Old June 21st, 2012, 04:22 AM   #1921
dubojr1
dubojr1's Avatar
Originally Posted by cuong-nutz View Post
I sent off my oil to the lab to get it tested. We'll see how well the oil is holding up to abuse and if anything is internally wrong.
I'm curious Cuong. What brand of oil are you using? I've considered in the past having my oil tested as well but I find that it's cheaper just to replace it. I guess testing could provide early warning signs though.
Old June 21st, 2012, 04:36 AM   #1922
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
I've put and OEM tank pad...
I'm still shaking from this upgrade... No more hockey tape on the belt buckle and on the jeans rivets...
Woot woot woot...
broken neck is offline   Reply With Quote
Old June 21st, 2012, 10:44 AM   #1923
cuong-nutz
cuong-nutz's Avatar
I have been using Rotella T-6 since after break-in. I'm at ~14.6k
HalfFast Racing Team
Old June 21st, 2012, 10:47 AM   #1924
dubojr1
dubojr1's Avatar
Oh cool. My oil changes are pretty much the same but I'm at ~16k. I'd be interested to read your report.
Old June 21st, 2012, 10:52 AM   #1925
prettypistol
Motorcycle(s): 2009 Ninja 250r, 2010 Ninja 250r
Cleaned the chain
prettypistol is offline   Reply With Quote
Old June 21st, 2012, 11:05 AM   #1926
Redgeneral
Redgeneral's Avatar
Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650
Smile
Ordered Bohemian Racing rearsets in gold.
Trying to wait patiently while they ship.
Redgeneral is offline   Reply With Quote
Old June 21st, 2012, 11:22 AM   #1927
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Left her at home, She heated up pretty bad yesterday so jsut wanted to give her a day to rest and then check her coolant and oil levels when I get a chance before I ride her again
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old June 21st, 2012, 02:29 PM   #1928
broken neck
... and removed those stickers that look like someone splatters some black or white paint on the body...
To my tastes, looks better this way...
Old June 21st, 2012, 07:10 PM   #1929
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Just finished an awesome track day. Got a bunch of pics and a couple vids. My friend is gonna touch them all up first. Can't wait to see. Now to clean all my gear and the bike, was a dirty, sweaty, hot day.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old June 21st, 2012, 07:12 PM   #1930
xSean13
xSean13's Avatar
Replaced front sprocket with a 15t...the DIY on here is vague at best. Good luck if you change your sprocket.
Old June 21st, 2012, 07:19 PM   #1931
CalvinAmI
CalvinAmI's Avatar
Motorcycle(s): '09 Ninja 250r [RED] & '06 Ninja 250 [WHITE]
Just finished wiring up my LED's.
front tri's = $9.99
rear stalks = $12.50
diode from ModMy250.com = $15.00
Electronic flasher relay = $15.00
TOTAL COST = $52.49
Value = infinite
CalvinAmI is offline   Reply With Quote
Old June 21st, 2012, 08:17 PM   #1932
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
What size nut holds down the front sprocket and how hard is it to get the bent washer off?
menikmati is offline   Reply With Quote
Old June 21st, 2012, 08:25 PM   #1933
xSean13
xSean13's Avatar
27mm front, and straightening the washer is easy...just used a flat-head.
Loosening and tightening the nut is the hard part. It's on freaking tight, and with 1 person it's extremely difficult. I had a 2x4 through the axle like the diy said and still couldn't get it, so I got on top of the bike, stood on the rear brake and torqued as hard as I could, veins popping out of my arms and all. Finally got it though.
In addition, putting the front sprocket on just by pushing the rear wheel as far as it will go is just about impossible...I had to take the axle out and drop the wheel and still had trouble getting it pushed in all the way onto the grooves. Then putting the brake pads back on the caliper properly was not working at all so I lined everything up and put the axle in from the right side instead.
Old June 21st, 2012, 08:29 PM   #1934
menikmati
I'm at about 18k miles with the stock front sprocket and I shrugged it off when I replaced my rear sprocket and chain about 2k miles ago, I thought I would have to have an impact wrench for the nut and a mallet or something heavy duty for the washer.
Time to place an order for a front sprocket and give it a go. I have to take the wheels off anyway to mount new tires.
