September 20th, 2010, 11:25 AM | #1 |
1996 Ford Taurus battery and alarm issue
My sister's 1996 Ford Taurus barely started this morning. I now think it was the battery but, at the time, I shut it off immediately to check the oil (the car burns oil, my sister never checks it, and I RARELY drive it). It wouldn't start after that, but the kicker is that the alarm started going off every time I opened the door and could not be silenced with my key. I flicked the switch behind the alarm LED but that didn't turn off the alarm. I pulled the fuse to the horns but the hazards keep flashing so I know that the alarm is still active. I usually can't get anything from the ignition but I can get clicking at other times (definitely seems to be the battery now). We tried jump-starting it and I couldn't even get the clicking... perhaps the alarm system was disabling the ignition? Either way, I think the next step is to test/charge the battery. Any other ideas?
Unfortunately, I do not have a battery tester or charger. |
September 20th, 2010, 02:56 PM | #2 |
Update: Took battery to Autozone on my motorcycle. An hour later they told me it wasn't holding a charge and sold me a new one. The new one does the same exact thing. Grrr...
The alarm goes off (activates) as soon as I connect the battery. It goes off again as soon as I open a door, even with a key. All the doors unlock when I use my key, so I know that, electrically, the car "knows" I am using a key. It still does not start. I can't even get it to make the clocking sounds it was making before. My sister started messing with her key fob and I heard the doors try to lock/unlock but it seems totally dead now or at least the car doesn't respond in any way. Last futzed with by CZroe; September 21st, 2010 at 11:03 AM. |
September 20th, 2010, 03:47 PM | #3 |
is this an integrated or aftermarket alarm?
either way, disable the power source for the alarm. if it's factory, there should be a fuse you can pull. if an aftermarket, find the "brain" and disconnect it. |
September 20th, 2010, 05:48 PM | #4 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
Does she have a remote on the key fob to operate the alarm?
Close the car doors and hood and see if it then will deactivate the alarm. And check the battery in the key fob too. Sometimes you have to put the key in the ignition and turn it on and off to shut off the alarm. If all that fails, disconnect the alarm and drive it to the dealer or an alarm installation company for them to shut it off. |
September 20th, 2010, 05:57 PM | #5 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
My aftermarket alarm on my car has a fuse you can pull. Look under your dash and under the steering wheel that is typically where alarms are (you may have to remove the panel under the dash if you can squeeze in there and get it). If it is aftermarket most will go if when reconnecting the battery (the old ones also still go off if armed and you use the key to open the car instead of the fob). Try pulling the alarm or disabling it if you suspect it has an ignition lockout when armed. mrlmd and kkim got ya covered on the rest.
09 ninja 2fiddy SE Driving slow things fast |
September 21st, 2010, 10:04 AM | #6 | |||
OK, so I sat in the car with my laptop for about 30 minutes trying to find out if it was something PATS-related (I still wonder if PATS ties in to the traditional alarm system too). After trying about 5-10 more times and flicking the alarm switch repeatedly with the key in different positions, I gave up and just sat there reading the PATS info. I was wondering if "1:3" means "three short flashes and a pause," which is what I was getting from the alarm indicator (it doesn't seem to have a PATS-specific "theft light"). I was also wondering where you find these 1/2, 3/4, 5/6, etc buttons it referenced (I'm assuming, on a code reader device). After having sat there quite a while without trying anything new, the light suddenly went back to normal. I tried the key and it started! The success was short-lived because it will not start today and it's back to setting off the alarm every time I open it. I tried it hours after the success last night and it was still working, so I am completely puzzled. NOTHING I did caused it to suddenly start working, soI suspected that it wasn't really fixed.
OK, so we're back to square one. A Ford-specialist told us that it probably needed to be reprogrammed by Ford if it couldn't be reset by locking and unlocking with the key fob, which isn't doing anything at the moment. I doubt it because it'nt not like it reprogramed itself when it suddenly started working, soit hasn't "lost" the programming. Quote:
September 21st, 2010, 10:24 AM | #7 |
First thing to try is another key that has been used to start the car in the past. If nothing there, then you need to get the codes pulled. The PATS system will toss out codes and then your diagnostics begin
What does the "theft" lamp do while holding the key in the start position? Also... if there actually is an "alarm LED" and a switch behind said LED, then you have an aftermarket system on the car in addition to the factory PATS system which only has a theft light in the instrument cluster. Your issues could be non- factory and total removal of the add-on system would be the easiest route.
September 21st, 2010, 11:01 AM | #8 | |
OK, I just went back out there and got it to start again like this:
Open door with key, alarm goes off, get in car, insert Key and attempt to start, will not start, leave in "on" position, flick switch on back alarm indicator LED back and forth a few times, alarm stops sounding, turn ignition key, CAR STARTS! I drove it to a convenience store and risked getting stranded but the same procedure worked again. The only problem with just dealing with it this way is that there is no horn due to pulling the fuse to keep it from sounding with the alarm. Oh, and I now know that the keyless entry buttons are what the PATS info was referring to with the 1/2, 3/4, 5/6, etc buttons. Quote:
2008 Not starting - battery issue? | Ash | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 14th, 2015 08:51 AM |
battery/electrical issue | MagicMike | 2008 - 2012 Ninja 250R Tech Talk | 9 | May 14th, 2014 07:52 PM |
1996 Ford E350 Toy Hauler Shuttle Bus Race Ready | Shadowwolf1117 | Motorcycle-related | 12 | February 8th, 2013 09:51 AM |
Battery part issue | checho323 | General Motorcycling Discussion | 2 | May 30th, 2012 09:08 PM |
Electrical Issue - Dead Battery? | k24_cm7 | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 17th, 2012 12:25 AM |
