Old July 9th, 2010, 01:37 PM   #1
Goosey
Goosey's Avatar
Motorcycle(s): Blue 2009 Kawasaki Ninja 250r
Protecting some damaged parts from rust
So I have dropped my Ninja and accumulated some scratches. No big deal right? Well it has been worsening because some of the metal areas which were scratched up such as:
- Exhaust
- Handlebar Ends
have started to rust at the scratched locations. Doh.
Anyone have any advice on a rust remover and some sort of clear sealant that would be good at keeping the rust away? I don't plan to repair this cosmetic damage for quite some time.
2009 Blue NINJA250r WEEEE
Goosey is offline   Reply With Quote
Old July 9th, 2010, 01:40 PM   #2
touch up paint on the handlebar ends, wax (car wax) on the (stock???) exhaust.
Old July 9th, 2010, 03:04 PM   #3
Goosey
Goosey's Avatar
Yep, stock.
Old July 9th, 2010, 03:05 PM   #4
Originally Posted by Goosey View Post
Yep, stock.
wax should work fine.
Old July 9th, 2010, 03:38 PM   #5
g21-30
g21-30's Avatar
You can remove the rust from the exhaust with a stainless steel pot scrubber like this:
Old July 9th, 2010, 03:42 PM   #6
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Another option for removing surface rust on chrome
is number 0000 steel wool. Steel is fairly soft relative to chrome so it won't scratch it any more than it may already be. (The more zeros, the finer the steel wool.)
Chrome is porous so rusts easily, it's more of a decorative finish than a protective finish. Not sure about waxing exhaust cans because of the temps but waxing chromed things like wheels and fittings is a good idea.
Old July 9th, 2010, 03:52 PM   #7
Sailariel
Sailariel's Avatar
On Chrome, Coca Cola and some aluminum foil works great. Dip the scrunched up aluminum foil in Coke and gently rub the rusted area--rust gone. Follow that up with some car wax. The bar ends can easily be touched up with Rustoleum.
Old July 9th, 2010, 06:34 PM   #8
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
I found that kangeroo urine and your toothbrush works the best on rust. you can also use it the clean the inside of your helmet and face shield.
Old July 9th, 2010, 07:40 PM   #9
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Old July 11th, 2010, 01:47 PM   #10
Sailariel
Sailariel's Avatar
Fox urine works as well---problem is that it smells quite bad. It is, however, more common than Kangeroo urine.
Old July 11th, 2010, 04:58 PM   #11
CC Cowboy
CC Cowboy's Avatar
Are you talking Megan Fox?
Old July 11th, 2010, 05:44 PM   #12
Goosey
Goosey's Avatar
It might be difficult to acquire Megan Fox urine, but I am sure the hunt would be enjoyable!
Old July 12th, 2010, 08:42 AM   #13
Sailariel
Sailariel's Avatar
That's for sure.
protecting your street-parked bike Finesse General Motorcycling Discussion 5 July 16th, 2014 11:32 PM
Have some damaged parts for sale/trade Insane Pie Motorcycle-related 4 May 19th, 2014 11:15 AM
[motorcyclistonline] - Protecting Your Bike Ninjette Newsbot Motorcycling News 0 February 2nd, 2011 03:40 AM
looking for damaged or affordable aftermarket parts! new gen stang65pony Items Wanted 5 September 1st, 2010 07:45 AM
Scratched and Damaged Parts PaulTersigni Items Wanted 3 April 8th, 2010 07:58 PM