Old June 21st, 2012, 08:37 PM   #1935
xSean13
xSean13's Avatar
That washer is super malleable, but the bigger front sprocket makes it ride very nice!
Old June 21st, 2012, 08:49 PM   #1936
menikmati
Good to know, I'm going to stick with the 14T this time around since I like the stock gearing but I'll consider the 15T with my next sprocket change.
Old June 23rd, 2012, 02:50 PM   #1937
menikmati
Got my S20's mounted and installed today.
Old June 23rd, 2012, 06:05 PM   #1938
sleepless
Motorcycle(s): '11 250 SE
The Ninja rider's helmet anyway..
2012-06-23_19-50-04_496.jpg 2012-06-23_19-49-16_80.jpg 2012-06-23_19-52-05_497.jpg
sleepless is offline   Reply With Quote
Old June 24th, 2012, 02:49 PM   #1939
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Stripped off all fairings to wash and wax each piece. While she was naked I decided to remove the carbs for a rejet. After dealing with the damn airbox during carb removal I pulled it out.
Since I was not planning on removing the airbox I now need to order a pod setup, breather element, and dig through the jetting database again for a rough starting point.
LoD575 is offline   Reply With Quote
Old June 25th, 2012, 07:44 AM   #1940
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
Yesterday I rode her to church, then to a terrible Mexican food restaurant where their enchilada sauce tasted more like barbecue sauce to me. Maybe I was just too white to eat there though... :shrug: I watched a bunch of kids look at my bike as I tried my best not to regurgitate my meal then rode it to get a hair cut. After my strange hair cut, which included vibrating chairs, head massages, hot women and warm towels, I headed over to my friends house. Then I rode back home and had all the neighbor kids compliment my bike when I pulled into the driveway
Mocha Man is offline   Reply With Quote
Old June 25th, 2012, 07:46 AM   #1941
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Attachment 19423 Attachment 19424 Attachment 19425
Pretty sick helmet, man!
Old June 25th, 2012, 07:53 AM   #1942
nycsteve
Biker
nycsteve's Avatar
Motorcycle(s): 2010 Ninja 250 SE
Church, mexican food, fresh cut with vibrating chairs, massages, hot women and celebrity status?
GREAT DAY!
S*** Happens!
Design Stuff | Tumblr
James 1:2-4
nycsteve is offline   Reply With Quote
Old June 25th, 2012, 06:52 PM   #1943
blackoutt
blackoutt's Avatar
Motorcycle(s): 08 R6, 08 250R
I could only find T-6 in 5-30 out here, so I got Rotella T 15-40 for now. What weight do you run?
Oh and today I changed the oil and filter, she's ready to ride now.
YEAH BUDDY!
blackoutt is offline   Reply With Quote
Old June 25th, 2012, 07:43 PM   #1944
Numbersix
Numbersix's Avatar
Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS
Overcame concern over knocking bike over without stands and adjusted rear shock preload to '2'. (point of reference, I'm 175#, 6'0"). I didn't need to worry; all this talk on the tech forum about how the wrench might slip, it's tough to turn the first notch, etc. didn't seem to apply to my bike, or I got lucky.
I was tempted to jump straight to '3' but I have learned from years of simulation racing *never* to adjust things more than a little bit at a time. I'll give this at least a week of daily riding before even thinking about '3'. Stiffening the rear always reduces understeer and can provoke power-on oversteer in cars; I'm assuming the same is true here so I want to give it some seat time to see how it reacts.
Numbersix is offline   Reply With Quote
Old June 26th, 2012, 01:22 AM   #1945
robski11500
robski11500's Avatar
Motorcycle(s): '09 Ninja 250R special edition
Went on a ride to Big Bear via Oak Glen road and Highway 38 Amazingly clear skies, and found out my ninja does just fine riding on packed dirt (complete road replacement on part of Oak Glen road) and it's more fun to turn around and cut your ride short when you've got THREE school buses in front of you Anyways, it's always a blast to go on a ride, especially with the roads we have here in socal
robski11500 is offline   Reply With Quote
Old June 26th, 2012, 01:43 AM   #1946
NinjaBoyEddy
NinjaBoyEddy's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r special edition
I had dirty sex on top of ninjalina with my girlfriend it was her idea, my girl is kinda jealous of ninjalina. We spend a lot of time together and ive transformed her. Ive have given her a new life Shes not plain stock no more. This happened a week ago and it was magical.
