Notices
Old October 12th, 2013, 11:15 AM   #1
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Got another 250...Need a little help with jetting
Got another 08 250 after selling my first 08 250 4 years ago. Bought this one used with 8k miles on it for a steal. Going to want to do some modifications over the winter to get it back to where I was moving with my first one, before kids ruined that dream...
Bike already has a Jardine RT5 slip on/possibly full, havent pulled fenders off yet.
Want to:
-remove airbox, add K&N pods
-swap out front sprocket for a 15T
-jet carbs
Need help with jetting. Anyone running something similar and can give me a starting point as far as jet size? In Ohio, don't do any extreme altitude riding. Any help appreciated.
~Thanks
Old October 12th, 2013, 12:06 PM   #2
quarterliter
Motorcycle(s): 2004 Ninja 250
110 mains probably. And screws 2.5 turns out. 2 shims under each needle. Honestly I would keep the airbox and remove the snorkel and call it good. Especially if you dont feel like messing with jetting alot. Granted you may need to rejet even if you only did that airbox mod, as the pipe will change things too
Old October 12th, 2013, 12:37 PM   #3
berserk81
berserk81's Avatar
Motorcycle(s): '06 Kawasaki Ninja 500
There are a lot of videos on YouTube that may help you on jetting the carbs.
berserk81 is offline   Reply With Quote
Old October 12th, 2013, 04:32 PM   #4
cuong-nutz
cuong-nutz's Avatar
http://www.ninjette.org/forums/showthread.php?t=10208
Jetting database.
Check out the DIY section in the tech section for more info about tuning.
HalfFast Racing Team
Old October 12th, 2013, 05:48 PM   #5
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Thanks all.
Old October 13th, 2013, 08:54 AM   #6
KrazyWalle
KrazyWalle's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model)
I have a full exhaust and Uni Pods. I'm running DJ 108 mains, needle in the 3rd position two washers on top. The screws I don't know I lost track of the turns after a long day of messing around. The pods are very loud, you can hear alot of intake noise btw.
I would be rich by now if I had a dollar for every person that has told me "You need to upgrade, You need a bigger bike, You need more power..."
KrazyWalle is offline   Reply With Quote
Old October 13th, 2013, 09:57 AM   #7
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Yeah everything I've read said they're loud. I'm not concerned, this Jardine is pretty loud. I'm looking to give the bike a little boost to compensate me changing the sprockets to ride better for highway. I have a 30 min commute to work all highway, so that's 90% of all my riding.
I ordered Factory Pro Stage 3 kit, with K&N filters. So I'm pretty sure with that, I can achieve what I need.
Old October 21st, 2013, 04:12 AM   #8
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
So, pulled airbox, added Factory Pro stage 3 jet kit. I installed 112 mains, left stock 38 pilot jet in, set mixture screws to 2.5 out, and added 3 washers to needle at 3rd clip. Couple quick questions:
-I placed e-clip in 3rd position as instructed by Factory Pro. They recommended 3 washers also to start. I placed these washers on top of e-clip, closest to the blunt end of needle. Is that correct? I recall reading on Factory Pro document this prevents needle bounce?
-having a slight hesitation between idle and 4k rpm, at 4k it grabs and takes off rather well thru redline. Would this be an indicator of needing to go higher on needle position, or idle mix screws?
Thanks!
Old October 27th, 2013, 05:31 PM   #9
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Put a few miles on bike with previous setup and wasn't happy with it. Pulled fairings and tank, pulled needless out and placed 2 washers under e-clip, left 3 on top. Actually put an e-clip on top of 3 washers to secure them as 2 washers were laying in the diaphragm area when I disassembled.
After a brief ride less than 5 miles, found much better than previous setup. Dead zone around 4k (1/4 OT?) went away, less or no popping on decel. I'll leave it here for now until next spring when I can get longer rides. Thanks for the help.
Old October 27th, 2013, 06:59 PM   #10
KrazyWalle
KrazyWalle's Avatar
Glad it worked out for you Them darn carbs can be real finicky and annoying!
Old October 28th, 2013, 09:55 PM   #11
webfoot
Motorcycle(s): 2012 ninja 250R
put stage 3 on my 2012, dynojet, yoshi slip on, K&n slip ons, got rid of air box, wow, a 250 that has balls. went exactly as dyno jet stage 3 said in directions, almost perfect, turned in air fuel 1/5 turn from that recommendation and it made a big diff, to me, no more whoof, big gas burp when shut off fast then open again, which occurred seldom, but did, now thats gone and i am glad I did all the upgrades. totally different little bike, not sure if I will go to 15 tooth front cuz no real long straights here in the islands, and I like the turns anyway
webfoot is offline   Reply With Quote
Jetting help Sipper' 1986 - 2007 Ninja 250R Tech Talk 5 April 18th, 2015 04:10 PM
Jetting: the right way alex.s General Motorcycling Discussion 4 July 20th, 2012 05:34 PM
2010 Ninja 250 Jetting Questions abhijitz 2008 - 2012 Ninja 250R Tech Talk 10 November 22nd, 2011 12:59 PM
Jetting ?'s triton981 2008 - 2012 Ninja 250R Tech Talk 2 September 5th, 2011 07:38 AM
jetting mxnello 2008 - 2012 Ninja 250R Tech Talk 1 April 18th, 2009 05:25 AM
