Old May 18th, 2013, 06:32 AM   #161
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I use small copper drain plug seal washers.
Worlds fastest 250 ninja
Old May 18th, 2013, 06:36 AM   #162
Originally Posted by lgk View Post
I'll do it on my next valve adjustment interval.
Looks like a cheap way to pick up a couple of hp, and improve throttle response.
Keep me updated. I'm 200 miles over due for my valve check. I've been putting it off because this is the first week I've been able to ride.
Old May 18th, 2013, 07:18 PM   #163
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Eric, that thing sounds amazing can't wait to see the numbers.
The temperature readings, where are they coming from? and are they in a good range?
Old May 18th, 2013, 08:22 PM   #164
Racer x
Racer x's Avatar
That is the dual exhaust temp gauge. And they are good
Old May 22nd, 2013, 04:06 AM   #165
Racer x
Racer x's Avatar
I am going to take the bike to the dyno on Saturday. I am going to RnR Cycles in Sterling Virginia. I have used this same dyno from the beginning. This will be a good test to see how much difference the intake cam on the exhaust side makes. Plus I a always testing the nitrous.
Old May 25th, 2013, 07:22 AM   #166
tubarney
Dyno today or next week?
Old May 25th, 2013, 07:44 AM   #167
Racer x
Racer x's Avatar
Sorry Saturday the 22nd of June. My arm is in a sling from shoulder surgery until the 18 th of June. My season is screwed. I am going to test and tune at the drag strip ASAP and dyno run the bike. But my next mile run is not untill September.
Old May 25th, 2013, 07:59 AM   #168
tubarney
In a sling till the 18th. Thats gotta suck. Just put the clutch and throttle on the same side and ride one handed. Who needs front brakes.
Old May 25th, 2013, 08:10 AM   #169
mgentz
Board Member
Sorry to hear. Heal up.
Old May 25th, 2013, 10:56 AM   #170
Racer x
Racer x's Avatar
I don't have front breaks at all. But I can't load and unload the bike. And I can't put on leathers and I would look really funny trying to get my head into my helmet with one hand.
Ya six weeks in a sling sucks. You should have seen me get the pistons in the block with one arm. Took hours.
Old May 27th, 2013, 06:03 PM   #171
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
That is a wicked sounding machine you have there Racer. Throttle response was amazing.
Looking forward to the dyno run.
LoD575 is offline   Reply With Quote
Old June 4th, 2013, 02:34 PM   #172
Racer x
Racer x's Avatar
Looks like I will be going on the Dyno this weekend June 8. I am going to RNR Cycles in Sterling Virginia. I should be racing in Ohio. But my shoulder had rotator cuff surgery and I can't get into leathers.
The set up for the weekend is .
256cc forged 64mm pistons
12.5 to 1 compression
Two intake cams
Polished combustion chamber
Ported head
CR Special carbs stacks no air filter
BrtrTis ignition system
Takai racing coils
Custom made dual exhaust
25 hp shot of nitrous
I am hoping for 60 hp. But just really want to see the air fuel mixture. It was lean in the cold air of April. But now it is probably close. And I want to see the A/F of the nitrous. I am going to drag race after the dyno. So I need to set up for the short 1/4 mile.
Old June 8th, 2013, 08:29 AM   #173
Racer x
Racer x's Avatar
On the dyno now. Just pulled 32.5 hp a little rich at 12to 1. And are you ready??
61.10 hp . The 60 hp barrier is broke .
Old June 8th, 2013, 08:34 AM   #174
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
awesome stuff! Make sure you get a good copy of the charts i'm sure lots would love to see it on paper.
Old June 8th, 2013, 08:56 AM   #175
mgentz
Board Member
Intake cam in the exhaust was the ticket?
Awesome stuff
Old June 8th, 2013, 12:35 PM   #176
Racer x
Racer x's Avatar
The intake cam was the ticket to jump 5 hp and it did it easy.
BUT I still have some work to do. I don"t want any more power. 60 is enough. Now I need the AF mixture to be more consistent. If it was rich or lean I can fix that. But I have a mixture problem. lean at start and rich at the end. The lean part is bad because it spikes the EGT. not bad at 1100 deg. But it goes rich and I need to be consistent to spray 100% power increase for 30 seconds. It is getting there. Just a little more tweaking.
