Old October 18th, 2019, 03:15 PM   #1
primetime00
Motorcycle(s): 2007 Ninja 250R
Oil coming out side of airbox
Hello all,
I've just finished a carb cleaning, oil change, new air filter, and coolant change. I took my bike out to gas up and add air to the tires. The bike seemed to ride fine. When I got back and set my bike on the kickstand, I noticed small drops of oil coming from the side of the airbox. Is this normal after the oil change? I checked my airbox and saw just a small amount of oil in there. It wasn't hot.
I've added some photos of the inside and out leak spot of the airbox. Is the amount of oil in the box look normal? Also, should the plastic 'X' in the airbox be snug with the filter. I did notice that it was not.
Thanks for the help!
primetime00 is offline   Reply With Quote
Old October 18th, 2019, 03:19 PM   #2
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Everything looks normal. You might have overfilled the engine with oil slightly and this is just the engines way of getting rid of the excess. Air filter looks OK to me.
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old October 18th, 2019, 03:57 PM   #3
The filter may have had too much oil on it.
Old October 19th, 2019, 01:01 AM   #4
Manual's method of pouring engine-oil into centre of filter and squeezing always seem to over-oil filter. I usually spray single layer of K&N oil on each side and that's it.
Old October 19th, 2019, 06:05 AM   #5
It's REALLY easy to over-oil the filter and cause problems, especially if you pour oil on the filter and work it in.
I also use a spray oil - and just one coat. I learned the hard way that two coats is too much.
[roadracingworld.com] - WERA West Presented By Lucas Oil Series Starts This Coming We Ninjette Newsbot Motorcycling News 0 February 7th, 2019 12:13 PM
Oil in my airbox Cereal 2008 - 2012 Ninja 250R Tech Talk 6 September 18th, 2014 07:54 AM
Oil leaking out of airbox bike wont run properly peeweecollins General Motorcycling Discussion 18 July 9th, 2011 10:05 PM
Oil rapidly filling airbox, won't run without choke. 44chart 1986 - 2007 Ninja 250R Tech Talk 21 March 28th, 2011 09:13 PM
1993 250 gas/oil mix sprayed into airbox? th3cavalry 1986 - 2007 Ninja 250R Tech Talk 11 October 28th, 2010 05:34 PM
