Old May 31st, 2011, 07:28 AM   #121
nah.uhh
Motorcycle(s): n/a
I wouldnt run the oil for the reccomended 7.5k miles, I'd change it every 3000(5000km) or less. Personally I swap at 2k miles or less(~3200km) but I run my bike hard all day. You can't change the filter without draining the oil, your filter should last as long as your oil. Don't use fram filters. The oil looking dirty means it is doing its job and keeping the dirt off the engine parts.
I don't know aboutyour rust spots :s
Posted via Mobile Device
nah.uhh is offline   Reply With Quote
Old May 31st, 2011, 02:40 PM   #122
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
Originally Posted by ScorpionNinja View Post
I use 1.7 quarts of WD40 for my 250R
How many cans is that?
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old June 3rd, 2011, 12:07 PM   #123
seldom
Motorcycle(s): 2010 Blue Ninja 250R
Yeah that makes sense. If you run your bike hard all day it only makes sense if you change it more often than recommended. I think I'll change it again at 6000k so that'll be around 3000km since my last oil/filter change. Would I need to check anything else apart from that like spark plug etc.. Sorry I'm not too mechnically minded but everyday is a learning curve for me.
As for the rust spots I see a rusty stain trail off the bolts on the exhaust and at the end of the stand where the water usualy could sit. I always run my engine and go for a good long ride after every wash and dry. Usually I use a nylon scourer during wash over the screw and bolt where it's looks like rusty stain and they come off usually but a few weeks later I would see the stain trail again as if the water driped off the screw and and dried and discoloured into rust colour. If that makes any sense.
Are the Hi Flo filters any good. I'm in Perth Australia and it's like a village city and we are a few decades behind so we can't get alot of things here. I rang around for Wax filters and the shops have never heard of the brand.
I finally found a store that sells Mobil 1 fully synthetic but I couldn't find 10w40 so instead I went for 15w50 which has the same cold starting temp and min temp never drops below 3 on the coldest winter's night.
Oh and as for the fuel consumption I filled up today and I got 5.09L/100km so that mean I'm geting 46.5 miles/gallon
seldom is offline   Reply With Quote
Old June 3rd, 2011, 12:10 PM   #124
always trust your MOM.
Old June 3rd, 2011, 12:18 PM   #125
seldom
On what? When to change the oil? The only time I'll trust her on that is when I need to change the oil in the deep fryer.
Old June 3rd, 2011, 12:19 PM   #126
http://www.ninjette.org/forums/showthread.php?t=10577
Old June 3rd, 2011, 12:27 PM   #127
MOM = motorcycle owner's manual. it has the same (it is the same, right?) schedule in it as what kkim just posted.
you should always read your MOM before stepping on the bike for the first time.
Old June 3rd, 2011, 01:45 PM   #128
yes
Old June 8th, 2011, 08:53 PM   #129
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
Ok, I need to change my oil soon and I want to switch to synthetic. I don't believe the po used synthetic, but who cares because I will. I found out which filter I would need from Kkims DIY - Oil Change. Unfortunately no one seems to carry the correct filters locally so I may have to order one from online. Now on to the main problem, I went to Auto zone and found some rotella t6 full synthetic like this:
It doesn't say that it's motorcycle specific and that is why I didn't buy it. Is this the same rotella t6 you guys talked about? They have the mobil 1 racing 4t synthetic ,or w/e it's called, but it would cost me $10 / quart when I can get a gallon of the rotella t6 for $25. Price isn't a factor when it comes to what will perform best in my bike. I got confused because the rotella t6 doesn't say it's motorcycle specific and the mobil 1 does. Will this work in my bike?
Live2ride is offline   Reply With Quote
Old June 8th, 2011, 08:56 PM   #130
yep, that's the stuff.
http://faq.ninja250.org/wiki/Preferred_Brands
Old June 8th, 2011, 09:01 PM   #131
Live2ride
Live2ride's Avatar
Kkim, thanks so much! You really help the ninjette community a lot and I just want to let you know it's very much appreciated.
P.s. You dah man!
