Old March 3rd, 2017, 06:48 AM   #1
jrshooter
Motorcycle(s): ninja 300
fork dampner rod ?
do you have to disassemble the forks on the 300, to remove the dampener rod?
going to install emulators and need to drill out the rods.
thanks.
Old March 3rd, 2017, 06:53 AM   #2
Yes, you will replace one dampenning device (the holes in the rod) with another (the emulator valve).
Old March 3rd, 2017, 06:57 AM   #3
jrshooter
moto fool do i have to seperate the upper leg from the lower leg to get the rod out ?
Old March 3rd, 2017, 07:51 AM   #4
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Nope.
Take off caps and springs
Remove front wheel
Remove bolt at bottom of fork legs
Poke a stick upwards thru hole in bottom of fork and dampers will go upwards out of fork tube
Dave Wolfe is offline   Reply With Quote
Old March 3rd, 2017, 08:18 AM   #5
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Getting things lined up for reassembly can be frustrating but its certainly doable.
Old March 3rd, 2017, 11:24 AM   #6
I would, drilling the tubes in a vice or drill press.
I believe it is possible in the bike, but I have not tried that.
These links could help you:
http://faq.ninja250.org/wiki/Install...rs_and_springs
http://faq.ninja250.org/wiki/Suspension
Old March 3rd, 2017, 02:14 PM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
there are a few emulator DIY threads floating around. I suggest you find one and review it. Lots of your questions will be answered and it will save you time.
Old March 3rd, 2017, 05:46 PM   #8
jrshooter
thanks dave
Old March 3rd, 2017, 06:26 PM   #9
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
I actually think I used a magnet from the top to get the dampers out, not a stick from the bottom. Oops. My memory has never been great.
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit FvnnyL3tt3r1ng Motorcycle-related 20 February 24th, 2016 08:24 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
Lowside- bent clutch thrust rod and possibly bent shift fork? Klondike1020 General Motorcycling Discussion 3 April 1st, 2014 02:29 AM
[faster and faster] - 2013 Harley-Davidson VRSCDX Night Rod Special, VRSCF V-Rod Musc Ninjette Newsbot Motorcycling News 0 October 17th, 2012 03:20 AM
