Old September 28th, 2009, 07:32 AM   #1
Hedge36
SooperChikkin.
Hedge36's Avatar
Motorcycle(s): BMW R1200GS Adventure, '07 250 Ninja
Hard ticking at idle
Yep, I searched. I Googled. And while this is probably a common issue, I haven't found the right term to describe it, let alone search for it
The new-to-me-'07 started yesterday with 7600 miles on it, and ended the day with 8100. About 400 miles into that run, I noticed a bit of a ticking sound up front between the pipes at idle - off-idle, no tick. Of course, I checked the oil and coolant levels, which were fine, and chalked it up to my ears playing tricks on me... it'd been a long day, what with my 6'1" frame folded up on the little bike, and I was getting a little punchy.
Anyway, this morning I headed out for coffee sans earplugs, and the tick - for want of a better term - was pretty damn noticeable. Again, levels are good, off-idle is fine. I call it a "tick" because it's not a low-end sort of "knock" and definitely not a "ping". There's a dark part of my mind that wants to call it piston slap but I really, really don't want to go there since I haven't turned the bike over to the new owner.
So, I bow to the collective wisdom here to alert me to other possibilities that might be more relevant to the Li'l 250. Thanks for any pointers.
Hedge36 is offline   Reply With Quote
Old September 28th, 2009, 10:15 AM   #2
When was the last time the valves were adjusted? On the pregens, they are due at the 600 mile check and every 5k after that.
Could the ticking you're hearing be loose valves?
Old September 28th, 2009, 10:26 AM   #3
Hedge36
SooperChikkin.
Hedge36's Avatar
Nah. I live with boxer twins, so I'm pretty tuned in to valve ticking. This is more like a 1-per-rev "tack" - my research makes me think "weak link", as in shoddy cam chain tensioner, though I've heard it described variously as either sounding like a good solid tapping noise or a coffee can full of pebbles. For the price, swapping the tensioner out sounds like a pretty good start considering I ran it between 60 and 105 all day yesterday
From the service records, the valves were checked and found okay about 1K ago. This weekend for grins I'll double-check them myself and make sure the cam hasn't jumped a tooth. Problem is, this is the first 250 Ninja I've played with so I'm not certain that the motor's power delivery isn't just part of it's factory corked-uppedness. She's making great power at 7K and up, so I suspect valve timing is currently okay. I'll also do an oil change and think about running a slightly higher viscosity to see if that makes any difference.
Old September 28th, 2009, 10:31 AM   #4
cool... good luck. please keep us informed if replacing the tensioner resolves the problem.
Old September 28th, 2009, 10:37 AM   #5
Hedge36
SooperChikkin.
Hedge36's Avatar
Wilco
Old September 28th, 2009, 02:11 PM   #6
greg737
Motorcycle(s): -
If you're going to remove the cam chain tensioner....
to check it's condition, be very careful to make sure you document how it's parts are put together. I've heard from other riders about getting it out and apart then realizing they didn't pay attention to how it goes together. Apparently there's a mistake that can be made with the short, fat spring.
There's a write-up in the ninja250.org FAQs about cam chain tensioner maintenance. http://faq.ninja250.org/wiki/Cam_cha...er_maintenance
If it's all pitted like this guy's was, I'd say you should replace it immediately. http://forums.ninja250.org/viewtopic...=778906#778906
I've heard that a loose cam chain can tear up the two guides/tensioners that ride against it (this is mentioned near the end of the Cam Chain Maintenance article I linked you to above) They're made of plastic and if this happens you can find the plastic bits on the oil screen when you do an oil change. (here's the oil screen checking article, http://faq.ninja250.org/wiki/Checking_the_oil_screen)
Good luck with it.
Old September 28th, 2009, 03:10 PM   #7
Hedge36
SooperChikkin.
Hedge36's Avatar
Thanks for the input, guys. I'm 98% sure it's the tensioner. Stands to reason, really, that if it was going to die it'd do it right at 8000 miles while being flogged on the interstate.
The noise almost certainly originates from near the tensioner (though this damn motor is so small it's hard to be sure sometimes!). And the more I think about it, the less I'm liking valves as the culprit as I'd expect them to tighten up after a hard run like that (unless one of the locknuts grew legs, and I sure as hell would've eaten a valve during the day if that was the case).
So, since all the shops are closed today, I'll order one up tomorrow (doubt they have it in stock here in Mobile) unless someone can chime in with an internet retailer who'll have stock and can do speedy shipping. You know, one that we trust.
Old September 29th, 2009, 03:02 PM   #8
Hedge36
SooperChikkin.
Hedge36's Avatar
Hey, folks - cooling my heels for a coupla days here. Somebody check my reasoning: if this WAS a sloppy valve, wouldn't I expect it to be just as noisy off-idle?
Old September 30th, 2009, 08:38 PM   #9
Hedge36
SooperChikkin.
