November 20th, 2011, 04:11 PM | #1 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
20 Question Permit Test
My birthday is nearing, and am have been studying both the drivers manual and motorcyclists manual (both the states and MSF's). So, my main concern is, what will be on the test? Will it just be simple stuff like "What sign is red and white?" - which is a real question off of the drivers test. Or will it be a question on how to ride a motorcycle, or identifying for example, the throttle or brakes?
I really don't know what is going to be on the small test. Thanks a bunch!!!
November 20th, 2011, 04:15 PM | #2 |
the permit test is easy. you'll do fine. its very basic stuff. typical road usage questions. iirc they let you retake it 3 times
November 20th, 2011, 04:17 PM | #3 |
#squid
MOTM - Jul '16
In NY you can take the test unlimited times, but the actual driving test is limited to five. If you fail the test, you can walk in again and take it again lol
November 20th, 2011, 04:19 PM | #4 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
its stupid easy.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
November 20th, 2011, 04:20 PM | #5 |
#squid
MOTM - Jul '16
Alright. All that studying for nothing
not really...
November 20th, 2011, 04:20 PM | #6 |
Avid Kitteh Poster
Its mostly common sense. Its good to read it over once or twice but thats really all thats needed imo
November 20th, 2011, 04:21 PM | #7 |
#squid
MOTM - Jul '16
Good. I did it more than that, I should be well prepared !!
November 20th, 2011, 04:21 PM | #8 |
Kamikaze Squirrel
All the questions should be from your state dmv manual; focus on the motorcycle and dui chapters.
November 20th, 2011, 04:33 PM | #9 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Good luck, Nick!
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
November 20th, 2011, 04:42 PM | #10 |
hates stupid people
Yeah, it's pretty easy man. For mine, I kept putting it off until the last second and then the night before, I just sat down and really read through the manual and soaked in what I was reading. I love motorcycles so it wasn't that hard to get interested, ya know? And then I just had my wife ask me the little self test questions at the end of each chapter/section. Did that process once and then went in the next morning and aced the test. If you've studied it as well as you said, you should be fine.
Good luck! and let us know how you did. |
November 20th, 2011, 05:22 PM | #11 |
#squid
MOTM - Jul '16
Alright. I know more than the manual has to offer.
November 20th, 2011, 05:25 PM | #12 |
I had a question on there that asked what I should do in a turn if I needed to brake. I put down straighten up then brake. I got that one wrong and the answer was Slowly apply brakes. This was in Michigan and might be different in NY.
November 20th, 2011, 05:30 PM | #13 |
#squid
MOTM - Jul '16
I believe mine tells me to slowly apply rear brakes. I believe only experienced riders should do that.
I don't know if the guy locked his rear brake, but either way, he took flight!
November 21st, 2011, 12:36 PM | #14 |
That guy locked his rears and then high sided. When making turns at speed you should never hit the brakes unless its an emergency. The same rule applies to shifting. I'm not sure what happened in the video as it could have been either brakes or shifting that caused the problem.
So to corner, if you are going too fast, slow down before you enter the turn, then take your foot off the brake (as long as you didn't lock it up). If you lock the front wheel, release it immediately. If you lock the rear, the best thing is to just keep it locked until you come to a stop. There are other ways to get out of a rear slide, but coming to a full stop works most of the time and is probably what is on the test. In an emergency, you can slowly apply both brakes (mostly the front). Keep in mind that if you start to skid in a turn, bad things will sometimes happen (see video). In the MSF course, they teach you to abort turns by straightening up and then applying the brakes. But its very seldom that you would actually do it that way in the real world. The reason is that you would probably run right into the path of a car coming the other way. When turning, don't forget to keep one eye looking down your turn path and the other watching the pavement for loose gravel/dirt/etc.. Depending on what you see, you may have to adjust your path. I've had to do an emergency stop before. I just slowly applied the brakes. I had the green arrow and a stupid cager decided to make a U-turn right in front of me. I was only doing about 40 and came to a complete stop about 6" from his POS. Then I looked up and saw him just yacking on the cell phone completely oblivious to the fact that he nearly killed someone. He never stopped or even acknowledged that I was there.
November 21st, 2011, 12:58 PM | #15 | ||
November 21st, 2011, 01:28 PM | #16 | |
When I saw the solid black rubber trail, I didn't think it was a spin up but if the bike is powerful enough, I suppose it could.
November 21st, 2011, 01:39 PM | #17 |
Yup, it doesn't really take much power when it's leaned over that far. He's still all the way over on his knee after the apex, and he gets on the gas too early and too fast, which adds even more lean angle when the rear starts to break away. The bike sure took a fun flipping ride though, didn't it! Looked like an expensive repair bill.
November 21st, 2011, 03:19 PM | #18 |
#squid
MOTM - Jul '16
That was one of the top comments
November 21st, 2011, 04:38 PM | #19 |
Here's a similar one that I don't get at all. He doesn't look like he is leaned over that much, nor does his back tire look locked, but over he goes.
November 21st, 2011, 04:59 PM | #20 |
We started to discuss that one in this thread, but I thought it was in another decent thread as well. Poor throttle control, less than great surface, and more lean angle than necessary. Edit: Found it, another discussion on same video.
December 12th, 2011, 09:07 PM | #21 |
#squid
MOTM - Jul '16
So, nine days. Anyone have any basic questions that you could test me with?
December 12th, 2011, 09:13 PM | #22 |
December 12th, 2011, 09:17 PM | #23 |
#squid
MOTM - Jul '16
Thank you...now I need more!
December 12th, 2011, 09:18 PM | #24 |
#squid
MOTM - Jul '16
This one puzzled me. It's "A" right?
