Old August 20th, 2016, 08:06 PM   #161
daverdfw
Motorcycle(s): 2009 Ninja 250
ok I installed the plastigage , here are the results
daverdfw is offline   Reply With Quote
Old August 21st, 2016, 12:05 PM   #162
cuong-nutz
cuong-nutz's Avatar
Looks great from what I can see. I can't remember the clearance for the counterbalance but I think I went off the same as the crank.
HalfFast Racing Team
Old August 21st, 2016, 12:07 PM   #163
daverdfw
Balancer Shaft Bearing Insert/Journal Clearance Standard: 0.020 ∼ 0.044 mm (0.0008 ∼ 0.0017 in.)
Service Limit: 0.08 mm (0.0031 in.)
Old August 21st, 2016, 12:57 PM   #164
cuong-nutz
cuong-nutz's Avatar
Looks near the upper clearance but it is well under the service limit.
I guess this is where the red plastigage would be more helpful.
My gut says it's okay to run but ocd me says check with the red stuff.
Old August 21st, 2016, 01:04 PM   #165
daverdfw
here is a better pic of the balancer measurement
Old August 21st, 2016, 01:05 PM   #166
daverdfw
to me it looks closer to the .001 than the .0015
Old August 21st, 2016, 01:27 PM   #167
cuong-nutz
cuong-nutz's Avatar
I'd run it as-is.
Old August 21st, 2016, 02:14 PM   #168
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Ya it's in the ball park . I would do the whole test again to be sure but it looks like it's in the spec spread just fine.
It would be nice to measure the crank and bearings with micrometers. But the plastiguage clearance tells the tail.
Worlds fastest 250 ninja
Old August 21st, 2016, 02:17 PM   #169
daverdfw
ok thanks, when you guys put the hondabond on, do you have the transmission already installed? I did what the FSM said and installed the drum in N, and it seems I can change gears fine. Everything feels smooth when I spin it.
Old August 21st, 2016, 03:04 PM   #170
Racer x
Racer x's Avatar
Yes first I clean the case edge with brake clean. Then use Honda bond and wipe the case edge with te Honda bond. But I wipe it clean using Honda bond. This sorta leaves a film or shows any areas that the Honda bond won't stick to.
Then I get everything ready for the case to go together. I start with the top upside down and lay in the crank and balance shaft and trans. Make sure the forks are all lined up with the drum and any pipes under the flywheel or clutch are in place. Then I put a thin layer of Honda bond on the bottom case. I use an acid brush and paint it on. Then allow it to skin up for a couple muinites. Make sure you have all the bolts ready and clean and lubed . Plus know which ones have the seal washers. I don't want to start figuring out anything at this point.
Old August 21st, 2016, 03:08 PM   #171
daverdfw
that makes sense, thanks! I guess I will start on that next, kidna weird this is the part I am most worried about. I am sure it will run, its the long term viability that frightens me! Oh well worst case its a salvage motor. You guys have been amazing with all of the help, I cant think you guys enough.
Old August 21st, 2016, 03:37 PM   #172
Racer x
Racer x's Avatar
There is no reason there will be any problems. Personally I have really enjoyed watching your build. I'm sorry you broke the case. But this has been fun for me. All my engines are together and ready to rock.
Old August 21st, 2016, 04:49 PM   #173
daverdfw
well I just got very lucky, I had the crankcase back together, was torquing one of the smaller bolts to 14 ft-lb with my ****** harbor freight torque wrench, and the bolt made a sound like it broke in the case FML! Pull it all apart and just like 2 threads broke off the bolt. Will have to clean everything and reassemble but could be worse. Also going to go buy a real torque wrench instead of this POS one.
Old August 21st, 2016, 04:54 PM   #174
Racer x
Racer x's Avatar
Personally I use two types. A tprque O meter from snap on for the small bolts. and a torque wrench with a small dial. Not the big barrel spring type. But the type with a small adjustment knob on the side.
http://philadelphia.craigslist.org/tls/5699562284.html
Old August 21st, 2016, 04:55 PM   #175
daverdfw
yeah I was thinking a digital one because you could see the actual number instead of blindly waiting for a click
Old August 21st, 2016, 05:08 PM   #176
Racer x
Racer x's Avatar
I like to watch the torque build up. I don't like the click. But the click is fine. Just try to get the bolt to tighten and the wrench to go click in one sweeping motion.
