Old August 25th, 2013, 05:34 PM   #1
JAG
Motorcycle(s): 2010 Kawasaki Ninja 250
Rocker arm mod
Does anyone know of modifications to the rocker arm
As far as improving the rear suspension. Other
Than cleaning and putting oil inside all the 3 pivot shafts including
The upper tie rod pivot shaft on the swing arm. And swing arm bearings. Is this all that can be done. I'm tring to eliminate the jack hammer effect and sling shot in my rear suspension.
Last futzed with by JAG; August 26th, 2013 at 02:18 PM.
JAG is offline   Reply With Quote
Old August 25th, 2013, 05:49 PM   #2
Modifications to those pieces are for lowering the bike for short riders.
The swingarm's pivot needs cleaning and lubrication as well.
The needle bearings can develop some play that will affect handling.
Check that the shock absorber has no play in the upper bushing, that the rod is not scratched or corroded and that no oil leaks through the seal is visible.
It takes only the top bolt to remove it for inspection.
Old August 25th, 2013, 07:41 PM   #3
JAG
Are you meaning oil in the top part of the shock. Didnt notice any play. I had the
Shock out and there's no give to the rubber part. Didn't see any oil leak. Can that be replaced. Wonder how much damping effect there is there. Too much unknowns with this suspension
Last futzed with by JAG; August 26th, 2013 at 02:20 PM.
Old August 25th, 2013, 07:59 PM   #4
Don't use oil to lubricate the bearings in the unitrack linkage. Pack them with high temp bearing grease with Lithium and Molybdenum disulfide.
Old August 25th, 2013, 08:36 PM   #5
JAG
Grease got it ill get some. If the shocks weren't so expensive I'd buy
New one. Too much money
Last futzed with by JAG; August 26th, 2013 at 02:21 PM. Reason: More info
Valve rocker arm replacement swede core 1986 - 2007 Ninja 250R Tech Talk 8 April 3rd, 2013 08:23 PM
Broke a damn rocker arm during valve adjustment. SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 7 April 3rd, 2013 03:00 PM
Missing Rocker arm and valve adjust screw/nut Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 45 May 22nd, 2011 09:28 AM
WTB-rocker arm yelve Items Wanted 5 April 6th, 2011 05:26 PM
[hell for leather] - Are you a mod or a rocker? Ninjette Newsbot Motorcycling News 0 October 14th, 2009 06:40 PM