Old June 9th, 2011, 04:41 AM   #132
BlackNinja
Motorcycle(s): '09 2fiddy
I know you got your answer, but yes. That's the stuff. Used to run it in my ZX-10, and run it now in the 250. It's taken a few hundred miles after the initial oil change, but the shifting is making noticeable improvements. The stuff is awesome...I'm a believer.
BlackNinja is offline   Reply With Quote
Old June 9th, 2011, 01:13 PM   #133
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
cody,
wix filters are availble at napa. rebranded as NPS part #ps4941
want1sobad is offline   Reply With Quote
Old June 9th, 2011, 05:44 PM   #134
Live2ride
Live2ride's Avatar
Great to know, I actually picked up a gallon Omw home from work tonight.
Originally Posted by want1sobad View Post
cody,
I went to 4 places today, first was napa, which was closed. It seems like our napa is closed 24 hours a day here because I haven't seen them open at all in the last month . I got their hours and I'm hoping to go get the filter tomorrow. Second was autozone which has the Rotella T6 that I bought; but not my oil filter. Wally world didn't have the filter and neither did advanced auto parts. Napa here I come...please be open.
Old June 9th, 2011, 11:33 PM   #135
cuong-nutz
cuong-nutz's Avatar
Try Pepboys. I picked up a small stock there.
HalfFast Racing Team
Old June 10th, 2011, 06:46 AM   #136
Live2ride
Live2ride's Avatar
It's official, not a single store within at least 40 miles has the right oil filter(literally). I don't think there's a pepboys within 1.5 hours from my house so that's out of the question.
Old June 10th, 2011, 08:09 AM   #137
reaubideux
Perpetual Newb
reaubideux's Avatar
Motorcycle(s): 2010 MIB Ninja 250R [sold]; 2006 CBR600RR [sold]; 2013 Triumph Street Triple R
Do you have O'Reilly Auto Parts stores in your area? In St. Louis, that's the only place locally that has the Wix filters and even then it seems like only 1 location in the area actually stocks them. I'm just lucky that the 1 location is only 6 miles from my office so I can run out at lunch and pick them up; I just always get a couple each time I go since I've been changing the oil so frequently.
We even have Napa stores here but they don't carry the rebranded Wix filters at all, just there cheaper version.
I just did my 4th oil change at 1500 miles, next one @ 2000 will be to the Rotella T6 and then I'll be on the normal oil-change schedule per my MOM.
reaubideux is offline   Reply With Quote
Old July 9th, 2012, 02:16 AM   #138
reabo
Motorcycle(s): Kawasaki Ninja EX250 K8F
Full Synthetic oil
Preforming my first oil change. I looked at the guide and it says i need 10w40 oil.
I want to use fully Synthetic as its suppose to be best. What i wondering is whats a good brand to use, also how much would i expect to pay for it? I dont want to be ripped of thats all. Im in the uk btw.
I also bought a K&N 401n air filter
reabo is offline   Reply With Quote
Old July 9th, 2012, 04:44 AM   #139
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
The bike love's some Shell Rotella T Synthetic SAE 5W-40 fully synthetic
http://www.walmart.com/ip/Shell-Rote...1-Gal/14958681
You mean oil filter 401
http://www.ninjette.org/forums/showthread.php?t=10780
Good luck hope some UK peeps check in
THE GOOD LIFE
cuz is offline   Reply With Quote
Old July 9th, 2012, 04:49 AM   #140
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Shell Rotella T6 Synthetic here also, really good oil to choose.
Old July 9th, 2012, 04:52 AM   #141
reabo
Thx for the replies. I can defo use 5w40 instead of 10w40?
I dont have a clue lol. I just follow instructions. Also my bikes the uk fi model not carb. Will it make a differencE?
Old July 9th, 2012, 04:55 AM   #142
EsrTek
EsrTek's Avatar
I'm no expert on oil, but couldn't find 1 single 10w-40 synth oil (I know they out there, just none at my local wal-mart)....and so many ppl here run this oil w/o issues I went ahead and did too.
