Old April 25th, 2011, 08:47 PM   #1
tjb0012
Motorcycle(s): 2009 SE Ninja250r
Carb Sync Question
Can someone explain to me what syncing your carbs is and why/when someone would have to do this. I plan on shimming my carb needles and removing the snorkel and am just wondering if i should be familiar with carb syncing because i will apparently have to fine tune my idle mixture screws.
If there is a DIY on carb syncing, could you please post the link. I have been searching the threads and can not seem to find one.
Thanks!
tjb0012 is offline   Reply With Quote
Old April 25th, 2011, 08:57 PM   #2
you should sync your carbs when they are out of sync.
normally, syncing is done after you have the valves adjusted or when you are having weird, pulsing problems at idle. Normally not needed when shimming needles... where did you read that it was needed?
have you searched the DIY threads for syncing?
http://www.ninjette.org/forums/showthread.php?t=5586
Old April 25th, 2011, 08:59 PM   #3
tjb0012
Thanks Kelly! I guess i missed that one...
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped menikmati Motorcycle-related 4 April 8th, 2020 12:39 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
carb sync WELLS 1986 - 2007 Ninja 250R Tech Talk 4 September 19th, 2013 08:30 PM
Carb Sync Question cuz 2008 - 2012 Ninja 250R Tech Talk 2 October 28th, 2011 08:05 AM
carb sync question greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 7 July 6th, 2011 08:41 PM