Old August 21st, 2016, 06:19 PM   #177
daverdfw
well I ordered a better wrench from Amazon, if anything I see why you wanna put the hondabond RT on super thin, in some spots I saw where it was thicker than others. So a learning experience. Will try again tomorrow after I get the better wrench.
Old August 21st, 2016, 07:41 PM   #178
daverdfw
could someone confirm something for me regarding torque on the crankcase? the service manual says for the 6mm bolts on the bottom of the case to tighten to
Torque - Crankcase Bolts ( 8, L = 90):
First: 10 N·m (1.0 kgf·m, 89 in·lb) Final: 24 N·m (2.4 kgf·m, 18 ft·lb)
Crankcase Bolts ( 8, L = 73):
First: 10 N·m (1.0 kgf·m, 89 in·lb) Final: 19 N·m (1.9 kgf·m, 14 ft·lb)
but then it says for the 6mm bolts on TOP to use
Torque - Crankcase Bolts ( 6): 12 N·m (1.2 kgf·m, 104 in·lb)
then this website says
http://faq.ninja250.org/torque/ex250j/
on all 6mm bolts to do 12nm
I am confused. thanks!
looks like I found a chart in the manual that say all 6mm bolts are 104 in-lb
Old August 21st, 2016, 09:24 PM   #179
cuong-nutz
cuong-nutz's Avatar
Follow what the manual says.
Old August 21st, 2016, 09:29 PM   #180
daverdfw
yeah I am, was caught off guard by how they had it formatted. was weird.
Old August 21st, 2016, 10:13 PM   #181
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Something you will run in to is galling from dissimilar metals. You've got steel or stainless steel bolts going into aluminum threads that already have corrosion in them. I typically run a tap through every hole to clean out corrosion and then use just a tiny bit of old school Never Seez on the threads to keep things lubed. Not sure if this formula is still available as it has lots of copper suspended in the mix and the can is as old as I am or older.
It keeps things from sticking and breaking. But again, I'm anal retentive and have many tools at my disposal. YMMV.
Goin' fast on slow bikes!
Old August 22nd, 2016, 09:37 AM   #182
bruce71198
bruce71198's Avatar
I've been going 10nm om all 6mm bolts as 12 and even 11 seem to pull the threads out of the aluminum sometimes. Better off not getting to that point
Old August 22nd, 2016, 09:38 AM   #183
daverdfw
seems like a good idea, those bolts are pretty thin.
Old August 22nd, 2016, 09:39 AM   #184
daverdfw
when I put the crank and balancer back in before I seal the case. I am making sure I align the pain marks, so even if it turns it will still line up correctly, thats the correct way to do that right?
Old August 22nd, 2016, 11:21 AM   #185
daverdfw
also just discovered I had the first rev of the FSM, found a copy of the 5th revision. so info should be a little more accurate.
Old August 22nd, 2016, 01:12 PM   #186
Racer x
Racer x's Avatar
I also only go to 10 on the small bolts. And also the cam cover bolts. I'm in and out with them often and figure 10 is enough. Plus my little torque o meter only goes to 10 so I just turn till the dial hits ten.
Old August 22nd, 2016, 01:25 PM   #187
TP Ninja
Motorcycle(s): 300 Ninja
I'd check with the dealer. I believe you could reattach the broken-off piece around that bearing shell with epoxy since it's not bearing much of a load. I would consider getting a new upper crankcase half then. But it's probably easier and less expensive to pick up a used engine instead. I bet parts and labor to replace that upper case and the shift shaft will be $1000 easy.
TP Ninja is offline   Reply With Quote
Old August 22nd, 2016, 01:33 PM   #188
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
No. There is significant side loading on the piece that broke from the clutch springs.
Also, he's already bought new cases and is assembling them as we speak.
Old August 22nd, 2016, 01:50 PM   #189
daverdfw
here is current progress, I have crankcase sealed. working on putting the flywheel back on, then pistons, head, cams
this flywheel is a PITA with that damn key.