Hedge36's Avatar
Update: valves are done. Damn, but that's a tight spot for tappet adjustments! Coming from BMW motors, I sure hope I don't need to monkey with these again any time in the near future.
ALL the valves were tight. I ran 4 on the intakes and 6 on the exhausts and erred loose, and now that that's done I'm convinced that the replacement tensioner (which arrives Friday) will be just the ticket.
Old September 30th, 2009, 10:19 PM   #10
null0
Motorcycle(s): Ninja 250 F17
I have the same noise. It's not the CCT or Valves on my bike. It was due up for a major service so the valves got checked and CCT checked. None of that fixed the problem. Mechanic also torqued down the header and checked some other stuff. After some research on ninja250.org I think the problem is this:
http://faq.ninja250.org/wiki/What%27..._the_clutch%3F
null0 is offline   Reply With Quote
Old October 1st, 2009, 07:39 AM   #11
greg737
Motorcycle(s): -
Interesting....
Are you going to pull the clutch basket to find out for sure?
The article mentions finding tiny bits of the rubber bumper black stuff on the oil screen. Have you checked your oil screen?
Old October 1st, 2009, 11:40 AM   #12
Hedge36
SooperChikkin.
Hedge36's Avatar
Yeah, in my case it's not the clutch. I pulled the screen early this morning and it was clean... and then I slip-tested the clutch and the rattle persisted.
So, I'm just waiting on the part to come in tomorrow and I should be good to go.
Old October 2nd, 2009, 10:35 AM   #13
Hedge36
SooperChikkin.
Hedge36's Avatar
Mmm... new cam chain tensioners are sweeeeeeet
What's funny is that if you compare the spring tension(s) between the old and new units, the squeeze test doesn't show a discernible difference. The most obvious wear item in the assembly looks to be the roller bearing.
Oh well. She's quiet and happy now. Time to ride her
Thanks for the input, everybody.
Old October 2nd, 2009, 10:40 AM   #14
nice work!
enjoy
Old October 2nd, 2009, 11:34 AM   #15
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Scott have you a DIY in the works?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old October 2nd, 2009, 11:40 AM   #16
Hedge36
SooperChikkin.
Hedge36's Avatar
Considering I had to fudge not having a 1/4" u-joint in my normal GS tool roll (shame on me), there really isn't much to add to the Wiki procedure.
Now getting to the exhaust valve tappets... sheesh.
Old October 3rd, 2009, 11:46 PM   #17
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Gonna have to disagree here. Responsible riders will get 12k miles between valve adjustments on.. hell just about any japanese bike (don't ask about the italians though). But most dealers who want your service money won't tell you that...
ASecretNinja is offline   Reply With Quote
Old October 4th, 2009, 01:31 AM   #18
sorry, I mis spoke... it's 6k miles, not 5k. 12k??? I don't think so. it's called "preventive maintenance", not "adjust when you think it's okay maintenance".
do what you want... I'm just quoting what the manufacturer recommends.
http://faq.ninja250.org/wiki/Do_I_re..._6000_miles%3F
Old October 4th, 2009, 04:00 AM   #19
Hedge36
SooperChikkin.
Hedge36's Avatar
Okay, I'm really curious - how does the relative responsibility of your riding style affect your valve lash?
Old October 4th, 2009, 07:51 AM   #20
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
sure thats responsible ROFL
QTRltrPWR
nate-bama is offline   Reply With Quote
Old October 4th, 2009, 07:57 AM   #21
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
Scott does your bike sound like so?
http://www.youtube.com/watch?v=uUVBonQ9AjI
if not your probably fine these bikes have a noisy valve train especially cold and at idle...running a good synthetic quiets it down a bunch.
QTRltrPWR
Old October 4th, 2009, 08:01 AM   #22
Hedge36
SooperChikkin.
Hedge36's Avatar
It's all good now, Nate. The only thing I need to do now is a carb sync next weekend. I thought I had my TwinMax on the GS this week but I was wrong and didn't have time to fake up a manometer.
Won't be long before I need to uncork this thing, I'll tell ya.
Old October 4th, 2009, 08:08 AM   #23
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
so i just noticed your in rainbow city, i'm just right up the road near Fort Payne. Howdy neighbor
QTRltrPWR
Old October 4th, 2009, 08:09 AM   #24
Hedge36
SooperChikkin.
Hedge36's Avatar
Howdy, mang. Gonna be here this week putting new tires and making nice to the GS and generally farting around before spending next weekend in Mobile, then back to Dallas.
Old October 4th, 2009, 08:12 AM   #25
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
cool well if your on your bike checkout the lookout mountain parkway it starts somewhere down there near gasden and runs most the legth of the mountain..Fun ride
QTRltrPWR
Old January 23rd, 2010, 09:06 PM   #26
Momaru
Momaru's Avatar
Got another bike doing hard ticking. Took a recording today while doing some other things, please ignore my innane commentary. After reading thru this thread, I'm thinking valve chain tensioner for 2 reasons:
1) it's definitely stronger on the right side of the bike, even if it doesn't show in the vid
2) had the valves checked at 7800mi (3000mi ago) and they were spot on.