I forgot to get the charts. Rick has them at RnR and will Email them to me soon.
Old June 8th, 2013, 03:19 PM   #177
lgk
congrats,
Old June 8th, 2013, 05:09 PM   #178
Very impressive!!! Congratulations Eric!!
For just the motor (no nitrous) what's your target AFR?
Old June 8th, 2013, 05:20 PM   #179
Racer x
Racer x's Avatar
Always looking for an AF above 12 and below 13. And the exhaust should be below 1200 and above 975.
Old June 8th, 2013, 07:33 PM   #180
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Congrats Eric
Old June 8th, 2013, 09:22 PM   #181
are you measuring exhaust temps at the header? Sorry, just curious what your method is
I'm glad to see the exhaust/intake cam swap made the difference. Who knew it would be something so simple.
Old June 8th, 2013, 09:37 PM   #182
Racer x
Racer x's Avatar
I have the EGT probe six inch from the exhaust valve .it is mounted in the header.
Old June 11th, 2013, 03:56 PM   #183
Racer x
Racer x's Avatar
This is the dyno graph from the all motor pulls. I have the timing retarded slightly and with oxygenated fuel it can make a couple more I would think.
Old June 11th, 2013, 04:33 PM   #184
mgentz
Board Member
Smooth graph. What happens to your af ratio at 8.5k rpm?
Old June 11th, 2013, 05:17 PM   #185
Thanks for posting that Eric. I appreciate that.
Looks like your peak hp is at about 12.5 or so, and you're dipping as low as 12 or high 11's at the top.
I've been trying to get a feel for the best AFR for these bikes with my EFI setup. My bike seems to pull continuously when I set it to 12.7, better than it did when it was set at 12.9. Your pull looks like it agrees with my results. Maybe I'll try 12.6 or 12.5 when I'm at my track day and see which one pulls the best on the back straight.
Old June 11th, 2013, 05:40 PM   #186
Racer x
Racer x's Avatar
This engine loves fuel. I have no idea what that blip at 8.5k was .. But Rick was just kinda warming the bike up. Might have been a throttle thing.
I wanted to see if the 1 mm more exhaust lift made a difference. Maybe a little.
But 32 at 12.5 is what it always does. Even with nitrous 12500 rpm is top power.
Below 12 to 1 on the A/F and the engine will chug and really loose power.
Old June 12th, 2013, 04:35 AM   #187
Dark
Simple kind of man
Dark's Avatar
Motorcycle(s): 2013 Ninja 300
Two intake cams
Ported head
Takai racing coils
Funny thing you mentioned RnR, going through your thread all I could think about was Ali and his 250 endeavor. He taught me a good deal regarding top speed, posture, form, etc. Rick is a great guy as well, they've tuned the majority of my bikes. Sounds like you're in good hands.
Dark is offline   Reply With Quote
Old June 12th, 2013, 05:50 AM   #188
Racer x
Racer x's Avatar
I have raced with Ali and used RnR since 2008. Ya really great guys. And real world tuners. They ride fast bikes all the time. So they know what they are doing. At one point Ali had the fastest zx12 and the fastest 250 ninja.
Old June 12th, 2013, 05:55 AM   #189
Dark
Simple kind of man
Dark's Avatar
I remember when he was rebuilding the 250 and the pistons had dimples in them from running nitrous...he didn't care and still used them, lower compression
Old June 12th, 2013, 07:34 AM   #190
Racer x
Racer x's Avatar
The cast pistons limit him to 10 to 15 hp of nitrous. Nitrous loves compression.
Ninja 250 racer build thread bitaria Ninjettes At Speed 81 December 8th, 2015 08:19 AM
300 Hero Build thread :) Hero Danny General Motorcycling Discussion 98 June 25th, 2015 06:47 AM
Christmas Build thread ds650rida 1986 - 2007 Ninja 250R Tech Talk 84 June 10th, 2014 02:46 PM
Epic build thread Alex Off-Topic 8 April 8th, 2013 04:57 PM
Not so new '83 Kawi 440 LTD Build thread 5evenz The Ex-Ninjetters Lair 9 January 28th, 2013 06:48 AM
