April 2nd, 2015, 02:30 PM | #1 |
[motorcycle.com] - Öhlins Recalls Aftermarket TTX36 Shocks
Öhlins is recalling its TTX36 aftermarket rear shock absorbers. The recall affects 964 shocks in the U.S. including some batches of the TTX GP, TTX RT and TTX36 MKII, produced from Nov. 9, 2013 to Feb. 20, 2015. According to Öhlins, the piston-shaft nut in some shocks may come loose, resulting in a loss of damping and potentially causing the shock absorber to come apart. Öhlins explains it used a different method to clean top-out spring guides that resulted in higher friction. This prevents the piston from reaching its intended final position, full metal-to-metal contact with the guide. Öhlins will notify owners and dealers will secure the piston-shaft nut to the proper torque. Owners are advised not to ride their motorcycles until the remedy has been completed. The shocks affected by the recall fit the following motorcycles:
Öhlins Recalls Aftermarket TTX36 Shocks appeared first on Motorcycle.com News. Click here for full story...
[roadracingworld.com] - Öhlins Expands Safety Recall Of Aftermarket Steering Damper B | Ninjette Newsbot | Motorcycling News | 0 | November 25th, 2013 11:40 AM |
[motorcycle-usa.com] - Ohlins Recalls Steering Damper Bracket | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2013 09:20 AM |
[roadracingworld.com] - Öhlins Recalling Aftermarket Steering Dampers For Some BMW Mo | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2013 12:20 PM |
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2012 04:30 AM |
[sportrider - latest stories] - Higher Performance Öhlins TTX36 MKII Shock Now Avail | Ninjette Newsbot | Motorcycling News | 0 | February 1st, 2012 08:20 PM |
