Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old November 10th, 2012, 08:31 PM   #1
Baja
Motorcycle(s): Ninja 300
Spool and headlight questions
We got a great deal on a rear stand from Cycle Gear and I think it would be better (safer) to use spools rather than the rubber pads. Is that right? Do the spools screw into the extra holes in the swingarm? Any certain type I need to get?
I don't like the unbalanced look of the single headlight being on. I read something about this but now I cant find it. We live in town and will never be use the brights. Is the bright headlight a different bulb that I could switch to a low beam bulb and turn them both on? Do the headlights adjust? I'm not sure if I would need to adjust it down.
Thanks for the help.
Baja is offline   Reply With Quote
Old November 10th, 2012, 08:38 PM   #2
The spool bosses (that hole on each side of the swingarm) are a standard M10 size. The only trick is that the spools have to be either small enough to fit under the swingarm, or have spacers to have them spaced out just far enough to clear the swingarm. More info in this thread.
I don't believe the bulbs are any different for high or low, they just are aimed differently with different types of reflectors behind them.
Old November 10th, 2012, 08:58 PM   #3
Baja
Is it better to get delrin plastic or aluminum?
Old November 10th, 2012, 09:58 PM   #4
It's just a preference. Neither is particularly superior, as a spool slider isn't really going to protect much as the bike is sliding on its side anyway.
Headlight questions... FBR_BDavis 2008 - 2012 Ninja 250R Tech Talk 23 August 1st, 2016 06:23 PM
Spool size? spool bolt length? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 1 November 29th, 2013 08:48 PM
Spool Installation NHrider19 Videos 1 June 6th, 2012 08:27 PM
Spool Install Question Malicious Logic 2008 - 2012 Ninja 250R Tech Talk 13 May 20th, 2012 04:01 PM
Headlight Questions?? Boomstick 2008 - 2012 Ninja 250R Farkles 8 September 6th, 2011 11:25 PM
