April 17th, 2012, 09:27 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2009 Ninja 250R Posts: 12
Exhaust gasket question
I just bought a 2009 250r and I noticed a leak around the area where the mid pipe slips into the exhaust can. I took it apart and noticed the clamp was really loose. Is there supposed to be a gasket that goes in here or do you just crank down on the clamp?
Thanks in advance. |
April 17th, 2012, 09:48 PM | #2 |
Ms. Personality
Crank it. I always put some RTV silicone on the mating surfaces, though. Has always worked for me.
April 17th, 2012, 10:29 PM | #3 |
Thanks for the quick response. I cranked it down and it looks good. I'll start it up tomorrow and see if it leaks. If it does then I'll go buy some RTV sealant and crank down again.
April 18th, 2012, 01:30 AM | #4 |
Join Date: Nov 2011 Motorcycle(s): 2011 ninja 250r Posts: 6
Mine definitely came with a gasket, just put my slip on on last week.
April 30th, 2012, 08:15 AM | #5 |
Just saw some exhaust gasket in a can at Walmart. What was on there was some flaky conforming metallic looking thing which was wrapped between that slotted sleeve thing and the the outer portion.
Gasket, Exhaust Pipe C (11009-1667) fell apart? Replacement options? | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 8th, 2013 10:31 AM |
WTB: Gasket, Exhaust Pipe C (11009-1667) | Bones85 | Items Wanted | 0 | May 7th, 2013 07:28 PM |
Exhaust Question | Hunsy34 | 2013 - 2017 Ninja 300 Farkles | 3 | March 3rd, 2013 11:27 PM |
exhaust gasket? | 00v_Lucky | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 25th, 2010 03:17 PM |
Header exhaust gasket | B2FiNiTY | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 8th, 2009 08:03 PM |
