Old September 23rd, 2012, 12:55 PM   #1
Virustech
Motorcycle(s): 250 ninja
Really Weird carb Issue need more trouble shooting ideas
Alright just gonna cut right to the chase hereon my 95 Ninja 250ex My carbs are losing fuel out of the body and were the air intake is for the pilots IE the two little holes below the intake on the rear of the carb. Im at a loss to what could be causing this problem. As far as what I have done to them so far is as follows.
Cleaned them with carb cleaner really well
Cleaned pilots and mains and all the little nooks that go to them
Set the floats to factory specs of 17mm (it is not leaking from the bowl overflow)
Pulled the top diphram off checked for holes in it and checked for bent needles there in great shape.
So im at a loss here for what else to check. Not sure and have never seen this on any of the carbs I have ever worked on. Very knowledgable about carbs so if you have a list of things to check other than what I have posted just post a list im at a loss here and this is my last resort before I just buy a new set!
Thanks for the help in advance hope we can figure it out cuz im ready to $&$---&@&$ lol
Virustech is offline   Reply With Quote
Old September 23rd, 2012, 03:26 PM   #2
OldTimer
OldTimer's Avatar
Motorcycle(s): Hayabusa, Vespa 200GT, Harley Electraglide, Ninja 250
The only thing you didn't mention was cleaning out the float needles and their seats. If there was a little debris in there it could hold the float needle open and not let it shut even though you set the float to 17mm. Not much else I can think of that will cause your bowls to overflow. Also your petcock should prevent the bike from leaking fuel since they are vacuum activated. I would check there for leaks too! Sorry, that's all I can think of...
OldTimer is offline   Reply With Quote
Old September 23rd, 2012, 03:33 PM   #3
I agree with Nick.
Besides, are the bowls properly ventilated to the atmosphere?
If not, some air pressure may be developing inside, pushing fuel in the direction you have explained rather the overflow tube.
Old September 23rd, 2012, 04:51 PM   #4
Virustech
Yea cleaned the float seats all the vents are gtg not sure might just need to pickup a new pair on ebay and see whats up. Almost seems like a vacuum problem its got me stumped big time
Old September 23rd, 2012, 05:14 PM   #5
Virustech
So I got it to start and run now its dumping fuel out of the overflow line. Pretty sure thats the float seat causing it. I have adjusted the float a few times and its in spec right now and its still dumping out the over flow. Pretty sure thats a seat issue.
But seems to be a vacuum issue as well. I cant get it to start if the vacuum hose is hooked to the petcock but if I remove it it will start then I pop it back on it will run. It revs from 3000 to 5000 up and down up and down then it will just die. It almost seems as though A its not getting enough fuel to fill the bowl or B its emptying the bowl and filling it and emptying it again. kinda got tired of messing with it tonight tom afternoon Ill shoot some HD video of the issue and post it up and link it on here and see what ya think. I would hate like hell to buy a rebuild kit for it just to have it be something else thats causing the issue. So im really trying to get a good diagnosis before I spend alot of money.
This bike I got a week ago for $600 not running so im not that much into it right now just so far put a CDI and Stator in it.
Old September 23rd, 2012, 05:40 PM   #6
Have you checked the ventilation of the tank?
Try crack opening the cap.
In order to eliminate the vacuum and petcock issue, you could feed the carbs by gravity only from a second vented tank and hose and see how the floats work.
Old September 23rd, 2012, 05:46 PM   #7
OldTimer
OldTimer's Avatar
I recently had a similar problem with an Amal Concentric carburetor on a 1968 BSA Thunderbolt. Since they are hard to find parts for, I took some valve grinding compound and put some on the seat and gently rotated the float needle in there. It was like what you do when you're seating a valve into a valve seat. Anyway I cleaned out all the valve grinding compound real good and then assembled the carb and it quit leaking. You might want to give that a try but you definitely do not want valve grinding compound in your engine. So make sure you clean it real good. It doesn't take much to seat the needle valve. Just a tip from something I did to solve a similar problem.
BTW, how much did the CDI cost, I think mine is not advancing so I want to buy a new one.
Old September 23rd, 2012, 07:15 PM   #8
Virustech
i got the CDI for about $85 they had some cheaper ones but the numbers did not match so I did not want to chance it
Old September 23rd, 2012, 07:17 PM   #9
Virustech
I checked the petcock for dirt cleaned it the diaphram looked ok checked all the vacuum lines ect. Tried opening the cap on the tank same issues.
Old September 24th, 2012, 01:58 PM   #10
OldTimer
OldTimer's Avatar
did you try to lap the needle valve into the seat? Did you get your CDI on ebay?
Old September 24th, 2012, 06:34 PM   #11
Virustech
Well I figured it out guys it was the float needles the little holder wires seemed to be stretched out really bad so I gave them a little help bent them down and all is well now. Starts right up no problems and runs like a champ.
The vacuum issues worked themselfs out its still having some idle issues but im gonna throw some seafoam in a full tank of fuel and get her out and that should help alot.
Thanks for all your info guys..
Old September 24th, 2012, 06:35 PM   #12
Virustech
yes I got my CDI on ebay
weird voltage/no start issue thedrewski86 2008 - 2012 Ninja 250R Tech Talk 8 April 16th, 2014 09:47 PM
Weird noise and shifting issue tony7kp 2008 - 2012 Ninja 250R Tech Talk 1 October 14th, 2012 01:40 PM
Trouble Shooting a couple things x only performance 2008 - 2012 Ninja 250R Tech Talk 11 May 18th, 2012 03:48 AM
Leaking Carb- Out of ideas.... drew13 1986 - 2007 Ninja 250R Tech Talk 7 May 10th, 2012 04:12 PM
Trouble-shooting Autoswitch/GD opener headshrink 2008 - 2012 Ninja 250R Tech Talk 11 September 8th, 2011 09:12 PM
