June 28th, 2011, 05:51 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2011 kawasaki ninja250r special edition Posts: 14
will this turn signal work
June 28th, 2011, 06:42 PM | #2 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Only one way to find out!
----> My Youtube! <---- Unregistered, watch my youtube page! |
June 28th, 2011, 07:12 PM | #3 |
There's a limit to s2pdty
Join Date: Apr 2011 Motorcycle(s): 250r ninja (sold) Posts: A lot.
June 28th, 2011, 07:14 PM | #4 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Depends on how you're asking. Will it flash correctly? Install a new blinker relay for LED's or some resisters and it will work fine.
Will it fit well? As said above, only one way to tell. |
June 29th, 2011, 08:23 AM | #5 |
ModMy250.com
Those look identical to these:
Now just go measure the stock blinker well and see if it matches up
The www.ModMy250.com guy |
June 29th, 2011, 08:39 AM | #6 |
Join Date: May 2011 Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue Posts: 623
Looking at how it screws on, I think the threaded part might not be long enough to actually stick out of the fairing hole. You might need to custom make a mounting bracket.
June 29th, 2011, 08:43 AM | #7 |
ModMy250.com
It should be just fine if the turn signal sits inside the well like the Protons.
June 29th, 2011, 09:43 AM | #8 |
DUCEATR
You can extend the mounting stud quite easily using a long nut and a bolt and washer, or you can tap and die a small length of PVC tubing. I used the long nut method when I installed my triangle LED's. If it fits in the hole on the bodywork you shouldn't need to extend. Heck, buy em and try em.
June 29th, 2011, 08:38 PM | #9 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
they look like what i just installed.. but got mine from cycle gear.. i had to make a custom spacer so they would stick out past the fairing a little bit.. otherwise they sunk in just a little too far, assuming they are the same which they look like they are.
June 29th, 2011, 08:40 PM | #10 |
KThanksBye
seems unsafe though people wont be able to see you in front
June 29th, 2011, 08:44 PM | #11 |
Ridin Dirty
its seeable from up front, especially at night.. but most states flushmounts are illegal anyway so..
June 29th, 2011, 08:47 PM | #12 |
KThanksBye
ok cool, laws i dont really care as long as im safe :P
June 29th, 2011, 08:52 PM | #13 |
Ridin Dirty
cycle gear has a set of flushmounts that were like a thin led strip.. those wouldnt stick out past the body at all..lol! these arent as noticeable as the stockers from a large distance away from the front but they are pretty bright and id say at night they are very noticeable from the front that they are on. as long as you keep the back lights nice and noticeable i think flushmounts are fine, haha~!
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Turn Signals Only Work 75mph+ | jjb84 | 2008 - 2012 Ninja 250R Tech Talk | 26 | May 1st, 2012 08:00 PM |
Single LED turn signal does not work. | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 16th, 2012 08:20 PM |
Went down, now turn signal won't work | subiegy2010 | General Motorcycling Discussion | 14 | March 18th, 2010 12:12 PM |
[motorcyclenews.com] - A great Ride to Work turn out! | Ninjette Newsbot | Motorcycling News | 0 | July 21st, 2008 07:11 PM |
