Old August 6th, 2023, 03:43 AM   #1
Soi
Clutch Plate Part different
I recently purchased a 2009 Ninja 250, I brought EBC clutch plate for it as I was concerned when I checked the OEM clutch plate that there was 2 different clutch plate ID on the schematic. Is there a difference between the first and last clutch plates and the middle ones?
first and last plate part number 130880039 (13088A)
Middle plate part number 130880038 (13088)
Soi is offline   Reply With Quote
Old August 6th, 2023, 09:29 AM   #2
Greetings & Salutations!!
Friction-material blocks on inner-most and outer plates are wider with smaller gaps between them. Post photos of what you have in EBC kit. And of parts you removed.
Old August 6th, 2023, 04:54 PM   #3
Soi
the only parts that have been removed is the clutch and a clutch stack(spring and steel plate) from another working ninja bike
Old August 6th, 2023, 08:02 PM   #4
Looks like EBC doesn't make different inner and outer plates. Should be OK
Clutch plate gap Unicyclone 1986 - 2007 Ninja 250R Tech Talk 9 June 16th, 2017 10:26 PM
2007 ZX6R Clutch Spring Plate/Clutch Spring Direction? KnuckleBuster General Motorcycling Discussion 2 August 24th, 2015 03:21 AM
Clutch :: Friction Plate & Metal Plate Install and Wear Questions abhijitz 2008 - 2012 Ninja 250R Tech Talk 12 June 21st, 2013 10:45 AM
