March 23rd, 2013, 08:16 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2011 Ninja 250 Posts: 115
Inexpensive/free modifications
So I was wondering, what are some inexpensive or free mods we can do to our bikes? I just did a fender chop; free. Made my bike look nicer. What else can I do???
March 23rd, 2013, 08:22 PM | #2 |
March 23rd, 2013, 08:23 PM | #3 | |
Join Date: Mar 2013 Motorcycle(s): 1999 Ninja 250R Posts: 59
take off the seat, undo the rubber strap ( it unhooks right behind the battery ) grab the snorkel by the two round holes and yank it out. seat back on and fire up the bike |
March 23rd, 2013, 08:28 PM | #4 |
Oh realllyyyy. Is there any downside to doing this? Does it disrupt the air flow at all?
March 23rd, 2013, 08:30 PM | #5 | |
March 23rd, 2013, 08:32 PM | #6 |
Jigglin' your Jiglets
MOTM - Apr '13
You will also need to shim the carbs or your bike will run like doodie
March 23rd, 2013, 08:37 PM | #7 | |
Bike isn't green anymore though |
March 23rd, 2013, 08:39 PM | #8 | |
even without the shims my bike still runs good |
March 23rd, 2013, 08:43 PM | #9 |
MOTM - Apr '13
Just know, your bike is running rather lean right now
March 23rd, 2013, 08:45 PM | #10 |
March 23rd, 2013, 08:46 PM | #11 |
MOTM - Apr '13
Yes
March 23rd, 2013, 08:48 PM | #12 |
March 23rd, 2013, 08:50 PM | #13 |
Razor's Edge
Join Date: Nov 2012 Motorcycle(s): 2007 Sportster XL1200C Posts: 196
Yup. You cannot touch the top of the carbs for shims until the tank is off.
March 23rd, 2013, 08:53 PM | #14 |
Razor's Edge
I reversed the the shifter linkage for a 1-up/2-6 down, GP shifting. You do have to remove the front sprocket cover. The linkage will not clear it.
If the weather is clear tomorrow, I will post pics. |
March 23rd, 2013, 08:57 PM | #15 |
I did that too, but I didn't have to remove anything. Is that only on NewGen? Mine is PreGen.
March 23rd, 2013, 09:08 PM | #16 | ||
Ah that sounds cool. Although I've ridden dirtbikes my whole life and I am pre-programmed for the 1 down rest up kind of shifting. I don't think I'd enjoy reversing it. Just me though Would love to see pics if it's a current gen... after all we are in the 2008-2012 section! |
March 23rd, 2013, 09:15 PM | #17 | |
Guess the sprocket cover mod is only for newgen. |
March 23rd, 2013, 09:18 PM | #18 | |
March 23rd, 2013, 09:19 PM | #19 |
March 23rd, 2013, 09:21 PM | #20 |
Also, if I try this and it runs poorly without shimming, will I need to get some kind of glue to put it back in or will it just go in and be ok without the glue?
March 23rd, 2013, 09:24 PM | #21 | |
EDIT:: Original DIY states that the snorkel is just press fitted in but does have some glue for waterproofing reasons |
March 23rd, 2013, 09:32 PM | #22 | |
Razor's Edge
March 23rd, 2013, 09:43 PM | #23 |
Originally Posted by Jiggles You will also need to shim the carbs or your bike will run like doodie Now here is where I am hesitant... I have just now read a few articles about shimming. It is -3C to 1C for every one of my rides so far this year and my bike starts great, doesn't require hardly any choke and warms up fast. I've never had it bog or stall on me either. I think I have one of the rare properly tuned carbs possibly. My bike runs amazing. I do not want to or plan on shimming the carbs. If I have a bike that runs nicely and doesn't show any of the "lean-set" symptoms should I be fine? |
March 23rd, 2013, 10:06 PM | #24 |
MOTM - Apr '13
Well if u remove the snorkel you'll be adding more air to your engine and upset that perfect balance that you currently have
March 23rd, 2013, 10:09 PM | #25 |
March 23rd, 2013, 10:26 PM | #26 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
You can install a cbr rear fender on your ninja which is pretty economical.
March 23rd, 2013, 10:33 PM | #27 |
I'm pretty happy with the stock fender. I just did a small chop to get rid of the long bit that sticks down and I'm pleased with how it looks now. Trying to keep it pretty much completely stock. I have a tutorial on exactly how I did it in this section.
