Old August 30th, 2016, 03:08 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Is this a loose cam chain?
So my Ninja 250 was making a ticking noise so I'm doing a valve adjustment now (I discovered that they're REALLY tight), but someone also suggested looking at the cam chain to see if it's loose. Video below:
https://youtu.be/Wj-3draEkhI
I recently cleaned and reseated the CCT and that seemed to help a little, but the ticking remained slightly.
If the chain is loose, how can I fix it?
Cra1g is offline   Reply With Quote
Old August 30th, 2016, 03:43 PM   #2
Normally you have to turn an engine in its normal direction of rotation to give a tensioner a chance to do its job. I assume that's the case with the Ninja 250 engine, but I'll defer to someone with better advice if I'm wrong.
Old August 30th, 2016, 03:46 PM   #3
Jim & Craig, just like the final drive chain can be measured for slack, the cam chain can be measured as well since he has it appart. I have posted the measure before, I will see if I can find it.
Old August 30th, 2016, 03:50 PM   #4
Get out the ruler!
20 Link length
Standard: 127-127.4mm
Service Limit: 128.9mm
Old August 30th, 2016, 03:54 PM   #5
Cra1g
Cra1g's Avatar
Ok, so I slowly cranked the motor and noticed that the slack went away, but then would come back after a half rotation or so, then would get tight again, and then loose again. Is this normal?
Old August 30th, 2016, 03:56 PM   #6
Yes, just like your final drive chain (to the rear wheel), the chain stretches in different places/links. Which is why you take the measure in multiple places to get a feel for the entire chain but always base your final decision from the tightest part.
Old August 30th, 2016, 04:11 PM   #7
Also the cams are easy to turn in some spots and hard to turn in others (notchy) because of the valves and springs.
Old August 30th, 2016, 06:53 PM   #8
Originally Posted by Cra1g View Post
........ I recently cleaned and reseated the CCT and that seemed to help a little, but the ticking remained slightly.
https://www.ninjette.org/forums/showthread.php?t=104334
https://www.ninjette.org/forums/show...&postcount=733
https://www.ninjette.org/forums/showthread.php?t=149329
Damage from loose cam chain? br1ckd 1986 - 2007 Ninja 250R Tech Talk 6 June 9th, 2015 09:08 PM
Loose chain remedy The_big_dill 1986 - 2007 Ninja 250R Tech Talk 11 October 31st, 2013 07:18 PM
Loose chain adjuster Slick_Stevo 2008 - 2012 Ninja 250R Tech Talk 4 July 8th, 2013 05:06 PM
Loose cam chain wear? cuong-nutz General Motorcycling Discussion 15 May 6th, 2013 05:43 PM
Chain loose question frogandalien 2008 - 2012 Ninja 250R Tech Talk 11 June 23rd, 2009 02:00 PM