MOV04699.MPG It's ~19MB, be forewarned. Wanted to edit, but can't find my usual vid edit software and don't wanna lose what little sound quality there is in a re-encode
As I mentioned in the video, I initially thought it was just drastically too lean, but that wasn't the case. I walked the mix screws to over 3 turns out and no difference.
It's running around 40F here and has been doing this for a while. At first thought it was just the 'normal' noise but finally heard another, 'younger' 250 today and it's definitely something wrong.
Timing chain tensioner. Agree/disagree/alternate ideas?
If so, how bad do ya'll think it would be to ride to my dealer of choice (some ~70mi up the road)?
Proud member of the Blue Army
Old January 23rd, 2010, 09:24 PM   #27
Hedge36
SooperChikkin.
Hedge36's Avatar
70 miles? No sweat. But really, just get the new tensioner and swap it yourself... I wouldn't waste the money having the dealer do it.
Old January 23rd, 2010, 11:32 PM   #28
jonthechron
Motorcycle(s): magHitVE
Hey, my manufactures manual says:
First Valve Clearance Check 800 KM(500)
Remaining Checks every 3125 Miles
Do you know if I should do a clearance check on a 09'?
Old January 24th, 2010, 08:29 AM   #29
Momaru
Momaru's Avatar
Aye, that's the plan. If I run in to the dealer instead of having it shipped, I'll likely be able to get the part before February. Also wanted to run by the shop and let them take a listen while I was there. Really loathe the idea of it being something else, but not too confident on my trouble-shooting ability within the engine if it isn't the chain tensioner.
Interesting... my '08 manual instructs checks at 7500mi intervals after the break-in. 7500mi has been suggested as excessively often, but if the manual says it needs it, there's probably a reason. I'd strongly suggest learning how to do it yourself though to save some big $$ checking it every 3k.
Might also take a look over here, lots of other opinions on the valve checks:
http://www.ninjette.org/forums/showt...hlight=ticking
Old January 24th, 2010, 09:24 AM   #30
Apex
Livin' the Minimoto Life
Apex's Avatar
WOW, that is insanely frequent. I check mine every 5k-ish. Err...well..basically when I feel like it. lol
Oh and the secret to gaining access to the adjusters is either remove the gas tank, or custom make some tools. I did that with a screwdriver and the socket. Ground down a 1/4" drive socket just a tad so it would clear the casting...worked great. Then have a small wrench handy to tighten it up the rest of the way.
Old January 24th, 2010, 03:09 PM   #31
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
the 86-88 models needed valve adj. every 3000 miles because they had softer seats than the 89-07 models. I'm willing to bet that the 08+ are similar to the 88-07 valvetrain
QTRltrPWR
Old January 30th, 2010, 11:24 PM   #32
Momaru
Momaru's Avatar
How would one go about this?
Old January 30th, 2010, 11:30 PM   #33
jonthechron
You might be right, my manual is a 1988.
Old January 31st, 2010, 01:44 AM   #34
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Did you ever figure out what is wrong? Is there something wrong? I can't tell from the video. What am I looking for?
Edit: I hear the tick. Mine has the same but not as loud. Is that normal? Meaning, is it normal to hear the ticking noise but not normal for it to be loud? Thanks. I only have 400 miles on the bike btw.
Old January 31st, 2010, 12:39 PM   #35
Momaru
Momaru's Avatar
Well, I've been told the cam chain does make some amount of 'tick' normally and listening to your vids, it sounds OK. Mine is making a lot of engine noise, especially when I was beside a '09 with <1/3 the miles I have. FWIW, I'm at about 10,750mi.
As for my engine, the valves were a bit out of spec (checked while I'm waiting on parts) so that should help a bit. Cam chain, tensioner and guides look A-OK but supposedly the tensioner can be 'bad' and look normal so I'm hoping it was just that. Long story short, still not 100% sure what's wrong, but my ears & shop guy agreed it's the tensioner. Will find out when it shows up and I get it installed.
Old February 5th, 2010, 06:54 PM   #36
Momaru
Momaru's Avatar
Well, after adjusting the valves as well as putting in a new tensioner and guides, my 'jett's engine seems happier. Pretty sure it was the CCT making the ticking, both from other people's reports and the old one felt a little weak vs new one when I re-compressed them both.
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
ticking. awful, awful ticking... Insan3guy 1986 - 2007 Ninja 250R Tech Talk 6 March 25th, 2014 05:32 AM
Engine ticking at idle? JMcDonald 2008 - 2012 Ninja 250R Tech Talk 14 December 17th, 2010 10:11 AM