March 23rd, 2013, 10:34 PM | #28 |
I'm just curious if there's any way to help with the air/fuel ratio other than shimming. I'd love to help the exhaust sound a little nicer but an exhaust is out of the question.
March 23rd, 2013, 11:31 PM | #29 |
MOTM - Apr '13
You can rejet but its more complicated
March 23rd, 2013, 11:51 PM | #30 |
March 24th, 2013, 01:35 AM | #31 |
When I say rear fender, I mean tire hugger... Keeps your suspension clean.
March 24th, 2013, 06:57 AM | #32 | ||
The stock main jets are a tad rich, so removing the snorkel helps get those closer to perfect. However, this little bit of extra air means that the already EPA-compliant midrange is now a tad lean. Raising the needles by shimming them out helps deliver a little more fuel during the transition from pilot jet into the main jet, aka during mid-throttle use. So yes, there's plenty of ways to richen the mixture. But each part of the carb controls mixture at a specific area of the throttle range. so it's important to be able to tell where in that throttle range the bike needs a different amount of fuel. The main jets control mixture during WOT. The pilot jets control mixture during very small throttle openings. The needle height controls mixture during all the transition between those two. We'll get into float height later if you find that you need to adjust that, but I doubt you'll need to. Jiggles, changing main jet sizes =/= changing the needle height. Stop confusing the noobs with wrong info. Quote:
March 24th, 2013, 08:50 AM | #33 |
MOTM - Mar '13, Jun '14
Lose some weight. It will make your bike faster.
March 24th, 2013, 10:16 AM | #34 | |
http://www.bikebandit.com/bikemaster...FQmFnQodUCMA0Q Extra or flashing brake lights. Blind spot mirror. Proper maintenance and service (don't neglect lubrication of cables and control levers).
March 24th, 2013, 10:47 AM | #35 | ||
OK! Starting a fast for a few days, let you know how much I drop! Quote:
I dislike the mirrors on my bike, don't feel like they stick out enough, maybe a little dome blindspot checker from wal mart will do the trick. Ya for sure, I should look into maintaining the cables and levers. Didn't think that was something I really had to worry about seeing as the bike is only 1200km's new |
March 24th, 2013, 10:53 AM | #36 |
Fast until you're faster.
March 24th, 2013, 11:19 AM | #37 | |
You did not comment on the foam hand grips (link): they are priceless about reducing vibrations on your hands.
March 24th, 2013, 01:32 PM | #38 |
lol yup
Foam hand grips? Didn't read anything about foam hand grips? :S |
March 24th, 2013, 01:40 PM | #39 |
Mauchner,
My question is, what are you looking to get out of this bike? I could list some modifications that can be done to a bike for less than $500 that make it a sportier bike, but that doesn't mean much if you're not looking for the same bike I am. So give us some more info; are you going for a certain look? a more aggressive bike in the twisties? a better bike for touring/commuting? how much do you weigh and what are your thoughts on the bike so far/what feels odd to you? etc etc. I hope this helps you get the answers you're looking for so you can get the bike you want. Modding a bike is cool, but modding just to mod sounds silly to me. |
March 24th, 2013, 01:46 PM | #40 |
Oh!!
The newgen takes well to having drilled slides. The pregen does not do as well. I did it, and ended up using epoxy to seal the holes off again. I got a funky lean sputter if I cruised at exactly 6k. The second I changed my throttle input either way, it was perfect again, but it was bad for daily use. I tried all kinds of needle heights thinking that I could adjust for it, but all that did was throw off the needle height for the rest of the throttle openings. Just my here. Stick with raising the needles via washers. Don't drill pregen slides. Idk why it doesn't work as well as the newgens, it just doesn't. |
Inexpensive performance gain? | Zackninja | 2013 - 2017 Ninja 300 Tech Talk | 21 | August 7th, 2014 11:19 AM |
Inexpensive rear stand? | kdogg2077 | General Motorcycling Discussion | 36 | July 8th, 2014 08:26 AM |
Inexpensive slip-on exhaust | peteypetepeep | Items Wanted | 4 | March 20th, 2014 05:49 PM |
Want an inexpensive mini battery | nick5446 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 13th, 2013 05:25 AM |
Inexpensive Steering Damper | TheJimmyEnglish | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 11th, 2011 11:31 AM |
