March 29th, 2016, 03:45 PM | #1 |
GPX datalogger
I have fitted a GPX datalogger on my Ex300, does anyone have the pinout for the Tacho connector , or somewhere easy to connect to get an RPM signal. The other signals are easy to find, but this one eludes me
thanks |
March 29th, 2016, 03:52 PM | #2 |
Vintage Screwball
MOTM - Mar '16
Coil trigger wire? Lemme find a schematic.
Goin' fast on slow bikes! |
March 29th, 2016, 03:58 PM | #3 |
Vintage Screwball
MOTM - Mar '16
According to the diagram, it will be black or black/orange. Not sure which is number one coil but I would try that wire for the number one cylinder coil.
If you want the tacho input to the cluster, it's pin 12 on the cluster plug.
March 29th, 2016, 04:53 PM | #4 |
Thank you , I really appreciate your help
March 29th, 2016, 04:54 PM | #5 |
Vintage Screwball
MOTM - Mar '16
91 gpx streetfighter | tri501 | 1986 - 2007 Ninja 250R Farkles | 9 | December 10th, 2015 01:42 PM |
XT Racing GPX Pro | green_bread | Items Wanted | 2 | October 28th, 2014 04:44 PM |
GPX Pro | TGRIFF | Ninjettes At Speed | 18 | May 13th, 2014 03:28 AM |
XT GPX Pro | DCMoney | 2008 - 2012 Ninja 250R Farkles | 16 | September 25th, 2013 05:40 AM |
[roadracingworld.com] - Dorna And MSMA Reach Compromise On Use Of Spec ECU/Datalogger | Ninjette Newsbot | Motorcycling News | 0 | November 10th, 2012 11:20 AM |