Old August 22nd, 2016, 02:02 PM   #190
daverdfw
when installing the flywheel bolt, the manual says 65 ft lb. I am holding the flywheel with a strap wrench. I am kinda worried about trying to torque that bolt down that much. what have you guys done with this bolt?
Old August 22nd, 2016, 02:41 PM   #191
daverdfw
so I followed the FSM on the piston oil rings , can someone doublecheck this for me? the red circles are each oil ring opening.
Old August 22nd, 2016, 03:12 PM   #192
daverdfw
holy crap how do you get the cylinder back over the piston rings? I tried sliding it down, and i kinda got them started but wouldnt go through.
Old August 22nd, 2016, 03:25 PM   #193
Racer x
Racer x's Avatar
First photo has the top ring gaps a little close together but the bottom oil rings look great.
Ok as for the block part. Go have a buiscut with butter and relax. This is the only part that is troubling. And just to be sure you did put the timing chain on correct?
Now rotate the engine until one piston is up and one is down. Put rags around the bottoms of the Pistons to protect them. Don't forget the base gasket.
The block has a little chamfer on it. Set the block on the piston and use your fingernail to squeeze the ring into the chamfer. It's best to push the back of the ring into the piston and then push each open end of the ring together. You should also squirt oil all over the Pistons rings and block.
Use a slight twist and rock motion to get the piston and rings in. Once you have the top rins in go for the oil ring and be more careful about the last one. It can be deceiving and slip out. Once one side is down rotate the engine a little and bring the other side up. Same song and dance but with less room to work.
DO NOT get frustrated. If you feel any frustration realize this is not as easy and it seems and walk away. Or try hard break a ring and wait for more rings to come in the mail. That is just how it goes.
Old August 22nd, 2016, 03:28 PM   #194
daverdfw
so should the top 2 rings gaps be like 120 degrees opposite?
also , yeah I have the base gasket on, the timing chain is on the bottom gear and pulled through the motor.
also for the flywheel bolt, I have an impact would that get it tight enough?
Old August 22nd, 2016, 03:41 PM   #195
Racer x
Racer x's Avatar
Yes to 120 deg separation on top rings
And yes to tighten the flywheel with an impact. Tight as heck is about right. Remember the oil pipes before the flywheel
Old August 22nd, 2016, 03:47 PM   #196
daverdfw
got it!
I got the cylinder head on, when I moved the crank and move the pistons, I hear no metal or other bad sounds, and the cylinder walls look fine.
yes the pipe is already installed under the flywheel.
Old August 22nd, 2016, 04:22 PM   #197
Racer x
Racer x's Avatar
You will be making noise in no time now!!
Old August 22nd, 2016, 04:46 PM   #198
daverdfw
ok one step closer, just put the flywheel at 2T and installed the camshafts
The paint marks are flush with the top of the head. I counted pins and have 36 just like the FSM shows.
here is a pic. One question, the camshaft on the left side wont seat completly because the cam lobes are on the lifters. IS this an issue or will it push down when I put the caps on? Thanks!
Old August 22nd, 2016, 05:32 PM   #199
daverdfw
ok! So I put the camshaft covers on, and cam chain tensioner, when i rotate the engine using the flywheel bolt on the 2nd revolution the 2T timing mark and both camshaft marks line up!
No weird noise, or grinding. so I assume I have everything all done in time?!
Old August 22nd, 2016, 06:24 PM   #200
cuong-nutz
cuong-nutz's Avatar
Sounds about right. Make sure you don't lose the spark plug seals on the valve cover.
Bike chain broke while riding. Can't shift. ieoz 2008 - 2012 Ninja 250R Tech Talk 8 August 19th, 2015 08:57 PM
Lowside- bent clutch thrust rod and possibly bent shift fork? Klondike1020 General Motorcycling Discussion 3 April 1st, 2014 02:29 AM
Short shift lever tie-rod? Yakaru 2013 - 2017 Ninja 300 Tech Talk 15 March 16th, 2014 01:14 PM
WTB Tie Rod for Shift Assembly TooNasty Items Wanted 0 May 15th, 2013 01:32 PM
Slipping shift pedal tie-rod headshrink 2008 - 2012 Ninja 250R Tech Talk 9 June 16th, 2009 10:46 AM
