Old March 21st, 2020, 07:25 PM   #1
drychain
Motorcycle(s): 2008 ninja 250r
Setting valve lash with cam chain tightened removed?
Hey everyone!
I’m just adjusting the valve clearance in my 2008 ninja 250. The service manual said to remove the chain tightener but now the front facing cam has a lot of play so I’m not sure if it’s the correct procedure to measure the valve lash with that thing removed???
Thanks!!
drychain is offline   Reply With Quote
Old March 21st, 2020, 07:35 PM   #2
Measure before removing cam-chain tensioner.
Only remove cam-chain tensioner if you have to remove cams to adjust clearance with new shims.
Old March 21st, 2020, 08:28 PM   #3
drychain
Thank you! It seems that I got the adjustment and checking section in the manual mixed up
DIY - Checking valve lash on '08+ 250r (WITH pictures) VeX 2008 - 2012 Ninja 250R Tech Talk 45 September 16th, 2017 04:13 PM
Tightened chain. More resistance??? cadd 2013 - 2017 Ninja 300 Tech Talk 5 July 26th, 2015 09:50 PM
Cam shaft seating issues after a valve adjustment? Zombiphone 2008 - 2012 Ninja 250R Tech Talk 23 May 18th, 2015 01:44 PM
valve cover removed question with pic mikedabike64 2008 - 2012 Ninja 250R Tech Talk 6 December 11th, 2013 05:45 PM
Odd sound after chain tightened JohnnyBravo 2013 - 2017 Ninja 300 Tech Talk 18 October 7th, 2013 11:44 AM
