Old November 6th, 2011, 06:26 PM   #1
91satanslegend
Motorcycle(s): 97 ninja 250
carb overflow hose size???HELP
Does anybody know the exact size and length of the carb overflow hose? I am going to ace hardware tomorrow to get this but don't know size or length and looking online doesn't help.
91satanslegend is offline   Reply With Quote
Old November 8th, 2011, 11:53 AM   #2
If I had to guess, it's probably a 1/4 ID hose. I'm not 100% sure though.
Did you ever get this figured out?
Old November 8th, 2011, 05:22 PM   #3
91satanslegend
not yet, im still trying to see if somebody knows the specifics on this hose... but apparently from what i hear, its optional.
Old November 9th, 2011, 01:10 AM   #4
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
I would also guess 1/4" ID. a 2 foot length should cost you about a dollar. Get a few different ones and use what fits best. Biggest I'd say is 5/16
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old November 9th, 2011, 01:21 AM   #5
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
Make sure it can handle fuel. Most of the hoses you'll find are vacuum hoses, and will deteriorate over time from fuel.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old November 9th, 2011, 05:30 AM   #6
91satanslegend
ok thanks everybody! I will be doing this friday once my gasket gets here..
Old November 9th, 2011, 05:57 AM   #7
g21-30
g21-30's Avatar
Measure the fuel outlet fitting. It's probably 1/4", but if you get 5/16" you can always use a hose clamp on it. Buy longer than what you need and trim to length after installation. Easier to trim hose than add hose! Since it's an overflow hose, the size is not critical.
Old May 1st, 2012, 05:56 PM   #8
MasterCylinder
MasterCylinder's Avatar
Motorcycle(s): '90 ex250
So in my haste to get my rebuilt carbs back on my bike, I forgot to replace the overflow hose that was previously missing when I bought the bike...
Should I even worry about having a hose on it at all?
MasterCylinder is offline   Reply With Quote
Old May 4th, 2012, 08:45 PM   #9
jschatte
jschatte's Avatar
Motorcycle(s): 1988 Ninja 250
Yeah you should have a hose on there. If not and the bowls overflow you will have gas pouring on your engine. Just get a roll of 1/4" id tubing and route it out the bottom of your bike (roughly 2ft)
jschatte is offline   Reply With Quote
Old May 5th, 2012, 07:46 AM   #10
MasterCylinder
Dang... OK thanks.
Old May 7th, 2012, 04:19 PM   #11
n4mwd
n4mwd's Avatar
I just rebuilt my carbs and I am fairly certain its 5/16", but if you get the 1/4" it will probably stretch enough to work anyway. They sell the yellow/green gas hose there in the lawnmower section. I'm using the yellow gas hose for my new vacuum lines.
My Ninja Blog
radiator hose size? mikedabike64 2008 - 2012 Ninja 250R Tech Talk 4 April 12th, 2014 11:14 PM
Where does the other end of this carb hose go? indr 2008 - 2012 Ninja 250R Tech Talk 2 May 13th, 2013 05:45 AM
Carb overflow. What could cause this to happen? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 25 August 1st, 2012 11:41 AM
Routing for fuel overflow hose haze5736 1986 - 2007 Ninja 250R Tech Talk 3 July 7th, 2011 07:09 PM
oil leak from an overflow hose? pinkandblack 2008 - 2012 Ninja 250R Tech Talk 30 June 17th, 2011 10:34 PM