Old July 9th, 2012, 05:25 AM   #143
cuz
cuz
cuz's Avatar
@reabo ALOT of people use this oil not just the ninjette people Im sure its one of the very best oil out there for the 250
@EsrTek try ur trucker stops since this is oil is more focused on them
THE GOOD LIFE
Old July 9th, 2012, 08:22 AM   #144
it doesnt matter what kind of oil it is if you change it often enough.
Old July 12th, 2012, 03:59 AM   #145
reabo
I think i found Shell Rotella T Synthetic SAE 5W-40 fully synthetic.
However, it has a list of car on it, no bikes. Is this right? Also its about £26. that sound right?
Old July 12th, 2012, 05:01 AM   #146
cuz
cuz
cuz's Avatar
That's right its not listed for motorcycles but God the ninja lovs it
THE GOOD LIFE
Old July 12th, 2012, 05:02 AM   #147
EsrTek
EsrTek's Avatar
Rotella T6 is the right one, but that price seems high..cost me about $5 per qt which should be about 10quid or side of pond.
Old July 12th, 2012, 07:45 PM   #148
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
He's probably looking at the 5L jug. That's the only one I could find after checking 6 stores. Cost me $37 Canadian.
tsdexter is offline   Reply With Quote
Old July 12th, 2012, 07:47 PM   #149
DennyV
Motorcycle(s): 2010 Ninja 250
i just use castrol from advance auto, its like $9 a quart, but you only need 2 and dont really use the all of it
DennyV is offline   Reply With Quote
Old July 12th, 2012, 08:13 PM   #150
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
The newer Rotella T6 does have the JASO-MA compliance written on the label. So it is official.
http://en.wikipedia.org/wiki/Shell_Rotella_T
Samer is offline   Reply With Quote
Old July 13th, 2012, 06:01 AM   #151
Jewtoys
Glad to see my Ninja can take T6. I have a bunch of gals leftover from my EVO
Jewtoys is offline   Reply With Quote
Old July 13th, 2012, 06:21 AM   #152
tsdexter
Castrol GTX? Is that any good?
The reason I ask is because I just used 2 quarts of it to flush my oil before putting in the Rotella T6 - it was on sale 2 for $8 at Wal-Mart, the cheapest they had so I went with it for the flush.
Also, did you get one specific for motorcycles? I didn't realize until after I used it but the Castrol GTX I got was energy conserving which is not good at all for your wet clutch and other parts inside. (will cause premature wear and tear)
Luckily I only used it for a flush so it was only in for 20 mins. You can check the back of your bottle...
Old July 13th, 2012, 08:54 AM   #153
DennyV
I use the motorcyle specific castrol
Old July 13th, 2012, 09:06 AM   #154
tsdexter
Good stuff. Just thought I'd check.
Old July 13th, 2012, 09:10 AM   #155
Ptdoughnut
Ptdoughnut's Avatar
Motorcycle(s): 12 250r (sold), 2014 ZX6R
I have Royal purple 10w-40 Synthetic waiting for me at my work. Anyone else use this stuff on their bike?
They tell me I have to many hobbies! I think they don't have enough.
Ptdoughnut is offline   Reply With Quote
Old July 23rd, 2012, 11:58 AM   #156
reabo
Ok, i ended up buying castrol edge 5w30, fully synthetic. I can use this?
Old July 23rd, 2012, 12:07 PM   #157
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
5w30?
broilmebk is offline   Reply With Quote
Old July 23rd, 2012, 12:09 PM   #158
reabo
****... ive bought the wrong one havn't i....
Its defo 5w30.
Old July 23rd, 2012, 01:48 PM   #159
DennyV
castrol edge is car oil, you want the oil that castrol makes for motorcycles
Old July 23rd, 2012, 01:58 PM   #160
reabo
Im confused. Comments above say as long as its 5w40 its alright, even if its for a car. Can i get away with 5w30 though?
Conventional vs synthetic for first oil change? ally99 2013 - 2017 Ninja 300 Tech Talk 12 January 20th, 2014 07:44 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
When should I change my synthetic oil? NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 2 July 21st, 2012 04:43 AM
My oil change to synthetic ester experience jonthechron 2008 - 2012 Ninja 250R Tech Talk 16 June 3rd, 2010 08:49 AM
