March 8th, 2011, 12:15 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
tire valve core - do you change it ?
When you change your tire, do you replace the valve core ? if yes, it there a particular model to buy ?
March 8th, 2011, 12:20 PM | #2 |
no... only if it develops a leak. I find if I keep the valve stems caps on, I almost never have problems with the valve cores.
March 8th, 2011, 12:23 PM | #3 |
That was quick thanks kkim !
March 8th, 2011, 12:25 PM | #4 |
God forbid I go to buy tires for my car and tell them the existing valve stems are good. You might think I just committed some sin. Not sure why I am being all religious on this thread. Anyway I bet those same tire guys who swear I need new stems on my car would plug a motorcycle tire puncture and not think twice about it.
March 8th, 2011, 01:39 PM | #5 |
I change them every 3rd or 4th tire change. Probably unnecessary in some cases, but it's a nit.
March 8th, 2011, 01:40 PM | #6 |
core or stem?
March 8th, 2011, 01:58 PM | #7 |
Ah - thought it was one piece, I think it's just the new valve stems. Are the cores retained?
March 8th, 2011, 02:09 PM | #8 |
the OP asked about cores, so I assumed the topic was about the cores inside the stems.
I'm like you, after about 5-10 years, I have them replace the rubber stems, but not at every tire change. I have seen them go bad (split at the base due to dry rot), so changing the stems frequently is not a bad idea if you feel the are subjected to extreme conditions. |
March 8th, 2011, 02:10 PM | #9 |
Join Date: Dec 2009 Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R Posts: 176
The core is internal on the valve stem but can be removed separate. I change the valve stem EVERY time I change a tire. Period. It might look good until you're stranded because it broke on a ride. They are cheap as dirt and a good piece of mind while you're in the wheel.
You can buy a valve core remove/valve stem puller assembly for $3 at the local auto store. Yes you need a stem puller, good luck doing to by hand. Cut the old one, fish the new one through, attach puller to cap threads, & viola. 10 seconds of work & a few dollars or a flat tire? or... better yet you can buy those really expensive metal angled valve stems!
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc |
March 8th, 2011, 02:12 PM | #10 |
IC2(SW)
Kurveygirl.com has some nice ones.
March 8th, 2011, 02:13 PM | #11 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
Cores never really go bad, they may come lose though. Really you should replace the valve stem when replacing the tire. They tend to dry rot and can cause leaks.
March 8th, 2011, 04:31 PM | #12 |
IC2(SW)
wish she had these in 11.3
March 8th, 2011, 05:48 PM | #13 |
ya, to the OP our valve stem hole size is 11.3mm what he said above^
These ones at kurveygirl are not bad for 10 bucks! Cheapest I've seen!
Tire Change Time | Apex123 | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 26th, 2014 05:18 PM |
Tire change questions | nickjpass | The Ex-Ninjetters Lair | 7 | September 5th, 2014 06:42 PM |
did u notice any change when you done your valve job? | pomartin | General Motorcycling Discussion | 12 | May 13th, 2013 04:33 PM |
Valve adjusting and Oil filter change | J>A>V | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 8th, 2013 02:36 PM |
Air leak from Tire Valve | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 6 | October 5th, 2012 03:40 AM |
