Old March 31st, 2020, 11:19 AM   #1
kerrismo
Carburetor issues
I have a 2012 250r im working on. When fully warm and choke off the bike idles like garbage for a while then dies (sometimes it just stays idleing like garbage around 1k) When trying to give it gas it'll just instantly die. I have noticed just looking without really taking anything apart a vacuum nipple (possibly) isn't connected is there suppose to be? I will post a picture
Thanks
kerrismo is offline   Reply With Quote
Old March 31st, 2020, 11:31 AM   #2
ducatiman
ducatiman's Avatar
see if the other end of the hose I marked X is floppin around loose in there. If so...attach it to the RH carb vac barb
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 31st, 2020, 11:40 AM   #3
ducatiman
ducatiman's Avatar
different angle, from front side of carbs, hose marked in yellow should be connected between RH carb barb and forward barb on decel valve as shown
coincidentally, just finished refurb on these this morning and snapped a pic in this view
Custom Carb Service
Old March 31st, 2020, 12:26 PM   #4
kerrismo
So everything should be connected the correct way now, but it is still having idle issues after choke is off. Even playing with the idle control it still studders then dies and instantly dies apon throttling. Carbs were cleaned and rebuilt, fresh gas was added as well. I know im probably missing something any other suggestion would be greatly appreciated.
Thanks
Old March 31st, 2020, 03:46 PM   #5
ducatiman
ducatiman's Avatar
What was motive prompting carb clean? Was bike dormant for extended period?
Custom Carb Service
Old April 1st, 2020, 09:35 AM   #6
Plastic port in original photo is for venting to atmosphere. There should be hose on it that goes back between intake-runners and down to rear-shock like other vent & drain hoses. That hose should be open so carbs can reference outside pressure for proper float-bowl operation.
What procedure and tools were used to clean carbs?
Difference before & after in behavior?
Old April 1st, 2020, 05:03 PM   #7
kerrismo
So before I go in to details about the carb I've got a stupid questio. Would a bent air filter housing cap cause low idle and stall? Then instantly stall once throttle is use?
Old April 1st, 2020, 05:15 PM   #8
Welcome to Ninjette, btw
not stupid questions. Your issue is not airflow, but insufficient petrol to match increased airflow when you crack open throttle. While you only need 1/14.7th as much fuel as air (by mass), it may be very difficult to get even that little amount through tiny little holes and passages. Do search here for "clean carbs ducatiman" for threads of others with same problems.
Carburetor hosing help!!! Juliamun111 2013 - 2017 Ninja 300 Tech Talk 11 January 23rd, 2019 12:37 PM
carburetor skip 2008 - 2012 Ninja 250R Tech Talk 9 June 5th, 2017 12:39 PM
Carburetor Cleaning Motofool Videos 3 May 20th, 2014 08:42 PM
carburetor bolts james250ninja 2008 - 2012 Ninja 250R Tech Talk 3 September 2nd, 2011 01:53 PM
Carburetor Heads Up Jakester9500 1986 - 2007 Ninja 250R Tech Talk 14 March 31st, 2010 09:44 AM