My first 3sum :]
Anyone else have sex one there bike???
NinjaBoyEddy is offline   Reply With Quote
Old June 26th, 2012, 01:48 AM   #1947
NinjaBoyEddy
front tri's = $9.99
TOTAL COST = $52.49
Value = infinite
Can you post a link to your rear turn signals I wanted the smoke ones but they out bidded me-_-
Old June 26th, 2012, 02:02 AM   #1948
NinjaBoyEddy
Originally Posted by EthioKnight View Post
Changed oil and filter, cleaned and lubed my chain and got to do what I had been hoping for the past week...INSTALL MY HUGGER!!
(This is Scott's newer version in SunBeam Red and Scott, as always, was great to do business with.)
I also replaced the stock oil cap with an aluminum billet one...just for kicks
Your seat cowl is sunbeam red? Would this red be the same red the 2010 special edition black/red is? I want to put a seat cowl but want to be unique not black and go with a matching red"" I noticed my red is darker so called "passion red"..
Old June 26th, 2012, 04:36 AM   #1949
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
yeah, the '08 red was passion red while the '09s were sunbeam red...no idea about your SE though, but I'm sure it'll look uniquely awesome! If the red is indeed passion r., you can get the '08 red. Much luck
EthioKnight is offline   Reply With Quote
Old June 26th, 2012, 04:42 AM   #1950
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
I left an hour early just to cruise around town on my bike, there's just no feeling to compare
Coolbpf is offline   Reply With Quote
Old June 26th, 2012, 04:59 AM   #1951
NinjaBoyEddy
Is your seat cowl OEM or that eBay one?
Old June 26th, 2012, 08:42 AM   #1952
EthioKnight
Super Noob
It's OEM...I would be cautious about the going the ebay route for these, I've heard fitment and color mismatch issues occurring with those.
p.s. I should have mentioned that my cowl is a sunbeam red (bike is a '09).
Old June 26th, 2012, 12:06 PM   #1953
road_rascal
Motorcycle(s): ___
Cleaned the bugs off my '04. Went on a 300+ mile ride yesterday in southwestern WI hitting up the twisty alphabet roads (county roads) with a few other guys. Still managed to eek out 65.7mpg with all the thrashing I put the 'lil Ninja through.
road_rascal is offline   Reply With Quote
Old June 26th, 2012, 01:49 PM   #1954
cuong-nutz
cuong-nutz's Avatar
That's interesting. The T-6 stuff here is 5w40.
Old June 27th, 2012, 01:36 PM   #1955
Redgeneral
Redgeneral's Avatar
Talking
Installed my Bohemian Racing Rearsets. Pics right after install.
The only issue I had with the install was the shift rod was too long. I had to use a dremmel with a cutting wheel to shorten the bolt at one end.
Old June 27th, 2012, 06:08 PM   #1956
blackoutt
blackoutt's Avatar
Yeah I think I meant 5w40, do they only make T-6 in the viscosity? I didn't buy it because I wanted 10w for the bikes. Maybe next time around.
YEAH BUDDY!
Old June 27th, 2012, 09:55 PM   #1957
cuong-nutz
cuong-nutz's Avatar
I've been debating if I should go all out and get rearsets or stick with adjusters.
Yeah, T-6 only comes in 5W40 unless they have a secret 10W40 stuff unavailable to the public. I'm still waiting for my lab analysis report to come back from my oil sample I sent off last week.
Old June 28th, 2012, 09:55 AM   #1958
Redgeneral
Redgeneral's Avatar
They're pretty nice. I have long legs (6' tall) so I've found it moves my foot position far enough back that I can grip the tank much better with my legs.
Next up will be a set of Driven clip-ons.
Old June 28th, 2012, 10:28 PM   #1959
LoD575
LoD575's Avatar
KN 0990 arrived today along with a breather element. Looking forward to a test and tune weekend.
Old July 3rd, 2012, 12:13 PM   #1960
Stingray1000
Rode her to work! Gonna change the oil and ail filter on the 13th. Was a beautiful morning for a ride, and luckily as soon as I got to work the day heated up and I was in cool air conditioning sitting at my desk! I leave at 9 and should hopefully be cooler for a great ride home! Lovin' ma Ninjette!
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
