29 AM
Custom bracket for stock gauges Crriiissss 1986 - 2007 Ninja 250R Farkles 4 May 18th, 2014 07:55 AM
New-ish rider Insan3guy New Members 9 June 25th, 2013 03:30 AM
DIY Key guard tutorial (With pictures, oh boy!) Monkeytofu 1986 - 2007 Ninja 250R Farkles 4 August 10th, 2012 02:19 PM
Old Schooling Effect Tutorial BlueTyke Pictures 6 January 6th, 2009 12:58 PM
