Old April 10th, 2014, 07:04 PM   #1
kavo
Motorcycle(s): '10 Ninja 250 Racer
AFR for most power
Whats the best AFR for power on these motors? I had a 250 and when dynoed it produced most power at high 13 (13.5+) to low 14:1 ratios.
I have an auto tune set up and wondering what the best ratio for power is
#77
kavo is offline   Reply With Quote
Old April 10th, 2014, 08:15 PM   #2
DaBlue1
DaBlue1's Avatar
You may want to read this thread. https://www.ninjette.org/forums/show...8&postcount=17
https://www.ninjette.org/forums/show...9&postcount=28
Old April 10th, 2014, 08:17 PM   #3
Ryephile
Ryephile's Avatar
Motorcycle(s): '13 Ninja 300 :: Pearl White
As a rule of thumb, peak torque is typically from 0.87 to 0.90 lambda. When talking in 100% gasoline speak where Stoich is 14.7:1, peak torque is usually 12.8 to 13.2:1. This of course depends on the combustion chamber shape, flame propagation speed, BSFC, VE, and a whole bunch of other factors.
Start with a 0.88 lambda target, and feel free to twiddle it a bit on the dyno to see where the sweet spot is at each programmable RPM cell in your Dynojet interface. Since you're tuning a naturally aspirated engine, it's unlikely you'll need to run any richer than 0.82 lambda or 12.0:1 AFR unless you're getting knock.
Good luck!
Ryephile is offline   Reply With Quote
Old April 10th, 2014, 08:22 PM   #4
kavo
Originally Posted by DaBlue1 View Post
Yes I was looking more for real world experience such as the second post
#77
Old April 10th, 2014, 08:37 PM   #5
DaBlue1
DaBlue1's Avatar
I just linked you to a couple of good single post. Here's the whole thing. Maybe it might be enough real world data for you.
https://www.ninjette.org/forums/show...618#post266618
Old April 10th, 2014, 08:40 PM   #6
Ryephile
Ryephile's Avatar
Remember to install your wideband sensor upstream of the catalytic converter if you're still running one or you won't get accurate O2 readings.
Old April 14th, 2014, 04:06 AM   #7
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
o2 is only half of the tuning(not really other factors involved), you need to look at changing ignition timing aswell.
If the stock ECU can change the pre-programmed timing settings, if not have to look into ignition control.
Changing "o2" cleans up the hills and valley's and corrects the AFR, and a power increase or loss could occur.
ninja250r81 is offline   Reply With Quote
Slightly used AEM UEGO Wideband AFR meter + sensor Momaru Motorcycle-related 33 August 19th, 2013 11:21 AM
help plz. wideband afr fine tuning the carb MikeJames21 2008 - 2012 Ninja 250R Tech Talk 20 June 12th, 2012 07:47 AM
Factory Pro Jetkit and AFR's abhijitz 2008 - 2012 Ninja 250R Tech Talk 8 April 7th, 2012 11:25 PM
[roadracingworld.com] - Live Webcast: OTT World Superbike Preview Show From South Afr Ninjette Newsbot Motorcycling News 0 May 14th, 2010 10:10 AM
[roadracingworld.com] - Fonsi Nieto Will Fill In For Injured Neukirchner In South Afr Ninjette Newsbot Motorcycling News 0 May 12th, 2009 11:10 AM
