March 17th, 2014, 06:44 PM | #1 |
Join Date: Dec 2013 Motorcycle(s): '04 Ninja 250R Posts: 367
main jet size listing.
stupid question but again im still new at this.
the main jets are in size from #100 #102 #105-stock size #108 #110 #112 |
March 17th, 2014, 07:09 PM | #3 |
is that correct? on a site i was looking at shows the main jets in a different order
March 17th, 2014, 07:28 PM | #5 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
I don't know what the stock main jet size is for the old gen, the service manual probably has it. Here a chart for the size differences between manufacturer.
CVMA #55 |
March 17th, 2014, 07:30 PM | #6 |
March 17th, 2014, 07:31 PM | #7 |
Josh, what's currently in your bike? the stock 105? or a 108? What are you doing to it that you think you need to go up to a larger jet?
Bigger is not better. Getting one step closer to the perfect mixture is better. |
March 18th, 2014, 09:15 AM | #8 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Stock is 105 but there is no reason to change jetting unless you have custom exhaust and/or pod filters. If you change the jetting without these things it will just run worse because the mixture will be to rich.
March 18th, 2014, 10:08 AM | #9 |
I have the 2 bros slip ons. But in some previous threads, there is cut out kinda like bogging when I push it quickly get the throttle to the "wot" or the stop point. The other day I was at 3/4 open throttle, then I jerked the throttle to fully open. The bike hicupet. Felt like it cut out only lasted a sec or so. I have a few other threads stating this problem. I did shim with one washer both needles. The low end is much better, it only happens at top end. No pods, just slip ons.
Even on a slow roll to wot it does this. I would say about %75 of the time it Boggs or hicupet at wot. So I figured going up one jet might help. |
March 18th, 2014, 10:09 AM | #10 |
March 18th, 2014, 11:37 AM | #11 |
So you need a bigger main jet. I don't have experience with custom exhausts so not sure what size you need. I run 112's no shims with pods and stock exhaust.
March 18th, 2014, 02:30 PM | #12 |
If you have 105, one size up is 108, not 110...
So snapping is the issue huh? Have you checked to make sure your slides are seated properly and not cracked/damaged? Meh at about your float height? |
Main jet question | pdxdavid | 2008 - 2012 Ninja 250R Tech Talk | 1 | October 24th, 2013 05:15 AM |
08+ Ninja 250 / Dynojet Jetkit 2193 Size 98 Main Jet | abhijitz | Items Wanted | 0 | March 6th, 2013 02:29 PM |
111 Main Jet | cuz | Items Wanted | 4 | November 10th, 2012 11:13 PM |
keihin main jet Q?? | cuz | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 10th, 2011 08:27 PM |
clarification on changing main jet sizes (yet again, sorry) | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 20th, 2011 09:37 PM |