To Safely ride with a passenger you must: A) Have at least a 750cc engine. B) Add extra air to your rear tire to compensate for the added weight. C) Make sure they have their own seat and foot pegs.
December 12th, 2011, 09:34 PM | #25 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
lmao you need a busa atleast for two up.
VROOOM vrooom >.> |
December 12th, 2011, 11:19 PM | #26 |
Join Date: Oct 2009 Motorcycle(s): 2008 Ninja 250r, 2006 Ninja 636 Posts: 175
what's the best way to deal with a tailgater?
a) speed up a little to increase distance between you and the tailgater b) slow down to open up space in front of you c) change nothing, as you can't change other motorists' behavior d) ride alongside him and punch in his window, then sleep with his wife. hint: don't stress about it lol
December 13th, 2011, 05:27 AM | #27 | ||
I think there were some harder ones in there such as what you need to do when its raining and you have to cross the railroad tracks.
December 13th, 2011, 05:42 AM | #28 |
Crossing wet railroad tracks...
Hint: Rubber tires slide easily on wet steel. So anytime its raining and you have to run over something made of steel, you need to be extra careful. The same is true of plastic things like road reflectors and even painted signs on the road (i.e.-"Ahead Stop", etc.). The center portion of the lane, known as the "grease strip" also gets very slippery when wet. When crossing RR tracks in general, you need to be aware of the angle of intersection. If they cross at less than 45 degrees (more parallel than not), you have to do a jig on the bike so that you cross at a safer angle. Otherwise, just run them over. Then there is steel grates on bridges. Its best to just go in a straight line over those and let the bike go where it wants. The bike will wiggle as it crosses, but it will go mostly straight. If you try to go at an angle, the grates will throw you around. Not fun at all.
December 13th, 2011, 06:25 AM | #29 |
#squid
MOTM - Jul '16
I think you have to open a space up.
December 13th, 2011, 06:37 AM | #30 |
The correct answer isn't listed. You should pull over to the rightmost part of the lane, or change lanes if possible, and let the idiot pass you.
That's the answer the DMV wants. But if you have a bully tailgater, your response is different. Bully tailgaters won't pass you no matter what. Each situation is different, but they rarely understand how dangerous it is for you. In their case, if speeding up will solve the problem, then do it, but if not, you'll need to stop or turn off until they pass. In most cases, you can out accelerate a tailgater, but they can still catch you if they try. You can use that to your advantage.
December 13th, 2011, 06:42 AM | #31 |
#squid
MOTM - Jul '16
Okay, that's what I thought. I was confused and picked the best answer.
December 13th, 2011, 09:42 AM | #32 |
actually on my DMV exam, the correct answer was open up space in front of you. for the exam, you gotta study what they want exactly. you might have a logically better answer, but if it's not the one they're looking for, they won't take it. There's no room for explanation on the exam. I agree, some circumstances call for speeding up, but that's not what the DMV wants to hear (the cop that pulled me over didn't really wanna hear it either. grr) . c'est la vie
December 13th, 2011, 09:45 AM | #33 |
Join Date: Aug 2011 Motorcycle(s): 2011 ninja 250r, 2013 gsxr 600 Posts: 93
My permit test had some wierd questions. Such as; starting at what time is it necessary to wear a helmet when riding a bicycle?
December 13th, 2011, 09:46 AM | #34 |
also the question may have been more specific--like "What is the best way to deal with a tailgater on a two lane road with intermittent dashed yellow lines."
I agree, moving over is probably the best option. just be careful when you pull into the next lane. a lot of the tailgaters 'round here have no problem passing on the right. if their car is fast enough, I'll just let em do it instead of risking a cluster****
December 13th, 2011, 11:52 AM | #35 | |
this is why books like twist of the wrist tell you to set your line and keep it. the more changes you make, the worse off you are going to be. especially under power. edit: looking back actually it looks like his bike picked up from getting on the gas then he pushed it back down breaking it loose... its hard to tell without a view of his throttle just remember. 99% of the time, doing nothing, or adding gas fixes the problem.
December 13th, 2011, 12:24 PM | #36 |
Where can I get a copy of this book? or is it a dvd?
December 13th, 2011, 12:48 PM | #37 |
maybe a book store, library or your local pdf pirating station? there is a video for twist of the wrist 2. theres other great books that have similar info but they disagree in a few subtleties. recently read "performance riding techniques" which is more for track riding than street riding, but its a great book as well.
i would send you the pdfs, but i dont have them anymore... i am supposed to send the squirell a copy but ive been so busy i havent had time to go steal more copies. sorry peeps, gotta do it on your own for now.
December 13th, 2011, 01:24 PM | #38 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
how to shift, lane positioning, nothing hard
blink-182 |
December 13th, 2011, 01:27 PM | #39 | |
But the reality is that if you are in a car, and a guy tailgates you, and he is driving a nice car, and you are driving a POS, then slam on the brakes. When he hits you, his insurance will have to buy you a new car and write you a big check. But if you are on a motorcycle, he only has to pay for funeral expenses.
just passed permit test | Kscreations08 | General Motorcycling Discussion | 31 | March 25th, 2014 04:02 AM |
Map of NY handgun permit holders | red5 | Off-Topic | 18 | December 31st, 2012 09:35 PM |
California DMV Motorcycle Permit Examination | ajcadoo | Riding Skills | 13 | February 10th, 2012 07:46 AM |
Alberta Learner's Permit ? | demp | General Motorcycling Discussion | 8 | May 5th, 2011 12:11 PM |
[topix.net] - Friday last day to ask for Harley rally permit | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2009 09:30 AM |
